Question about Denon Audio Players & Recorders
My Denon AVR 1906 receiver keeps shutting off & shorts out.
  • Jonzer Oct 17, 2008
    My Denon AVR 1906 receiver keeps shutting off...shorts out.
djnick989
  • 1067 Answers
SOURCE: Denon AVR-1905 remote
www.remotewarehouse.com grenteeed fit match
Posted on Jan 26, 2008
hawkwatcher
  • 67 Answers
SOURCE: DENON AVR 1906
Units dc protect mode is probably activating due to Blown channel (shorted output transistors) I work for a Denon Authorized repair Center in Michigan If shipping to Michigan is economical let me know kstahl65@att.net
Posted on Feb 15, 2008
tech48
  • 624 Answers
SOURCE: Denon AVR-1907 blinking red power button
It sounds like you have a bad speaker on the zone 2, or you have the speakers connected improperly.
When you engage the zone 2 a relay clicks and the speakers then become part of the amplifiers circuit.
If the problem was in the amplifier, it would go into protect mode without even having speakers connected to it.
If the speakers all check good, you most likely have the wrong type of speakers, meaning the impeadance is too low, or you have too many speakers connected to it.
On the back of the Denon, you will see right around the speaker output jacks, what ratings the speakers should be. If I remember correctly, it says 6 ohms or more when using only "A" or "B", and it says 12ohms or more for "A" + "B".
If you have two 8 ohm speakers on the same speaker jack you now have a 4 ohm load. That is below the ratings and can cause the amp to shut down (go into protect). Since your amp shuts down right away, I think you have a bad speaker or way too many speakers connected.
I have seen many times when people will connect 2 or 4 speakers to the one of the outputs that are designed for only 1 speakers.
If you are using too many speakers you will need a speaker distribution box. It has a resistor network built into it so the amp never sees a lower impeadance than what it is designed for.
You can connect 4, 6 or 8 speakers to one set of outputs designed for 2 speakers. You do loose a lot of power to the speakers, but it is better than blowing up your amplifier.
If I can be of any further help, let me know.
Posted on Jun 22, 2008
  • 4 Answers
SOURCE: Denon AVR-1803 keeps shutting down
check your speaker wires make sure none are touching each other this will cause a short and shut the reciever down
Posted on Mar 17, 2009
  • 92 Answers
SOURCE: AVR-589 Denon Receiver Keeps Shutting Off
even if the wires are not touching they can still arch. make sure there is no bare wire showing ie. cannot see any unshielde speaker wires. id unplug then replug back in
Posted on May 18, 2009
Can any one advise me DENON AVR 1906 stanby power supply voltage check points values & sub transformer in/out voltage values..?
If you wish to get some details; check the site linked here. Pull up older posts.
Circuit diagrams of SMPS section of many popular brand devices are given. Search the site by type in the "brand name" of your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 25, 2016 | Denon AVR-1906 Receiver
Denon avr-1612 keeps shutting off and on
You have an output problem, check outputs for short
Apr 07, 2014 | Denon AVR-1612 5.1 Channels Receiver
AFTER 2-3 SEC THE AMPLIFIER SHUTS DOWN AND THE ON/OFF BUTTON FLASHED RED sOME ADVICE?
Check to make sure the speaker wiring is secure, failing that! the audio output stage that drives the speakers is the problem, you probably have a short and the safety shutdown circuits have be activated to prevent further damage. It will need a technician to remedy the situation.
Jan 01, 2011 | Denon AVR-1906 Receiver
AVR-1508 7.1 Channels Receiver: My Denon AVR-1508 won't stay on. Once I try to tak...
Not familiar with this model but seems like the protection circuit is kicking in, this could be caused by an imbalance of Ohms between channels or a short. remove & check all speakers and cables for continuity or shorts, does the unit power on without speakers or in a different mode (surround off).
always add speakers in pairs (L&R) before testing to prevent possible protection circuit, test main speaker pair first then add surrounds (all according to the allowable Ohms range for the amp of course)
Nov 18, 2017 | Denon AVR-1508 Receiver
Denon 1906 all the right channels speakers not working
when turn on the amp,the volumn cannot under control
Oct 10, 2009 | Denon AVR-1906 Receiver
Mar 17, 2009 | Denon AVR-1803 Receiver
Speakers on the right side of my AVR will produce no sound in any
change the right channel audio ic of your denon amplifier.
Jan 07, 2009 | Denon AVR-1906 Receiver
Denon avr 2105 died (3 times) dead AVR2105 faulty avr-2105
If your amp looks like it's going to work as normal (ie the front display lights up as it should etc), but then the amp goes into protection mode when the anti-thud circuit times out, then I know what's likely to be wrong.
It's one of the power amplifier channels which has gone faulty.
I just found this out after having this problem with my AVR-1906.
I took the amp apart and de-soldered the suspected channel power transistors (centre channel in my case).....and hey-presto! it fired up as normal (obviously the centre channel would be out of service).
I have ordered the replacement transistors from Farnell (UK) at a miserly cost of around £2-£3 each.
Just waiting for them to arrive.
An alternative is, if you don't use all your channels, take the transistors from a known working but not needed channel and swap them over with the duff ones.
Hope thats of use!
Jul 19, 2008 | Denon AVR-2105 Receiver
DENON AVR 1906
Feb 05, 2008 | Denon AVR-1906 Receiver
71 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
