Question about Brother SX-4000 Typewriter
How do I put the correction tape on? I need a diagram I think. I read the one suggestion offered, and I couldn't do it. I don't know where to thread the tape. I put it in front of the black one, I put it behind the black tape....
tell me please. I need to use the typewriter!
Thank you.
  • 183 Answers
First, remove the ribbon. Now look at the left side of the printhead. (thats the unit that moves back and forth) You will notice that, above the spindel that you put the correction tape on, and towards the platen, on the black plastic, there is a recessed flat place about the width of the correction tape with slight serrations in it. This is the guide for the corr. tape. There is one like this on the right side also.
Put the corr. tape on the spindle, keeping slight tension on the tape, give it a 1/2 turn so the underside (dull) side is facing to the left, and put it in the guide. Then you put the tape behind the two metal "fingers" that are sticking up in front of the printwheel, and then into the guide on the right side. Then put the other corr. tape spool on the post on the right side, and turn it until the red "leader" on the tape is past the middle of the printwheel. The dull side of the corr. tape is the side that does the corrections, so make sure that side is facing towards the platen. Make sure the ribbon goes behind the metal fingers also. The tape and the ribbon should both be between the fingers and the metal cardholder.
Posted on Oct 28, 2008
I need a wiring diagram
Well I go down to as far as 1980. Not sure of the difference (if there is one) and I couldn't see how many "prongs" were on that switch in the video but I did look up the switch that should be for your truck which is the same part number for the 78 and 80 so if that's the correct one that should be for your truck, I think it should be the same. (AC Delco number 19251626 ?). Hope this works for you.....
Oct 07, 2012 | Cars & Trucks
I get " check tape
I Think the cable you mean is a Fire wire cable.
Camera's and tapes, I take it its a mini DV tape movie camera.
Assuming so, on the spine of the DV cassette there's a small plastic slider, open = protect, close = write. I can only think of this as being the issue.
If it is a software problem, to be honest, wouldn't even copy to PC, I'd copy to a dvd recorder with a hard drive, edit it there then burn to dvd.
Sep 10, 2011 | Cameras
How do you put in the correction tape in the brother A X--425
The correction tape feeds the same direction as the ribbon, andI think it only goes on 1 way. The tape goes in front of the ribbon.
Jan 25, 2011 | Brother ® Starter Kit for AX, GX, SX and...
Lines through the tape when recording or playing back
It could need a head adjustment. Any camera store can do that for you.
Feb 11, 2009 | Sony Handycam DCR-VX2100 Mini DV Digital...
I do not know how to load the correction tape...can you help me?
the easiest fix, is to take the machine to a repair shop that sells corr. tapes and ask them to install it. watch how it's done. look in the yellow pages. if you can't find a shop close, - - - first, take the ribbon off, then you put the supply side on the post on the left of the printhead. above the tape and right in front of the cardholder there is a guide for the tape that is black and has 2 fingers pointing to the left. turn the tape so that the part that is facing down as it comes off the spool is facing to the left, put he tape in the guide, between the two metal fingers and the card holder, then into the black guide on the right side and then put the take up spool on the post and turn to take up the slack. put the ribbon back on
Jan 05, 2009 | Brother GX-6750 Typewriter
Wrong letters typing
it sounds like you were using a non-brother correction tape,one that was too sticky and consequently too "slow" and during the correction sequence the fingers of the daisy-wheel got entangled with the tape. Make sure that the correction tape is of a "non-sticky" nature and then take off the correction and printing tapes. That way you will see better how the daisy-wheel is fitted . I will assume that you have an instruction book to show how this is done. before fitting the daisy wheel examine the fingers to see that none are bent or crossed over each other. If this is the case it is better to buy another one. bring your typewriter to the shop if this is the case and they will possibly re-fit the wheel for you. good luck.....
Mar 19, 2008 | Brother ML-300 Typewriter
Correction tape not working on this model
This T/W has 2 tapes a black ribbon and a lift off tape the L/O tape has to be a tack free type General Ribbon T355 or equivelent. It installs below the ribbon on the left and feeds to the right.
Dec 14, 2007 | Nakajima AX-150 Typewriter
Record vcr to dvd-r
This suggests that you are net setting up the DVD recorder up correctly,
Check- are you connecting to the correct 'INPUT; port?
Check have you select the correct chanell that points to this port.
Carefully go the the book- vey can be very dense to read.
Nov 21, 2007 | Zenith XBR413 DVD Recorder
Correction Tape
Check the way the correct tape is installed. I have seen people twist them around the guide backwards and the correction material is facing away from the paper. Also can you see the correction tape lifting up?
Aug 13, 2007 | Brother GX-6750 Typewriter
Brother SX-4000 Typewriter Logo
244 people viewed this question
James Cagle
James Cagle
Jim Keysor
