Question about Mitsubishi Diamond Computers & Internet
Screen image sporadically changes between 2 sizes.
For a given resolution setting the image size varies from a normal 100% to about 85% size. This happens particularly on startup or when screen goes from screensaver powerdown to active. When the screen shrinks it always brightens significantly and black levels become poor. It will switch back and forth between these 2 states (100%/normal and 85%/too bright) about evry 15 seconds to 2 minutes until the screen has been on for 1/2 hour to one hour. What is the defect and how can this be repaired. This is an otherwise very satisfactory monitor and I don't want to ditch it.
SOURCE:
  • 86 Answers
SOURCE: Screen goes black with white horizontal line.
WHEN does this problem occur? Does it ONLY happen after the computer loads Windows (or another OS), or does it happen as soon as you turn the monitor on? We really need more information before we can provide specific advice or suggestions... IF this happens as soon as you turn the monitor on, switch it with a different monitor. If the problem goes away, the original monitor is defective, and probably not worth the cost of repairing it. If the problem ONLY happens after you load Windows, boot the system into Safe Mode (press the F8 key during bootup until you see the menu which allows you to select Safe Mode), then reboot and see if the problem has been resolved; simply booting into Safe Mode, then rebooting the system into Windows MIGHT solve this WITHOUT requiring you to change any system settings... IF the problem remains in Windows AFTER you've booted into Safe Mode AND rebooted back to Windows, the videocard driver might be corrupted. In that case, you'll have to reinstall the vidcard driver to correct this problem... If all else fails, it IS possible that the videocard itself is defective; if installing an updated driver doesn't work, try swapping the videocard with a different one. BE SURE to uninstall the OLD videodriver, and install the proper one for the new videocard; if you don't install the correct driver, you could create MORE problems than you have right now...
Posted on Mar 30, 2007
Demmy
  • 59 Answers
SOURCE: C840 resolution difficulties...
The type of screen you have is a UXGA screen. the optimal resolution for that is 1600 x 1200. changing the resolution for that will distort the screen causing black borders. If a computer has a 15.0+" SXGA+ screen with an optimized resolution of 1400x1050 and the screen's current resolution is set to 1280x1024 pixels, the display will shrink resulting in a black border surrounding the edges of the screen. Also, all other lower resolutions may be stretched to fit the screen. No border will be visible, but fonts may appear slightly fuzzy.
Posted on Oct 03, 2007
tantong
  • 138 Answers
SOURCE: Image appears for 2-3 seconds then screen goes black
The following steps are how to examine what's wrong with your LCD monitors. After you turned it on and the screen went black, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Tan
Posted on Mar 16, 2008
SOURCE: Screen shrinks monentarily then zooms in untill screen is blank, then turns off.
I had a similiar issue that caused all my Microsoft applications to zoom out to 500%. It also caused PDF documents to shrink and go the the last page. The issue was caused by the Intellatype software that came with my ergonomic keyboard. The issue was resolved by disabling the zoom feature of the sofware on the zoom tab.
Posted on Aug 07, 2008
  • 31 Answers
SOURCE: No input signal
Check connections, Hertz rate, and settings (if you can read them). Otherwise, it may be time to whip out the cash and get a new monitor and/or computer.
Posted on Aug 20, 2008
Using control pannel does not change my screen resolution help
did you click apply after changing any settings ?
click start control panel display desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
Oct 06, 2012 | Dell Inspiron 1100, 1150, 5150 & 5160...
My screen is little blurred . i cant see objects clearly in my screen
you can make changes to your screen resolutions and brightness in your computers settings or if your computers monitor is separate to your computer ie:desktop it might have tabs to make some changes to its brightness and resolution
click start control panel,display,desktop you can select a different desktop from the drop down list
also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
hope this helps:
Jul 27, 2011 | Computers & Internet
I have HP Laptop HPG60-445DX PC Windows 7. I need to change size of letters back to original size-I dont know how
Display in Windows 7 allows you to make the text and other items, such as icons, on your screen easier to see by making them larger. You can do this without changing the screen resolution of your display. This allows you to increase or decrease the size of text and other items on your screen while keeping your display set to its optimal resolution.
Let's see how to change Display in Windows 7:
1. Click the Start and then choose the Control Panel option.
2. Control Panel window opens up. Click Display.
3. Choose one of the following:
Smaller - 100%. This keeps text and other items at normal size.
Medium - 125%. This sets text and other items to 125% of normal size.
Larger - 150%. This sets text and other items to 150% of normal size. This option appears only if your monitor supports a resolution of at least 1200 x 900 pixels.
Make your choice and Click Apply.
To see the change, Click Log off now and then Login again.
See this link:
http://www.techtalkz.com/windows-7/516049-how-change-font-size-icon-size-windows-7-a.html
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 17, 2011 | HEWLETT-PACKARD G60-445DX Notebook
How to use change resolution
The screen resolution of the Camera cannot be changed. The option in the Camera is to change the Image size which will increase the MegaPixel rate of the Camera. This can also be called as resolution. This can be changed by touching the Image Size icon displayed on the Camera screen. The settings available for Still Image Settings and Movie Image Settings in the DSCT70 Camera are given in the image given below:
Thanks,
KenSolutions
FixYa
Oct 21, 2010 | Sony Cyber-shot DSC-T70 Digital Camera
Canon scanner speed slow
Various ways....Try these! the slow problem wil get off
How to change the resolution (Windows)
The precision of printouts can be improved by changing scanning resolution.
The higher the scanning resolution is, the more precise the scanned images are represented, however, the file size gets larger.
The scanning resolution can be changed before scanning photos.
Note: When the scanning resolution is doubled, the image data size will be quadrupled.
When the data size is large, the throughput speed may slow down or may occupy too much of the computer's resources (memory).
<Procedures>
Memo: The following is explained using MP Navigator 3.0 procedures.
To scan using MP Navigator:
1. Launch MP Navigator and click Photos/Documents (Platen) on the Scan/Import tab.
80006642en_05sj00759_en_00.jpg- The window you see varies according to the printer model.
2. When the Photos/Documents (Platen) window is displayed, click Specify.
3. When the Scan Settings window is displayed, select the resolution in Scanning Resolution.
If necessary, set other items as well.
4. Click OK.
5. In the Photos/Documents (Platen) window, click Scan to start scanning.
6. Changing the resolution is completed.
To scan using the scanner driver:
1. Launch MP Navigator and click Open Scanner Driver on the Scan/Import tab.
80006642en_05sj00765_en_01.jpg- The window you see varies according to the printer model.
2. Change the resolution.
According to your purpose, set the resolution in Simple Mode with ease, or in Advanced Mode with a detailed setting.
- To set the resolution in Simple Mode:
(1) Select the Simple Mode tab.
(2) Select the output resolution from the Destination pulldown menu.
If necessary, set other items.
- To set the resolution in Advanced Mode:
(1) Select the Advanced Mode tab.
(2) In Output Resolution, select one of the preset resolution, or enter the number from 25 to 19200 to specify your favorite resolution.
3. Click Scan to start scanning.
4. Changing the resolution is completed.
Jun 01, 2010 | Canon CanoScan LiDE 25 Flatbed Scanner
My moneter sceen picture has become large and out of focus
i  think there was  a problem with system monitor resolution setting,please follow the given steps and check the monitor setting-
1-Right click and go to property option
2-chose setting option
3-check screen resolution,standard size is 1024 by 786 pixels and color quality is highest 32 bits
  and also check advanced option under setting DPI setting is normal size 96 DPI ,choose all option than apply and ok.
Thats helpful to you.
Thanks,
Dec 13, 2009 | Computers & Internet
Images scan set at 300 dpi, end up 72 dpi
It depends on the physical size of the images. Size and resolution are related to each other. Let me explain:
You have an original, say, 2 inches by 2 inches.
You scan it with resolution of 300dpi (dots per inch).
You will get a file that's 600 by 600 pixels, right?
Then you look at it on screen, which has a resolution of 72dpi - if it's displayed without magnification, what size the picture will be? 600 divided by 72 = 8 and 1/3 of an inch, so on screen it will be 8 1/3 by 8 1/3 inches.
So, there's no such thing as a picture file's "real" resolution - we can talk about a resolution at a given size, because it's the horizontal and vertical size in pixels what's "real".
Therefore you have to ask what size the scanned picture is, and then look at the file you receive; in it's properties you will find it's number of pixels horizontally and vertically, and from that you can easily calculate (dividing the height in pixels by the height in inches) the actual resolution the file has been scanned at.
Then you'll know for sure if need to complain to the friend ot not :)
Nov 13, 2009 | Epson Stylus CX4700 All-In-One InkJet...
My sony cyber shot dsc-p32 camera
just change the resolution
set the camera on photo mode
then press trash button, it should display the resolutions
i recomend 1.3 megapixels for normal pictures, when you need the high resolution change it to better
also if you use the options of the photo mode you can change from fine to normal picture quality
Dec 04, 2007 | Sony Cyber-Shot DSC-P32 Digital Camera
DSC-F717 mp Question?
do you mean your files are around 2 mb (megabytes) in size? megabytes and megapixels are not the same thing..megapixelspixels=resolution and megabytes=file size..5MP pictures are around 2MB in size..
Sep 12, 2005 | Sony Cyber-Shot DSC-F717 Digital Camera
Computers & Internet Logo
Top Mitsubishi Computers & Internet Experts
Alun Cox
Argospete
Argospete
john h
Are you a Mitsubishi Computer and Internet Expert? Answer questions, earn points and help others
