Question about MyMusix PD-6070 MP3 Player
Ripping from my c drive to my mp3 player
I have the 2 gig mp3 player and when i plug it in to tower message appears saying that the device is not responding. how to remedy ?
I also have ripped some songs already to be transfered. And yes the player is on when in the tower. How do I make this transfer ? My e mail address is djp762002@yahoo.com Please help
    Sergeant:
  • 213 Answers
Go to my computer> properties>hardware > device manager >last one universal bus driver click on it>go to driver and update it
choose only second option when asked
Posted on Oct 18, 2008
Speedo MP3 pink 1 gig. When I plug into my Mac (yes, Mac hooked to power source; yes, plugged directly into the Mac's USB) I continually get a message saying I've ejected incorrectly. Then shortly...
It probably means your usb connection is loose. You can try another usb port on your mac, if that is better then the usb port you usually use is bent or has a loose connection, if not the problem is likely the MP3 player's usb.
You could try putting a small amount of weight on the MP3 Player while its plugged in to improve connection. While it is plugged in, use your finger to lightly move the device up or down and hold gently. If the connection improves, use a small weight to hold device in that spot. If you are pushing down put a small box on top of the device, if you are pushing up, gently wedge something underneath drive.
Hope this helps.
Sep 20, 2017 | Speedo Aquabeat (2 GB) MP3 Player
How do I download Pictures to MP3?
A generic procedure is :-
  1. Turn on your computer. Plug the USB cable that came with your MP3 player into an open USB port on your computer.
  2. Step 2 Turn off your MP3 player and plug the other end of the USB cable into the USB port located on top of the player. Turn on the player.
  3. Step 3 On your computer, right-click the pictures you want and select "Copy" from the menu that appears.
  4. Step 4 Double-click the "My Computer" icon on your computer. Double-click "MP3 player " or ' MP3 Device" in the "My Computer" window.
  5. Step 5 Open the "Pictures" folder. Right-click and select "Paste" from the menu that appears.
  6. Step 6 Let the files copy. Click the "Safely Remove Device" icon located on the left side of the Start toolbar at the bottom of your screen.
  7. Step 7 Click "Safely Remove USB Storage Device." Wait for a message to appear that says it is safe to remove the device, and then unplug the USB cable from your computer and your MP3 player.
Hope i helped you.
Thanks.
Aug 30, 2009 | Audio Players & Recorders
I don't know how to download music into the GoGear VIBE mp3 playe
Usually most mp3 players work as a flash drive when you plug them into your computer. Some won't let you transfer or play while charging, but this one looks like it gives you an option to.
Open Windows Explorer (to see the drives, folders and files) and plug your mp3 player in. Select Charge and transfer. A new Removable Device should appear in Explorer with a drive letter assigned to it. It could be F:, G:, H:, etc... Just copy your mp3s onto that drive.
When you are finished, clock Safely Remove Hardware in the bottom right corner of your screen and select the mp3 player device and stop it. A message will appear saying that it is safe to remove this device. Then unplug it and enjoy!
Aug 17, 2009 | Philips GoGear HDD1830 MP3 Player
Computer is sayin the mp3 is full but there is nothing on it
Suddenly my centon 4GB wasn't allowing me to add mp3s to it as it said it didn't have any more space but I knew it did because I had just deleted a couple gigs. I figured out that there's an "invisible" recycle folder on the mp3 player that has the files you've deleted still stored in it.
To fix do this:
1. plug your mp3 player into the USB port.
2. Find out the letter of the drive it appears as.
ex. let's say the external drive it appears as is F:\
3. Now go to:
Start
Run
Type in: F:\recycled
4. Click on File on the top toolbar
5. Click Empty Recycle Bin
Your free space on your mp3 player should now successfully be retrieved!
Jul 07, 2009 | Coby MPC-848 MP3 Player
Mp3 not recognized by the computer
try re installing the cd program of ur mp3 or if you dont have any... try this. (for windows computer only)
1- plug your mp3 in the computer using your usb.
2- go to my computer.... in the left task pane. click view systems information.
3-the system properties dialogue box will appear.
4-click the hardware tab then click the device manager.
5-the device manager tab will appear.
6- click the portable devices then you will see the name of your device.
7-click the name of your device .
8- you will see in the general tab in the dialogue box that will appear 'device usage'
9- enable it.
thats all..
Jun 07, 2009 | SanDisk Sansa E280 MP3 Player
Can not load music from a cd to my phillips go gear sa3020 sa3021
You have to run your mouse over the Rip tab in Windows Media Player, click on the arrow that appears under the Rip tab, and select Rip Options --> Format --> and change it to Mp3. Then the Rip will work.
-Tha Mp3 Doctor
Feb 16, 2009 | Philips GOGEAR SA6045 MP3 Player
Anko directory error when plugging into my computer
Microsoft error management for error 47 says
When the "safely remove hardware" icon is in the status bar (the by time) disconnet the mp3 player. After a few seconds connect it again. Then reboot the computer system. You will then be able to see the contents of the mp3 payer.
I tried and it works. Also it means the player could be removed without clicking on"safely remove hardware".
Jun 04, 2008 | American Anko MP-2GD MP3 Player
Insignia NS-4V24 sync error
Most likely a issue in the FAT or similar table. The tables used on the internal memory is allocated only for short files names since most media managers change the file names to fit 8.3 dos. They do this since mp3 and mwa audio files use id tagging. So try renaming your mp3's that its eight letters or numbers then the three letter extension .mp3 = rap0001.mp3
Mar 22, 2008 | Audio Players & Recorders
'no database'
The Database error is generally because the device does not have enough free space to create the database ( or GUI ). Delete some songs off the device and that should solve it. You should generally keep 6MB free for every 2 gigs of music. Please add to the question for additional assistance. Best of Luck.
Oct 02, 2007 | Sony NW-E002 MP3 Player
Flash memory problems
When I put in extra 1 gig of memory on my 1 gig unit and then looked at it in my computer the extra memery showed up as another drive. I had 1 gig from the unit as 1 drive and on another drive I had another 1gig
Aug 21, 2007 | RCA TH1101 MP3 Player
MyMusix PD-6070 MP3 Player Logo
Top MyMusix Audio Players & Recorders Experts
Greg Cann
Greg Cann
michael galang
Sandeep Shenoy
Are you a MyMusix Audio Player and Recorder Expert? Answer questions, earn points and help others
