Question about RCA Televison & Video
When using the remote ,l'm only able to get channels from 2 to 14,then the screen goes blue with the word (MONO) under the station #
  • 1,879 Answers
How about the other details ?
what channels do you get and are they also in mono if you are not using the remote ?
Posted on Oct 17, 2008
  • 1,183 Answers
HI,
Could you give the connections, how your projection TV is connected for cable televsion. Are you using a setup up box for cable ?. If yes Try switching off the cable box and the televison. Power on the cable box and then the TV and check
Thanks
proton
No audio on only some stations
Apparently the TVGOS (TV Guide On Screen) signal on CBS stations (since the 6/12/09 digital changeover) can cause the sound to be missing on those channels. Use the SAP button on the remote to page through the SAP options. When you return to the normal setting the sound will be restored. This problem should not occur again unless the SAP button is pressed.
Oct 29, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Radio for Sandisk model SDMX1
Press the AB button to toggle between Audio Play, Radio, and Voice Record. Use the left/right scroll to highlight Radio. Then press the center button or play/pause button once to select radio.
You will see FM Radio in the upper left corner of the display. Under that you will see either Preset followed by a number OR Channel. If it is on Preset, you can use the left/right scroll to switch between preset stations. If you press and hold the AB button, the player will scan through all frequencies to find the strongest stations in your area and set those as the default preset stations. When on a particular station, press and hold the record button to delete that station from your presets.
Press the center button once to switch to Channel (or back to Preset). Under Channel, you can manually scroll through the frequencies yourself. Push left or right and hold for about a second to find the next available station.
Press the play/pause button once to toggle between Mono and Stereo.
Those are all the functions I've found so far. Hope it helps.
Good luck,
vw
May 26, 2009 | SanDisk SDMX1-1024-E18 MP3 Player
Using my universal remote contol,lost sound on 2 TV channels
The solution is to change the audio input from SAP (secondary audio programming - default on TV sets sold in Canada) to Stereo or Mono. Your remote will need to be able to access the "Menu" settings screen for your television set.
May 07, 2009 | Samsung TV Remote Control
Sharp Aquos LC-32D44U stuck in ""Mono"
I dont know if this will work for you, but its worth a try. I had the same problem.
1. I changed to a station that was having the problem (an analog station with MONO displayed on the screen).
2. I unplugged the TV for about 15-20 minutes. (I was thinking maybe something needed to refresh, so thats why i unplugged the tv.)
3. I plugged the tv back in and voila. The station showed up as MONO then immediately swtiched to STEREO.
After that, i was able to use the AUDIO feature on the remote to actually change from MONO to SAP, etc.
Ive had my Sharp for about 5 months now, and thats the first time its happend to me. Luckily, i solved the problem...this time.
Hope it helps.
Feb 12, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Cant get mono off tv screen ..
The TV set itself will probably have a button that is marked either "Video," "Input" "Source" or "TV/VCR" - I would need to have your exact television model # to be sure. Make sure the cable box is on. Press the Video/Input/Source/TV/VCR etc button and see if your cable picture reappears on one of the source channels. If your television is connected to the cable box with a standard coaxial cable, then Ch.3 or Ch. 4 would be the right choice. If you have a digital cable box, however, the cable is probably going to be on an auxillary channel. If you give me the exact model # of your TV, and the type of wires that run from your cable box to your TV, I can give you more precise instructions. Good luck!
-Tha Mp3 Doctor
Feb 11, 2009 | RCA M4204 MP3 Player
Program channels
TV SETTING
1. Press the MENU button.
2. Use or button to select the TV setting menu, then press or button.
3. Use or button to select the Channel no. setting and use the or button
to change from AIR (over-the-air broadcasts) to CABLE (cable/satellite broadcasts).
4. Use or button to select the Tuning mode and use the or button.
5. Use or button to select the Auto tune and press or button to
confirm the selection. The unit will immediately search through all possible TV
channels and store those channels with signals in memory. After this is complete,
the unit will switch to the first channel found.
6. To exit the MAIN MENU and return to the normal screen, press the EXIT button.
Note : In DVD mode, this option is not available.
Remarks:
1. Channel no. : 2-69 channel for Air mode, 1-125 channel for Cable mode.
2. Tuning mode : Air or Cable mode are available.
3. Auto tune : Searches for usable stations and stores them in memory.
4. Skip : ON - Skip weak channels. OFF - No channel skip.
5. Fine tune : The frequency changes to allow fine tuning.
6. AFC : Auto frequency control.
7. MTS : Select the Mono sound/Stereo sound/Secondary Audio Program (SAP).
21
TV SETUP
MTS (Multi-channel Television Sound) SETTING
This feature allows reception of sound other than the main audio for the program.
3. Use or button to select MTS menu, and press or button to select the
options (Mono, Stereo, SAP)
4. To exit the MAIN MENU and return to the normal screen, press the EXIT button
on remote control.
Note:
• MTS only operates while in TV mode.
• The SAP (Secondary Audio Programs) feature allows a TV station to broadcast
other information, which could be audio in another language.
RESTORE SETTING
If you reset the TV to the factory settings, all your present settings on picture &
sound will be erased and replaced by the factory’s default settings. However, picture
setting in PC mode and parental setting will not be erased.
Jul 15, 2008 | TruTech PLV1615T 15 in. LCD Television
Cannot change channels in digital mode
Solution that worked for me:
Beware: Although the process should be safe, it technically voids your warranty.
Enter the service menu:
1 - turn of tv with remote
2 - press and release in the following order on the remote: Info, Menu, Mute. Make sure remote is pointing at the tv
3 - turn on the tv from the remote
4 - you will see the service menu. using the down arrow on the remote select the Reset option. Using the right arrow button at this point will do a hard reset.
5 - Wait a few seconds, turn TV on
6 - you will have to rescan analogue and digital channel but it should be working now.
Jan 29, 2008 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Mono setting?
What channel is it and when they tune in that channel, is the picture nice and clear or is it grainy and snowy before the screen goes blue? On some sets, if the signal is weak, the picture will go blue. This is called Blue Screen and is there so you do not see very poor, grainy and snowy pictures. Some sets will have an option in the menu to turn the blue screen off.
Aug 27, 2007 | RCA 24F512T 24" TV
Mts:mono mode and just keeps scrolling through channels
take that tv to a tech you bought that set deffected .or take it back to where you buy it from.but my advice is that you take it back to where you buy it from.as you will pay double.repairs and what you have already paid for the set.good luck
May 02, 2007 | Apex Digital GT3215 32" TV
Televison & Video Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
