Question about Zanussi 24 in. DE6544 Built-in Dishwasher
ZANUSSI DE6544 drying & end of prog indicator lights flashing
Drying and indicator lights are flashing.
When I clear the fault and try to restart a cycle the programme starts and lasts for about 1min then fault indicator repeats.
I'm able to spin the impella on the pump inside the dishwasher and it seems to be free.
Has anyone got any Ideas ?
James
5 Suggested Answers
  • 883 Answers
SOURCE: Zanussi Aquapulse DE6544 not emptying
find the power source (usually at the circuit breaker panel)-then turn the breaker for the dishwasher off and return to on after 10 minutes and try restarting.
Posted on May 27, 2007
SOURCE: Dishwasher was tipped and won't run
I have the same problem if you take off the tray below the front door and set a small blow heater in there it will dry the out the anti flood switch. It usally takes about 25 mins for the machine to start working again.
Posted on Jul 20, 2007
SOURCE: ZANUSSI DE6855 DISHWASHER - NO HEAT FOR WASHING OR DRYING
Make sure you unplug before you start. I had the same problem with a DE6850. The heater was ok. Metered at 25.ohms. Apparently, the relay on the control board mounted in the front door behind the switches is a common fault. Remove the screws around the top part of the door and you will be able to get at the control module. Resolder the connection. Zanussi reliability has been lost. Noel P31bf5e2.jpg
Posted on May 08, 2009
Zanussi Aquapulse dishwasher - is filled with water inside, is not washing and the lights keep flashing on and off - has anyone any idea what may be wrong with it?
Posted on Sep 29, 2009
Zanussi zdt 6053 usually will not run full cycle (on any cycle) but stops with constant error beeps. But it is draining ok and sometimes goes full cycle (not often) Any ideas?
Could be anything!
If you suspect that there is a fault then it will be displayed by blinking LED "END OF CYCLE". As the display of failure in hexadecimal code it can flash up to max. 15 times than short pause and after that repeat fault code. You must to count the number of times the LED "END OF CYCLE" flash up.
Example from user manual: Anti-flood device is activated.
- continuous flashing of the indicator light of the running programme
- 3 intermittent audible signals
- 3 flashes of the END OF CYCLE indicator light
(which means "i30" fault code, the cycle is interrupted and the
drain pump switches on).
Possible causes:
Water leakage from the tub - sump and various connections
(pump, upper spray arm duct etc.); floating sensor blocked
mechanically; microswitch faulty; fill solenoid blocked
mechanically; circuit board faulty (solenoid triac short-circuited);
wiring faulty.
26226179-aipk5px1bmfkdpsmrgevaqwn-3-1.jpg Could be also:
To cancel a washing programme in progress:
- Open the dishwasher's door.
- Press the programme selection/cancel button for about 3 seconds,
until the indicator light of the running programme turns off and the
END OF CYCLE indicator light flashes, indicating that the running
programme has been cancelled and that the machine has
returned to setting mode. It is now possible to select another
washing programme. If a new washing programme will be
selected, check that there is detergent in the detergent dispenser.
NOTE: only during the drying phase, if the dishwasher's door will be opened and remains open for more then 30 seconds, the running programme will be automatically cancelled and the machine will return to setting mode. This will happen, always only during the drying phase, also when the machine is switched off by pressing the
On/Off button and remains switched off for more then 30 seconds.
Dado
Jun 26, 2016 | Zanussi Dishwashers
AEG OKO FAVORITE 4070 - AFter not using for a week dishwasher is flashing dry & end together, will not switch off unless turn it off at the power point, there is no water left in the machine.
If the END or DRYING indicator on the programme progress display is flashing, you can probably rectify the fault yourself.
After rectifying an END or DRYING fault, press the button for the wash programme that has been started.
The wash programme continues. If the fault is displayed again, than check water leakage in the battom of dishwasher.
Malfunction: END and DRYING on the programme progress display are flashing simultaneously.
Possible causes: The leak prevention system has been triggered.
Remedy: Try to find and repair water leakage otherwise close the tap and call customer service.
Dado
Mar 16, 2014 | AEG 24 in. Favorit 60870M Free-standing...
Our washing machine (Zanussi ZWF 1632 W) flashes 5 times
This is a motor problem the end light flashing 5 times indicates error E50. The motor has either got wet or has just failed i would suggest trying to dry it 1st but i would suspect the motor has gone down to earth usually having to replace it. The part no. DST1246179079 Motor aprox £195 but shop around you may find it cheeper.
Dec 11, 2008 | Zanussi ZWF1430W Front Load Washer
Dishwasher not filling
I WOULD REPLACE SOLENOID AND TIMER
Jan 17, 2008 | Zanussi 24 in. DE6544 Built-in Dishwasher
May 27, 2007 | Zanussi 24 in. DE6544 Built-in Dishwasher
Feb 21, 2007 | Zanussi 24 in. DE6850 Free-standing...
Washer will not work
Possible drain fault, check filter. Regards Advisor
Jan 28, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi 24 in. DE6544 Built-in Dishwasher Logo
56 people viewed this question
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
