Question about Kenmore 44102 Front Load Washer
Spinning problem Machine occasionally doesn't spin, it appears that skips it on all types of washing.
  • 641 Answers
In those cases it doesn't spin - Do you hear if motor is running (an humming noise) ? It sound like a badly worn belt that slid on the tub (the washer succeed to spin- depending on clothes weight in tub) . Open the rear panel, check for belt status and if it really worn,replace it with a genuine belt from the manufacturer. Be awre you should disconnected power cable from the machin before starting work on it. Good luck!!!
Posted on Jun 04, 2006
Washer skips spin cycle
You have an issue with the controller on your machine. Needs replacement.
Sep 17, 2017 | Maytag Legacy Series Top Load Washer
Washer won't agitate or spin
Hello there and welcome to fixya
there are several things that you will need to check first ok please verrify the following
It doesn't pump or spin
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin
If your washer pumps out the water but doesn't spin, check these:
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Sep 07, 2011 | GE Profile WPRE6100G Top Load Washer
My washing doesn't spin, It doesn't pump or spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 12, 2011 | Washing Machines
GE frontload washer doesn't spin
heatman101
Aug 12, 2011 | GE WSXH208A Front Load Washer
Hi our Bosch exxcel washing machine has stopped spinning and doesn't reach the end of its cycle most of the time. If it does the washing is still soaking and needs a new rinse and spin cycle after....
Hi gillsteer,
I believe your drain pump filter is just clogged. The drain pump is trying to pump the water out before the Spin cycle, but can't. Usually this is caused by a foreign object that is obstructing the impeller. See my tip on how to access, drain & clean the Drain Pump Filter:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
After this, the Spin cycle will run, after the drainage procedure. If it does not, then you may need to replace the Drain Motor. Which is a easy task.
Kind Regards :-)
* If this solution helped you, please rate it
Jul 18, 2011 | Bosch Washing Machines
All the water does not spin out of the clothes & at times it doesn't even seem like it is spinning
heatman101
Jun 07, 2011 | Whirlpool LSR6334LQ Top Load Washer
Machine doesn’t spin,
heatman101
Oct 10, 2010 | GE WDSR2080D Top Load Washer
Washer doesn`t spin
heatman101
Oct 04, 2010 | GE Profile WPRE6100G Top Load Washer
Spin cycle doesn,t work
Hi. this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
May 27, 2009 | Roper RAX7244KQ Top Load Washer
Washing machine won't spin
This site should help -
http://www.washerhelp.co.uk/diy-repair-help_4.html#cl_q2
I am thinking moor brushes, but it could be any one of 3-4 different problems.
Jan 28, 2009 | Washing Machines
Kenmore 44102 Front Load Washer Logo
131 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
