Question about Electrical Supplies
Light switch problem peter951
Hi yes I do have a bank with 3 switches two are being used for lights already, how do I make the third one live to take another light
  • kuwaitim
    kuwaitim May 11, 2010
    There are a few things to consider - please excuse any unnecessary explaination if you already have these issues covered.
    Most residential lighting circuits are fed from a 15A circuit breaker. This means (by the electrical code) you can have 1,440 Watts of lighting on that circuit. The circuit breaker can handle 15A but to help prevent internal wall fires, we don't use the maximum capacity (even though your car can handle 7000 RPMs for a short time doesn't mean you should do it all the time). Some lighting is done with 20A breakers - it depends on how your home was wired.
    So - all of that to go through the following steps.
    1) find out what circuit breaker your switches are on - taking note of other lights or outlets that are on the same circuit. If these lights are also fed from the same circuit that your microwave or plasma screen TV are fed from, you may want to reconsider adding this light. Add up the wattage of the lights and potential wattage of other appliances. If it's a 15A breaker, you should not exceed 1,440 Watts. If it's a 20A breaker, you should stay below 1,920W.
    2) Once this is established, and you know you're "good to go" - locate the "HOT" wire in the box where you want to add the switch. The best way to do this is with a tool that detects voltage. You can usually find one at your local hardware store for a few bucks.
    3) Remove power from the box - that is - switch the circuit breaker off. Take your tester again after power has been removed and ensure that there are no other hot wires in the box (if there are - check your breaker, make sure you've turned the correct one off - if so - call an electrician - you may have a larger issue).
    4) Create a jumper wire from the HOT wire to where your switch will go. You will want to "wire nut" it to the HOT wire and then connect it to the switch. There should be 2 screw terminals on the switch - one goes to the HOT wire, the other to the light fixture. If you have 3 screw terminals, one will not be used.
    5) Restore power to the box and you should be good to go. If not, call an electrician. Do not force the breaker on if it "pops" to the off position. Undo everything and let the professionals help you out.
    Based on the information you gave this should do the trick. Remeber - don't be a hero - turn off power before wiring. It's not worth it.
    Genius:
  • 1,605 Answers
What is the 3rd switch is used for ??? blank??
another light to a ceiling or to an outlet???
Posted on Oct 23, 2008
Yukon brake light
You have power at the fuse. The brake light switch has two wires on it, one is the supply from the fuse the other is to the lights, Check for volts at the switch (yes), bridge the two wires then follow the wiring checking for a live. Start at a light and work your way back up the loom checking all connecting sockets, has the vehicle a trailer socket, check the multi-plug where it picks up the wiring.
Jan 03, 2014 | Cars & Trucks
Brake Lights don't work on the back of our 2003 Ford Windstar
Did you actually check the brake light switch for power in and out ?
There are two different fuses, one for each side. And the circuit includes the turn signal switch.
The third brake light bypasses the turn signals.
Mar 01, 2013 | 2003 Ford Windstar
Is there an adjustment for the stop light switch on a 99 GMC Yukon. I have replace it and my brake lights still do not work. Park lights work fine.
There is no adjustment. The park lights are on a different circuit than the brake lights.
Do you have a third brake light that works. Its also on a different circuit but works from the same switch. Do your turn signals work. They use the same filament as the brake lights.
Also, the brake light circuit goes through the multi function (turn signal) switch.
Since the brake lights and turn signal lights use the same filament in the bulbs, the brake light circuit will pass through the turn signal switch. When a turn signal is used it cancels out the brake light for that side.
Let me know if your third brake light and turn signals work in the rear.
Also, if youy have not already, check/change the bulbs. The type of sockets those lights are in also get burned so look at them well.
Oct 18, 2011 | 1999 GMC Yukon
I have a 3 wire replacement light switch but the one in the fan only has 2 wires. Can I use the 3 wire switch? If so how does it wire up?
Kind of hard to be 100% sure without seeing the switch, but seems like the old switch was a simple single pole on/off switch while the new one is a multiple pole switch. The old switch had two positions, off and on. The new one most likely is off/on/on, perhaps used to turn on two banks of lights similar to a 3 way switch on a floor lamp; off/dim/bright. Sounds like it could be used provided it fits physically. Wiring would be power in to one wire and switched to one of the output wires. The third wire should be covered properly with a wire nut and tape to keep it from shorting out. However, there will be a position on the switch which will do nothing at all. After having said all this, I would suggest you purchase the correct switch as the replacement.
Aug 28, 2010 | Hampton Bay 44 In. Bistro, Copper Kitchen...
I have power to 3/w switch, and 3wire cable that goes thru 4 lights to a 3/w switch. Can I wire all 4 lights to come on and off with the two 3/w switches ? If so how?
Yes, you can. Since you have power at the one 3-way switch already. Use two of the three wires to go DIRECTLY through to the other 3-way switch. Make sure NOT to connect these wires to anything other than to the 3-way switch. Now, you have power at the one 3-way switch - and the two wires (called travelers, jockeys, etc.) going directly over to the other 3-way switch. You already have your neutral at your lights, so that's taken care of. Now, wire each of the four lights together - and take your remaining wire down (connect it) to the (powerless) 3-way switch where you just brought the two travelers/jockey wires to. Land this on the colored/odd screw on the 3-way switch. Now, the 3-wire cable that came from the 3-way switch that had power to it already...has a remaining wire that you will cap. You used the two wires to go directly over to the other 3-way switch - and now, that third wire can just be capped (or taped off). So basically, you have power at one 3-way switch. You have two wires going directly to the other 3-way switch. And from this switch, you have a wire going to your lights. The neutrals are connected together between the four lights (which I'm presuming have already been connected back to a neutral source, or your electrical panel). I hope this helps. If not, please contact me again. Good Luck, and I wish you well.  - Jim
Apr 14, 2010 | Hammering
How to connect a 2 bank (4 batteries) to the 3 GUEST switches.
Sorry for the delay. I don't understand why they have the third "on/off" switch. Normally on a boat like yours, the set would be as follows :
Each pair of batteries would be jumped together to make a single large bank. We can then consider them "bank 1" and "bank 2" usually they will correspond to port and starboard.
Now you will take the positive lead from bank 1 and connect it to B1 on the port switch and then jumper it to B1 on the starboard switch.
You will do the same for bank 2 and the starboard switch.
The "common" on each switch will be your positive output to the motors corresponding them to port and starboard.
Now you can run your port motor with the port switch selected to battery 1 and the starboard motor with the starboard switch selected to battery 2.
Your emergency parallel is already built in. If battery bank 1 dies, you can start both engines with battery bank 2 and vice versa. Putting the switche(s) to the "all" position will allow you to start/run the engine(s) form both banks at once.
You can use the third switch to supply the "house" system. Take its power feed from the "common" terminal on either of the battery switches. In this way you can isolate which battery bank you use to draw power from for all of your accessories so there is no fear of you running a battery bank dead and being stranded. For example if your house feed is connected to the port battery switch and you have the port battery switch selected to bank 1 (port bank), should you run the battery dead listening to the radio you can simply start the starboard engine and then select "all" on the port switch. Now the starboard engine will be charging the port battery bank, bringing the house system back to life and allowing you to start the port engine.
In order for the system to work it is important that all of the battery and engine grounds be connected together in a central point (a common buss bar).
Dont forget that you cannot switch battery switches while the engines are running.
Good Luck!
Jul 22, 2009 | Guest 297 Secondary Station Control For...
Electrical fan connection
Firstly, yes the fused spur should be earthed. You should wire from the fused spur to the fan L,N & E.
Your light switch should be in line on your light live supply wire.
If you wish to use the light switch to turn on the light and fan at the same time you should also run a live switch wire to the fan L1.
This should FixYa.
Please remember to rate this solution.
Dec 09, 2008 | Dryers
Light switch
You Need to Test with a electric tester and Identify a Hot and a nuetral in t the Box. If you find them that is what you need AT LT.If you are missing either you will have to add it. 3W switches can be installed numerous ways.If you have More info let me know.
Master Electrician
Oct 14, 2008 | Electric Door Light Switch
3 way light switch
with an electrician
seriously,
there are too many ways to wire a three way switch circuit, to guess at, and they are not all compatible if the ends are wired differently, a sparky has the tester to be able to tie the third switch in.
Sep 19, 2008 | Cooper Industries Cooper Wiring CS220V AC...
In our new home we have 3 Hampton Bay ceiling fans with lights. The lights with remotes turn on when we are trying to operate one in another room. Is there a code that can be changed so this does not...
In the wall transmitter (switch) and in the receiver are frequency switches. It's a bank of 4 tiny on/off switches. They can be set so each fan is different. The receiver and the transmitter must be set the same. So, as an example, you could set one of yours as follows ( 1 means on, 0 means off): 1110 - another one 1101, and the third 1011.
Sep 03, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Electrical Supplies Logo
327 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
