Question about Thermador PCS484GGUS Gas Cooktop
Burner won't light
My cooktop burner sparks but will not light.There also is no sound of gas coming in when I turn the burner on, please help!
  • Anonymous Nov 09, 2008
    One of the burners on my gas cooktop will not light.
  • jenmenke Nov 22, 2008
    same problem. all other burners light. this one sparks, but doesn't light and when I remove burner cap there is no gas smell, either.
  • 619 Answers
SOURCE: burner won't light
Clean the gas nozzle w/small wire are located at the back of the gas cook top /shut off the gas clean small gas nozzle clog / w moisture /rust dust and any foreing material.
Posted on Jan 10, 2008
Bgillespie
  • 89 Answers
SOURCE: Thermador 30" gas cooktop SGCS304RB
Do you hear gas? If so, take a needle and put it through each one of the small holes where the gas comes out.... Also look for a little "white-dust" where the sparker makes the spark. (located probaly at back of burner). If there is a white dust build-up scrape it off with something (needle) and give her another go...
Posted on Jan 22, 2008
  • 110 Answers
SOURCE: Dacor cooktop ignition problem
TAKE THE BURNER CAPS OFF AND CLEAN THEM REALLY WELL AND MAKE SURE THAT THEY R PUT BACK ON PROPERLY THRER ARE GENERALLY A NOTCH THAT HAS TO BE LINED UP JUST RIGHT FOR THE CAPS TO FULLY SEED TO PROMOTE PROPER LITING
Posted on May 30, 2008
scrodamoon
  • 659 Answers
SOURCE: Gas burner not lighting
make sure the burner ports are not clogged. and the caps are properly positioned. clean ports with a wire or a straightened paper clip if clogged.
make sure the igniters are clean and dry
Posted on Aug 03, 2008
textonor
  • 130 Answers
SOURCE: Clogged burner on gas cooktop
lowly is it the left burners that won't lite? I only ask as depending on the model some of the Thermador cook tops had simmer control burners. This is a 3 part system on the burners. 1 a simmer control, 2 electric solenoid, 3 potentiors. When you turn on the burner the potentior tells the simmer control to send power to the gas solenoid. At the same time the unit will spark. If your unit has extra low on the left 2 burners then you have this system. The usual problem in the potentior. Hope this helps.
Posted on Aug 09, 2008
I have a gas glass cook top (JGC9536) with a problem at the right front surface burner (12,500 btu). I used to be able to just turn the switch on high and the burner would light. Now, there is spark and...
Make sure there is no blockage of the burner near where the spark jumps. All it takes is a drop of water to stop the gas flow near the spark. Most likely you can use a knife or some other thin blade to clear the slots where the flame comes out of the burner.
Feb 20, 2014 | Jenn-Air 35 in. JGC9536 Gas Cooktop
I have a 36" Thermador
Sorry to read about your problem, I hope this helps you out.
you must have a bad control knob
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 20, 2010 | Thermador SGS36GS Gas Cooktop
My GE Monogram 5-burner gas cooktop has a constant buzzing sound. The cooktop is working properly, but the buzzing is annoying.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Sep 23, 2010 | GE Profile JGP636 Gas Cooktop
R rear burner not sparking
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 02, 2010 | Dacor Preference SGM365SS Gas Cooktop
Gas stove burner will not turn on
heatman101
Apr 29, 2010 | Gaggenau 23 in. KG 260 Gas Cooktop
The igniter on the right front burner of my GE Gas cooktop does not work....I must use a lighter or match to ignite....What can I do? There is no clicking sound when I turn on the burner?
all burner igniters work at the same time - you may have a faulty electronic spark unit. change the spark unit. go to repair clinic dot come for the unit. also would be wise to check the ingniter start switch on the gas burner control knob
Oct 17, 2009 | GE 36 in. JGP628 Gas Cooktop
Kenmore Elite 30" gas cooktop installed. Large right front burner
There are a series of holes in the burner leading down from the main flame area to the pilot tube, ensure the holes are not plugged/restricted.
Feb 11, 2009 | Kenmore 30 in. 42701 / 42702 / 42709...
Old Thermador cooktop continues to spark even after turned off
sounds like you have a bad switch. maybe on the large burner.. some of those switches can be replaced without the whole harness.
Dec 22, 2008 | Thermador PSC364GDZS Gas Cooktop
Aug 03, 2008 | Thermador 31 in. SGS304Z Gas Cooktop
Thermador PCS484GGUS Gas Cooktop Logo
32 people viewed this question
Top Thermador Cooktops Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
jasbo
jasbo
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
