Question about Jenn-Air JCD2389G Side by Side Refrigerator
The freezer part works, but the refrigerator side is set on the coldest setting, but not cooling.
    Problem Solver:
  • 12 Answers
There are a lot of reports of this problem with this model. Some of the things to check are the coils in the freezer sextio to make sure they are not iced over. With the compressor running, push the freezer switch and make sure the fan at the back of the freezer compartment is working. There is a duct in the upper right that allows cold air from freezer into fridge, these often freeze up or the trap door spring falls off closing this passage. In the fridge side is a return air duct, I have seen some models where the factory left tape in this duct that reduces air flow. There is a possibility the bulb is staying on although this is remote.
In short this is a poorly designed product and there are a multitude of similar symptoms with different solutions.
Posted on Nov 21, 2008
Samsung RS2630SH Side by Side Refrigerator not cooling down frig or freezer
Is the compressor running? If so, feel the discharge line is the line cold? If not the unit is probably out of Freon, which means it will have a leak somewhere in the system.
Aug 25, 2014 | Samsung RS2630SH Side by Side Refrigerator
Kenmore side by side refridgerator - freezer works very well, refridgerator not very cold, setting is on coldest set point.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 09, 2011 | Refrigerators
The freezer is cold but refrigerator side is turned to coldest setting but it is only luke warm
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 14, 2010 | Kenmore 56864 Side by Side Refrigerator
Refrigerator will only get 58 degrees no colder, freezer is working fine, dial on fridge is on coldest setting...help
heatman101
Nov 28, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Freezer works but only on coldest setting. Fridge is not getting cold on any setting.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 09, 2010 | Jenn-Air JCD2290HES Side by Side...
Refrigerator top rack is warm. Temperature shows 65 degrees
if your freezer can make ice and the ice is dry, the problem is simply air flow into the refig section. A very common cause for a service call that wasnt needed for reefers is the settings. One setting OFF 1-10 usually, operates the compressor. The remaining setting will say , for colder freezer or similar, It opens a little flapper door between the freezer and the fridge section. If you set that one to max or coldest freezer it will actually starve out the fridge section for air ,and you get a cold freezer and warmer box! It happens everytime someone has the problem , its too warm! they peg both controls to coldest! The compressor will coll the freezer sufficiently even if set to 1 and the fridge should be cool too if the setting isnt pegged to coldest setting thus closing down fridge air and making the freezer colder which isnt ever required!
Aug 25, 2009 | Jenn-Air JSD2695KES Side by Side...
Freezer work's excellent,, but fridge part is getting warmer every day now and will soon not be able to keep food cool. Have freezer set at D and E is coldest.... have frige set at 9 coldest setting but...
The freezer plates are the first to get the dwindling freon an dthat will remain the coldest. Find the leak and have it repaired (not just refilled or you will be here again in a few days!
JOAT
Jun 28, 2009 | Hotpoint 21.7 cu. ft. Side-by-Side...
Refrigerator side not cooling
Leave the fridge setting where it is "normal" and turn up the freezer, yes freezer setting by one or two notches.
Apr 08, 2009 | GE Q Series GSS25QGT Side by Side...
Right side of refrigerator not cooling; frezzer working great
Ice build up on back wall could be defrost thermostat or faulty defrost heater
Mar 21, 2008 | GE GSS20IEM Side by Side Refrigerator
Jenn-Air JCD2389G Side by Side Refrigerator Logo
114 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
