Question about Cameras
I POSSESS A SONY DCR-TRV25E DIGITAL CAMCORDER THAT HAS DEVELOPED A FAULT. THAT KEEPS SHOWING THE CONDENSATION SYMBOL AND THE TAPE WILL NOT REJECT FROM THE CARRIER. DO YOU CARRY OUR REPAIRS OR CAN YOU ARRANGE FOR REPAIRS FOLLOWING A QUOTATION? THANK YOU, Reg Hooper
SOURCE: Sony DCR-HC38E Exporting miniDV video to computer
I had a similar problem with my Sharp camorder.
The preview window on XP simply displays corrupted images.
At the end, I bought a different firewire card and it worked for me.
Good luck.
Alex
New Zealand
Posted on Jan 19, 2008
welcomejee
  • 10594 Answers
SOURCE: The no tape and eject symbols are flashing at the same time.
Those signs means Record tab on tape is ON, eject tape and check record tab and make sure to set it on Record position.
Posted on Feb 26, 2009
pontelemon
  • 538 Answers
SOURCE: Can't see how to play Hi8 tapes on this Sony dcr-trv340e pal camera
It's a Digital Hi8. Your tapes are Analog.
But it should play Analog also.
In the menu play with "PB Mode" settings.
Posted on Apr 14, 2009
  • 98 Answers
SOURCE: sony dcr-hc21e camcorder lcd stop working,viewfinder is ok?
This problem can fix by replacing the flexfoil or FPC between the camera and LCD assy if you need parts call a Sony repair service center or ask us
regards,
Rob Rotronica
Posted on Apr 15, 2009
  • 497 Answers
SOURCE: camcorder SONY DCR-TRV25E, COMPATIBILITY window vista
If you want to use the USB cable to connect the Camcorder to the Computer to transfer the video to the Computer then:
(Applicable for Vista Operating System Only.)
This Camcorder does not support USB streaming with the VISTA Operating System.
Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable.
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer using i.LINK cable.
Refer this link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
NOTE: As the Camcorder does not support USB streaming with Vista, it is not required to use any Sony Device Driver to transfer the video to the Computer. You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
(Applicable for Windows XP Operating System only):
If you are using a Windows XP Operating System then you have to install the USB Streaming Driver in the Computer from the supplied Software disk with the Computer.
Check this link for the instruction to transfer video to a Computer using USB Streaming.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
If you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video.
If you are using an i.LINK cable then:
The Camcorder will flash the DV IN message as soon as the i.LINK/Firewire cable is connected to the Camcorder.
If you are getting the DV IN message then it indicates that the Camcorder recognize the connection.
If you are not getting the DV IN message as soon as the i.LINK cable is connected with the Camcorder then the issue may be with either the Camcorder or with the i.LINK cable.
Try resetting the Camcorder or try with different i.LINK cable. Locate the RESET button behind the LCD screen of the Camcorder. (You will be able to locate the RESET button by opening the LCD Screen. The Camcorder should be switched ON when you reset the unit. Press the RESET button using a sharp-pointed object).
NOTE: Resetting the Camcorder will reset the settings of the Camcorder to the factory settings including date and time. It will not delete any data saved in the Camcorder.
If the issue still persists after resetting the Camcorder and with different i.LINK cable then your Camcorder requires service to resolve the issue.
Good Luck!!!!!!!!!!!!!!!
Posted on Sep 23, 2009
Sony CCD FX500E ejects tapes
Mechanical fault. Contact any service technician; or the authorized service centre for Sony. Electro help
Nov 29, 2014 | Sony Video Cameras
Tape will not load sony DCR-HC96E camcorder
will it reject or not ,if so clean the drum inside the tape department amini tape cleaner or rubbing alcohol with a cotton q-tip.if its the motor you will need to service.
Jan 20, 2013 | Sony DCR-TRV285E Digital-8 Digital...
I HAVE A SONY DCR TRV25E AND AM UNABLE TO RECORD THERE IS NO PICTURE APPEARING ON THE LCD SCREEN OR VIEW FINDER BUT WHEN YOU PLAY BACK TAPE U STILL GET SOUND BUT NO PICTURE
Sounds like its fried, there is probably not a fix for the problem that will not cost more than the camcorder.It could be the power converter on the device, a voltage regulator or capacitor might have gone thus cutting power the certain parts of the device like the screen and CCD.
May 02, 2011 | Sony Handycam DCR-TRV25E Mini DV Digital...
I want to transfer video from sony Digital Video Camera Recorder DCR/TRV25E to my Macbook Pro. The camcorder uses Mini DV and I have a USB connection between the camcorder & Mac. Please let me know...
Hi - It's pretty easy. You would use the I.Link (Sony calls it) connector which is actually fire wire. So you would need a fire wire cable (about five dollars or so) between the camera and Mac, load up the built in Imovie software and you'll be ready to go.
Here's a link to a good video tutorial demonstrating the process.
http://video.about.com/desktopvideo/Apple-iMovie-video-capture.htm
Have Fun
Regards, Mikeywaf
Feb 27, 2011 | Sony Handycam DCR-TRV25E Mini DV Digital...
Feb 26, 2009 | Sony Handycam DCR-TRV250 Digital Camcorder
Sony handycam DCR-TRV25E viewfinder is blank
Correct, its CCD Imager failure case in your DCR-TRV25E camera.
Sony offers repair of your camera free of cost.
Click Sony Support UK to get details..
Good Luck.
Sep 27, 2008 | Sony Handycam DCR-TRV25E Mini DV Digital...
Sony camcorder
condensation is the situation where a sensor detects presence of moisture inside that is hazardous to the gadget, this will not be removed if no air flow can get inside, best way is to open any side and blow hot air inside. Not hot that can damage some parts.
Feb 06, 2008 | Sony Handycam DCR-TRV340 Digital Camcorder
Tape rejection - droplet symbol shown
Hi there, the small water type symbol means that the internal dew sensor is activated. Please use the fan (low temperature) or leave it in a warm place for some time. If you need more info please advice.
Apr 26, 2007 | Sony Handycam DCR-TRV130 Digital Camcorder
Cameras Logo
42 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
