Question about Kitchen Appliances - Others
Berkel Slicer won't start
I have an old Berkel model 2040 slicer. When I press the on button, I hear the motor hum but the blade won't spin. If I push the blade with my hand, it spins and works properly. That is until I turn it off. Then it's back to push starting it. To complicate things, this problem doesn't always arise. It will work normally (turn right on and blade spin) for hours or even days and then out of the clear blue it goes back to having to "jump start" it. Anyone ever come across anything like this
Had the same problem, test your capacitor, that should be the cause of it. Good luck.
Posted on Nov 21, 2008
At work we have a berkel deli slicer model hcx and we need to know to sharpen the blade. if we could get a manual that would be great. it is a great old machine. thanks, tina
old food slicers used to have an oil stone that was held against the blade as it was spinning
worked a treat so you could do the same thing
only need to do it for about 30 seconds
Jul 16, 2016 | Kitchen Appliances - Others
Slicer won't start
Motor is jammed, take the blade off and see if you can turn the spindle that the blade mounts to.
Feb 19, 2014 | Weston Meat Slicer
How to remove berkel slicer blade
my berkel slicer model 818 the motor runs and the automatic table will slid but the blade does not torn
Jun 01, 2012 | Berkel 827E Gravity Feed Deli Meat Slicer
Meat slicer blade won't turn
many of them have nylon gears that the teeth strip off of .
Mar 19, 2012 | Berkel 827E Gravity Feed Deli Meat Slicer
Do not have model #...older slicer. need to remove blade to clean behind
there is a thru bolt on the left side of the slicer if you are facing it to use it, that holds the plate on, unscrew it, its usually red
Sep 07, 2011 | Berkel 827E Gravity Feed Deli Meat Slicer
To sharpen the blade of my meat slicer
The stone that sharpens the back bevel is used for more time, but use grind for minimal amount of time, 30-40 seconds sounds extreme to me. The stone for the top surface of the blade is only pressed briefly to remove the slight burrs from sharpening on the back side of the blade.
Oct 09, 2009 | Berkel 827E Gravity Feed Deli Meat Slicer
How old do you have to be to clean a meat slicer in the uk
Old enough to know that you unplug it before you work on the blade!
Sep 19, 2009 | Berkel 827E Gravity Feed Deli Meat Slicer
Globe Meat Slicer Model # 500 motor runs blade not turning
Fiber gear on blade hub stripped. deep socket required to remove hub. DON'T CUT YOURSELF!! remove motor, used food safe solvent to clean grease out of housing. Fiber gear held on with snap ring. Replace gear, repack housing, put hub and motor back and start slicing. Routinely check to make sure gear is lubed.
Oct 30, 2008 | Berkel 827E Gravity Feed Deli Meat Slicer
Kitchen Appliances - Others Logo
463 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
