When i switched my laptop on it loaded to a black screen displaying 6950\6950(registry\machine\components)
  • 13,433 Answers
Can you explain in more detail what happens? which laptop brand and model you got? Windows?
Try using the recovery disk to restore the system.
Posted on Oct 17, 2008
Does my seammaster model 6950 do straight stiching or only zig zag?
Looking For Seammaster 6950 Users Manual Can You Help
If it looks like these photos, then it is capable of zig-zag and some other decorative stitches:
Vintage Seam Master Sewing Machine Model 6950 149 99
You also may want to talk to these guys about using the Simplicity manual for your machine:
http://www.sewingpartsonline.com/instruction-manual-simplicity-sl6950.aspx
Sep 18, 2017 | Sewing Machines
What caused a black screen
I had the same problem. While rebooting the laptop the screen would be on for a few seconds after it finished rebooting then the display would go black. If you looked very carefully at the screen you could see the image was there but there was no light behind the screen to make the image visible.
I removed the black plastic display bezel cover that goes around the edge of the display screen to check out the lights and wiring. I found a small magnet that belongs inside the display bezel had fallen out of it's slot in the plastic bezel and was stuck to the inverter pcb (printed cicuit board). To fix this problem I secured the magnet into it's slot inside the display bezel with a bit of glue. After fixing the problem and putting the display bezel back together the laptop worked normally.
The magnet could possibly fall out if the laptop was closed and upside down then dropped on a hard surface. Mine did not feel very secure in the mounting slot which is why I secured it with glue.
This magnet is how the laptop knows the lid is closed. When the laptop is closed the magnet is moved closer to a magnetic switch on the inverter pcb and activates the switch. The laptop thinks it is closed and shuts off the lights behind the display screen. When the magnet fell out of it's slot and stuck to the inverter it activated the magnetic switch all the time whether the laptop was open or closed. This caused the laptop to think it was closed and shut off the lights behind the dispaly screen as soon as the reboot finished.
Aug 28, 2014 | Acer Aspire Computers & Internet
Black screen
Start the laptop in safe mode and run System Restore
After that I will suggest you to update your drivers just go the site of your Laptop manufacture. Once there enter the model number OR service tag of the laptop then request driver (usually found in the web site's "Support Section"). There you should be able to find all the drivers for your model laptop
If this didn't help you then it seems that there is registry problem with your OS. so simply get the Intel software partner Reginout to fix all the registry issues which are causing black screen.
Jun 19, 2013 | Dell Latitude E4300 PC Notebook
My laptop came on but my screen is black. I can hear my coputer on but my screen is staying black.
Here are some discrete steps you shall also take besides fixing your Windows 7 registry which is inevitable for safer and stable computing:
* Conduct an antivirus and antimalware scan. Fixing for malwares after a registry scan gives an extra protection to the PC and saves PCs from lots of dangerous infections.
* Start Windows 7 in safe mode and restore your PC/system to the previous date after which you received the Windows 7 updates. It is believed that some updates may be behind these screen issues in Windows 7.
* Adjust your display settings since the wrong settings may also cause the Windows 7 black screen also called the blank screen. You can do this by starting Windows in safe mode.
Follow all the guidelines and start from registry repairing scan for Windows 7 to fix Windows 7 black screen.use registry cleaner reg in out to solve the issue
Sep 13, 2010 | HP Pavilion dv6000z Notebook
Laptop is working fine until the screen goes black
The problem of black screen can also happen in other versions of the Windows. However, the symptoms and effects of the problems in all operating systems are almost same. For instance, when a user starts his Windows, everything goes fine. But when he logs into it there awaits a black screen instead of the normal desktop layout. An average computer user finds it very disturbing and has no clue how to fix Windows 7.
However, the best way to find a solution to this problem is to fix the registry errors in your computer which become the cause of all major Windows errors and crashes. The registry in Windows 7 is a very important component of the entire operating system and it stores information about the Windows settings. If these settings are not adjusted properly then there start to appear strange computer problems such as Windows 7 black screen.
Follow all the guidelines and start from registry repairing scan for Windows 7 to fix Windows 7 black screen. The best available tool to repair registry and fix PC errors such as this is Reg In Out.
Sep 12, 2010 | Acer Aspire One PC Notebook
I have a Toshiba Equium L40-156 laptop.When switching on a message appears saying windows is loading files,the screen then goes blank.
on startup press f8 a screen with a black background and white writing will display select enable vga mode. after windows loads reset display settings
Jan 22, 2010 | Computers & Internet
Load up acer and screen black with arrow cursor only thing that works
registry or some Windows DLL files r corrupt...
try this..
restart, before u get the Windows screen press F8...
choose option load in Safe Mode
if Safe Mode loads and u get the desktop, try downloading Tuneup Utility from internet, install that and clean ur registry
then shut down and restart....
let it load in Normal mode....
let me know if that works else we can work some other solution
Dec 20, 2009 | Computers & Internet
Monitor does not work, computer starts up, dell prompts load, windows prompts load then screen goes black. i can hear everything loading but no display.
connect an external monitor on your machine and check if display is ok on the external monitor. if yes, try to re-install your video driver and check if display is ok on your laptop.
if both doesnt have display (external monitor and laptop's display) i suspected your lcd display is faulty.
Jun 30, 2009 | Dell Inspiron 6400 Notebook
Black screen display after switching on
Try restarting without the battery ...just the power adapter.
May 22, 2009 | Dell Inspiron 5150 Notebook
Sometimes When I boot up my Gateway laptop amessage in white type on a black screen says something about registry/machine component. It flashes so fast I can't see the whole message. I tried cleaning the...
I can't help you here.All i will say is NEVER mess with the registry!! The registry can ruin everything if tweaked by the unknowing hands. I installed a so called registry cleaner 6months ago and it took the best part of 4mnths to get it back to how it was. I'm still struggling to uninstall the CLEANER 6 mnths later.
Oct 25, 2008 | Gateway Computers & Internet
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
