My copier stop at half way.laser light goes to the right & dont turn back.
MY problem is laser eye go half way copying merchantdise and does not go back are return to normal position.
  • 1,326 Answers
You are not looking at th laser. If you are you will go blind. You are most likly looking at the scanning lamp. You did not say what make or kind of copier. Also, do you get a error code? Also, do you get a small part of the copy and the rest is black? If you get part of a copy and the rest is black, you have a analog copier and most likely you have a cracked or a short caued by a crack in the scanning lamp power cable.
Posted on Oct 18, 2008
Why is my photocopier only printing half a page?
Sounds like one of the sensors in the doc feeder that detects the size of the paper has gone bad.
Also, make sure you always close the document feeder when making copies. Sometimes it helps to put a blank sheet of paper over the back of a small object if you're copying something small.
Copier Collin Houston TX Copier and Imaging Expert
Aug 18, 2014 | Sharp Office Equipment & Supplies
Half looks great but the other half is gray scaled has been getting worse for about a month
1)So, your copie is half with good black color, and other half light, with possiblle white streaks?
IF YES: you need to clean the laser unit and replace the toner cylinder cleaning blade, also check the drum unit - if it got over 25000 copies change it too.
2)So, your copies are half good and half like no toner is fixated on paper?
If thats the case replace fixing roller and bushings, and check the press. roller bushings.
Feb 01, 2010 | Canon USA - COPIERS - ImageRUNNER 2010F...
Printer print one-third of the label and then stuck. After pressing button on printer goes empty label (sometimes one or two, sometimes more) and just after that goes good label. Often printer stuck on a...
You need to calibrate your printer to the label stock and clean the photo eye that the label passes over right before it goes into the printhead. Make sure the eye picks up the light. They MUST be in perfect alignment, normally about 1/2" from the side of the label. You should also make sure you have the correct label size AND orientation selected in the program you are running. Running a 6" X 4" label with the program set for a 4" X 6" label will stop the works.
Oct 02, 2009 | Intermec EasyCoder F4 Printer
Hp laser jet 1320 stop printing
Try unplugging the power cord and plugging it back in. Check to make sure that there are no paper jams or foreign objects stuck in the rollers. Reseat the toner and make sure the lid is firmly closed.
Jun 19, 2009 | HP Laser Jet 1320 Printer
Prints only on left half of page. Very light on right half - almost blank. Have changed the cartridge, so this is not the problem.
try to clean the pinout also try to shake the toner for right and left about 5 times and then turn it back
Jun 11, 2009 | Lexmark E210 Laser Printer
Xerox xc1045 copier machine
If it starts to make a copy and the light comes on then stops in the middle there is a problem w/the connection.
check the cable that turns on the light it may have a cut and is not making contact in a particular spot. If not then it may be the board that controls the lamp.
Oct 17, 2008 | Xerox 5665 Copier
Can't make copies
I had the same problem just yesterday. Turn off the printer for 10 seconds. Then turn back on. Turn back off again and unplug from the electrical outlet. Open the control panel and tilt it toward you. Close the control panel, plug machine back into the outlet and turn back on. I did this and it solved my problem.
Sep 10, 2008 | HP Laserjet M1319F Laser Multifunction...
Toshiba 3301 desktop copier
this problem can never be solve on Net, I have had this problem many times with small canon copier, it is a mechanical error that need to be corrected at the point of clutching to return back.
this us to occur when the Copier has worked for long, that is to say the the copier becomes weak. so ...
Apr 28, 2008 | Office Equipment & Supplies
Copier will not allow to use
E codes are usually paper jams take out paper drawer and look for jammed paper if you dont see any unplug copier from wall and plug copier back in somtimes this wil force paper trapped in copier out as it powers up.
Jan 15, 2008 | Canon imageCLASS D780 All-In-One Laser...
k24674
