Question about Onkyo TX-SR601 Receiver
NO surround sound coming from our harmon/kardon speakers when set up to our onkyo tx-sr601 receiver. wires connected in correct areas, front left, right and center speakers work, subwoofer works. setup for surround sound. changed out a working speaker to make sure it wasn't a speaker problem, works ok. PLEASE HELP!!!!!!!!!!!!!!!!!!
  • 6 more comments
  • michelle woodburn Jun 05, 2006
    It's NOT the "rear" speakers, but the left/right surround sound. Thank you for your comments.
  • Anonymous Mar 13, 2014
    just received new harmon kardon 2700 receiver. hooked up speakers and i get no sound fromm any source
    does anyone have any suggestions?
  • Anonymous Mar 16, 2014
    Sound is supplied from the TV to receiver via optical cable. This has worked in the past but recently quit working. 3.1 setup. Center channel is the only speaker that won't put out sound. Center channel speaker works with radio output so I know the speaker and cables are working. Center channel only won't work with sound coming from the TV??
  • Anonymous Mar 27, 2014
    I have a Harman kardon 137 .no sound coming out of surround sound or sub woofer.Front and centre speakers r only on quiet softly. Have done speaker test and resetting of avr but no change.
  • Anonymous Mar 28, 2014
    only makes sound in direct listening mode,no difference if in tuner,c.d.,or f.m. selection,have disconnected surround speakers with no change
  • Anonymous Mar 29, 2014
    Why won't my center speaker work when I have it on surround hall mode on?
    President:
  • 3,130 Answers
So your saying that you have no rear channel. Some recivers use a single stereo output ic for both sides on the rear speakers. you could have a defect with this IC . Anther thing Im sure you check3ed the obvious ie : the switch is on suround sound? If there is a front to rear fader is it in the middle? Good Luck
Posted on Jun 04, 2006
Onkyo sr600 memory problem
I had the same problem with my TX-SR601 receiver.
Solution: I changed the capacitor C766 (100uF/6,3V) on the "DSP and main microprocessor" or "U1" board. This capacitor is responsible to keep the settings in the memory. It is directly next to the SRAM ICs (Q705-706) (type: CY7C1019BV/CV33-15VCT).
Now the receiver works properly again.
Mar 04, 2012 | Onkyo TX-SR601 Receiver
Message states the power to zone 2 is not activated when trying to listen to zone 2 speakers. Nothing in my manual about this message. How do I activate power to zone 2 on a tx-sr601
Page 77:
"Not available in Zone 2 mode" Setting not allowed because the Zone 2 mode is turned on.
"Zone 2 is not On" Will not work because the Zone 2 has not been turned on.
TURN ZONE 2 ON.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Onkyo-TX-SR601-Receivers-manual/id/365ag212/t/2/
Page 55 shows the prerequisite settings for using the surround back terminals for Zone 2.
Page 60 describes USING Zone 2 and points out that only analog sources can be used with Zone 2. Are you trying to use digital sources? Read the notes regarding REC OUT.
Jul 07, 2011 | Onkyo TX-SR601 Receiver
How do I connect my onkyo tx-sr705 to a pyle pro speaker selector? I am "not" using the onkyo for a surround sound, only for music with 3 pairs of speakers in different rooms. (CD, Sirrus...
Hi Mdensonjr, I see that this was posted in 2011 but well the speaker selector would be connected to the Front speaker terminals, Thanks, JT
May 29, 2011 | Onkyo TX-SR705 Receiver
This site said it was free - then there is a charge? I am getting a "Protecting" message when I turn on my receiver - then it shuts off....What does this mean and what should I do?
It means the receiver senses excessive heat, or a short at its outputs. Disconnect the speaker wires and see if that helps. If not, get it to a Tech. If it turns on, figure out which speaker path(s) was causing the problem and resolve it.
The manual.
Power shuts off immediately after power on.
• Amplifier protection circuitry is activated. Remove the power cord from the outlet immediately. Contact your Onkyo service center.
Jan 13, 2011 | Onkyo TX-SR601 Receiver
My ONKYO TX-SR601 receive will not let me play my zone 2 speakers. I get a message saying '' Powered Zone 2 is not activated. How do I activate Zone 2? Thanks. Tom
Have just got a 607 myself, but it may apply to your model too.
Press the RECEIVER button followed by SETUP. On the TV screen a menu should appear and select SPEAKER SETUP then SPEAKER SETTINGS and set the powered Zone speakers to ACT.
SETUP will then return you to normal. Note: some other surround speakers will be switched off when ACT is on and ACT won't come on if Bi-amp is used.
Jun 13, 2010 | Audio Players & Recorders
Onkyo TX-SR601 6.1 Channels...dialog norm -3 readout
Enter the menu for speaker levels, and increase the center channel.
Dec 07, 2009 | Onkyo TX-SR601 Receiver
More watts needed
Add another power amp to line outs from your main amp to your speakers this will give more power(current) to your main speakers as you have decreased load on main amp
Dec 22, 2008 | Onkyo TX-SR601 Receiver
Hi We are setting up our new Onkyo TX SR606 receiver but are having trouble with the automatic speaker set-up. The 2 front speakers, centre and the back right speaker are ok, but there is an error...
Hi there. If you are running a 5.1 speaker system, make sure your surround speakers are on the surround terminal NOT ON THE SURROUND BACK. the surround back is only for the 7.1 speaker system.
Sep 13, 2008 | Onkyo TX-SR606 Receiver
No sound from main speakers.....
WHEN YOU SET ZONE 2 ON DID IT ASK YOU TO OUT PUT ZONE 2 ONLY OR MAIN + ZONE 2? IFF SO TRY SWITCHING MAIN ON AND IFF THIS DID NOT WORK MAKE SHURE SPEAKERS ARE SWITCHED ON IN MAIN MENU.
I KNOW THIS IS 2 LATE 4 YOUR NEW YEARS PARTY BUT I JUST FOUND THIS SITE 2DAY.
HOPE THIS HELPED.
CABLE GUY.
Dec 25, 2007 | Onkyo TX-SR601 Receiver
Onkyo TX-SR601 Receiver Logo
598 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
