Question about Proview PL926WBi 19" LCD Monitor
Only brief display on my Proview PL926Wbi monitor
When I turn on my monitor, it will display the computer screen quite beautifully for only a few seconds and then goes black. If I turn it off for e few seconds and then back on, it will do the same thing but only for a few seconds. The power indicator remains blue the whole time, even when the monitor is black. Can this be repaired? If so, how? Or should I just trash it?
  • Anonymous Oct 23, 2008
    i have the same problem, it turns black after a couple of seconds but i can still hear sound if i was watching a movie or something. can i fix it myself?
  • Bmonty40 Nov 13, 2008
    I have about the saime problem as above. Mine comes on for couple secs but has a green picture and then goes black.....
I have the same problem i have to keep turnoff than back on how can i fix it and where
Posted on Oct 21, 2008
    Novelist:
  • 159 Answers
Hi
It can be repaired in most cases.
Your's sounds optomistic.
What needs to be done is your power-inverter board needs to be overhauled.
I do these on ebay.
If your picture wasn't pinkish or dark at the top or bottom when it was working, then it sounds like probably the inverter was going and finally went. They are light light bulbs and have life expectancies on the capacitors.
If your picture was pinkish or dark at the top or bottom when it was working then you may have 1 or more of the bulbs failing.
To get to the inverter:
Once the four screws are out of the bottom edge, the the trim slides upwards to unsnap it.
You will probably have to lift the top edge away from the screen itself as you are sliding the trim up because it will hang up on the screens metal trim that is underneath.
Then unplug the screen video cable
At this point to verify possible bulb problems you can plug it in a turn it on.
bad bulbs will usually show their face here.
IF bulbs look okay then unplug the backlight bulb plugs.
The the inverter/ powerboard is under the center area under the metal cover which is screwed into place.
Shout if you need more info.
If you email me a good picture of the inverter in the area of the larger yellow square component, I may be able to get a better idea if it is the inverter from a visual.
Thanks
bammbammfran
Posted on Oct 17, 2008
Does my Proview PL926WBi 19
Any monitor will work with any computer provided the correct graphics card driver is installed. When you install Vista and you do not install the graphics driver, Windows will default to Generic VGA driver and you will not get the best resolution that the monitor can display.
Jan 29, 2010 | Proview PL926WBi 19" LCD Monitor
Proview Monitor PL926 Wbi The power indicator
Repair estimate will be according to problem.
Nov 13, 2009 | Proview PL926WBi 19" LCD Monitor
Computer Monitor Goes Blank
Pink tink = bad LCD Inverter (aka backlight) thats what you will need to replace :)
Jun 26, 2009 | Proview PL926WBi 19" LCD Monitor
Pl926wbi 19"proview monitor,screen goes black every 3 seconds,
Bad capacitors on the pcb boards internally unsoldering ad replacement is indicated.
Feb 17, 2009 | Proview PL926WBi 19" LCD Monitor
ProView PL926WBi
bad capacitors on the board, replace these and the inverters should get there power.
Dec 01, 2008 | Proview PL926WBi 19" LCD Monitor
I NEED HELP PLEASE!!!!!!! PROVIEW 19" MONITER.
Does the led on front of the monitor stay blue or does it become amber ?
If it becomes amber, then you are not getting a signal.
No harm in trying this : You can try to see if it is a contact problem.
With the monitor unplugged.
Use a small paper clip to run in and out of the blue vga plug holes a few times each to make sure they are not plugged or gummed up.
If that doesn't help and you know that your video cord is good, then I am afraid to say that more than likely there is a problem with yor video card.
If it stays blue then the signal is there but the screen isn't fully lighting up, leading to a failing power-inverter board or a bad bulb.
powerseller
bammbammfran
Oct 12, 2008 | Proview PL926WBi 19" LCD Monitor
Blank screen with message "mode not supported"
Hi
How have you connected the monitor to the computer?
Is it through the vga or the dvi port?
Pls press the monitor menu button and change the mode to vga or dvi depending on the connection that you have now.
You might also get a vga to dvi adapter and connect the monitor to the computer.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
Proview PL926WBi 19" LCD Monitor Logo
126 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Pawan Ambastha
Level 1 Expert
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
