Question about Lite On Televison & Video
Model 5005 have used successfull for 3 years unit now will not recognise disks made by it or accept new recordable dvd rw or older erased dvd-rw disks. Disks which are successfully played on a Panasonic DMR-ES16 dvd recorder/ player. I have two upgrading disks which I have loaded in on the 5005 but no joy. Any advice
  • daveandmarie Oct 18, 2008
    PROTON77 Hi I have tried a commercially recorded dvd( Bird Migration) works fine. I have cleaned the laser with a cleaning disc. I have also put in a CD-R disk and the disk type is displayed & a request for which type of formating choice is displayed. I stopped there because I did not wish to format the disc if the recorder would not play it at a later replay. I then took a brand new dvd+rw out of the box & inserted it . The recorder responded & tried to format the disc but on completion it showed Fail but no error code. Help !
    Daveth
    I have added a comment to Proton77 wth the hope he might see where the problem lies.
  • 905 Answers
You will have to go inside and physically clean the laser eye! because the cleaning disk's do not get all the film off the laser's glass eye. you need to gently clean the crease on the glass
if that don't do it , it may be able to be adjusted but otherwise the laser will have to be replaced
Posted on Oct 18, 2008
  • 1,879 Answers
Optical Drives that uses lasers such as DVD players and CD-ROM drives in computers at some point in time will fail to read discs. On normal operation like what you have been doing for the last 3 years can cause laser malfunction due to wear and tear.
Disc Cleaner and Repair is your option.
  • 4,472 Answers
Most likely you need a dvd lens cleaner. The lenses can become dirty. It is about 10$ at any electronic outlet or wal-mart or any of the likes. You run that through the player and you can give that a shot. Though being that its 3 years old you may want to consider replacement as you can get a much better model for a very very reasonable price under 50$. If you still need any assistance let me know. Please take a moment to accept and rate my solution accordingly.
Thanks,
Lee
  • 1,183 Answers
There can be two points of failure, one the software that controls the DVD player working also called a firmware , second the DVD laser inside the unit.
If you could give us the error code that is displayed on the panel in front it would help.
Also have you tested normal audio cd or a VCD in the system rather than a DVD , if it plays the same.
Thanks
Proton
Posted on Oct 17, 2008
  • Mandeep  Singh
    Mandeep Singh Oct 19, 2008
    Hi Dave,
    Sorry of keeping you waiting for a solution, as the problem seems with only the burning of disks and formatting the new ones. Its the drive bay that gone. Probable cause of failure is the laser that burns disks, has reached it max life or faulty drive. I would suggest to take it in for repairs, as the problem can be resolved by replacig the same.
    Thanks
    proton
  • 6,487 Answers
Does this player still recognize another disc that was not made from it ? of it doesn't recognize and disc at all? if that is teh case that this can be a problem with the lens of the player already you can try to run a DVD cleaner and hopefully that will fix the problem but if still not this may need a lens replacement already...
Samsung DVD-VR330 unit will not accept a brand new blank DVD-RW disc---machine says 'load' for 20 seconds, before saying 'open', which it does.
The DVD-RW will work at random, some brands will wok better than others. Memprex, Sony, Maxell are 3 I can use sometimes. Once the disk is accepted it must be formatted. Click that and if accepted, first do a record for say 2 minutes to see if ti works.
If it works don't take it out until you're ready to finalize it.
That's mostly so the disk will be readable in other players, should it not want to go back in, you probably lost the record.
Don't write on the back, use a card and keep it in the cover.
Sometimes I can use those disk's in PC for data.
regards
Jan 03, 2013 | Samsung DVD-VR330 VCR and DVD Recorder
RC689 DVD recorder/vcr player not recognising blank disks
Take the recorder back, it is clear this is a manufacture issue.
Mar 28, 2012 | LG Televison & Video
What is the difference between a DVD+RW and a DVD-RW.
DVD-RW
It is the re-recordable version of the DVD-R. To use this type of media you will need to buy a DVD-RW recorder. The DVD-RW recorders usually record DVD-R, CD-R and CD-RW media, too. Similarly to what happens to DVD-R, DVD-RW disks can be played in newer commercial DVD players without any problems. Older commercial devices cannot recognize the media, refusing to play the disk. To play a DVD-RW disk, commercial players need the disk to be finished. After finishing the disk, you can only record new data in it by reformatting it, which makes you lose all the recorded data.
DVD+RW
It is the re-recordable version of the DVD+R and everything that was said about the DVD+R is valid for the DVD+RW. Only the newest DVD players play movies recorded in disks using this format. There are recorders on the market that can record both DVD-RW disks and DVD+RW ones. These recorders are called DVD?±RW. Similarly to the DVD-RW, the disk needs to be finished to be played in commercial DVD players, and to record new data in the disk after having finished it requires reformatting it, which makes all the data in it to be erased. DVD+RW recorders are usually capable of reading DVD-RW disks (but not of recording them) and vice-versa.
There you are.
Aug 22, 2011 | Acer Computers & Internet
Model DMR-ES30VEB. I have had this recorder for a few years now but since I got a new Sony TV at christmas I am having problems recording. When I record a programme the DVD says it does not recognise the...
DVD-RW discs are ideal for temporary video recording and data backup, but they are not recommended for successful finalising, as there is no guarantee that the disc will work in another device.
Have you tried using DVD-R discs? these CAN be recorded in video mode AND finalised for compatible playback in other players. I assume the DMR-ES30V is a DVD/VCR combo unit - if so, the DVD recorder will not recognise RW discs; only DVD-RAM and DVD-R.
DVD-R discs are recommended for video recording and finalising in this model. (later model Panasonic DVD recorders allow RW disc recording).
Mar 26, 2011 | Panasonic DMR-ES30VEBS
I have dubbed vcr tape to a Sony DVD-RW disc and tried playing it back through a toshiba player and it keeps coming up Bad Disk. My PC won't even recognise it. When started dubbing the screen displayed 1hr...
Did you say you used a DVD-RW disc to transfer a videotape onto? The reason your PC won't recognise that disc is because the data format on it is a different language to what PCs understand - plus an unfinalised DVD-RW won't play in other DVD players - it is usually an incompatible format.
(DVD+RW discs with titles/top menus created in video mode CAN be played on a PC DVD drive or a normal DVD player as can finalised DVD-R discs (DVD-R discs MUST be recorded and finalised in the same recorder for compatible playback). DVD-RW discs can only be viewed on the unit they were written/recorded on.
The other reason for the 'remaining space' on the disc you describe showing less than 120 minutes is due to a title recently being recorded or erased - unless you format it - the 120 minute / 4.7GB DVD-RW will not show full available space. Erasing titles on re-writable DVDs does not increase space. The same rule applies to unfinalised +R / -R discs (you cannot re-format these to get the space back once recorded - they are 'once only' writables)
I recommend you invest in some DVD-R discs and re-copy your VHS tape to that - then if you are satisfied with the result, title etc., finalise the DVD-R - it will play on any DVD player or PC with DVD support (or it should). These discs are relatively inexpensive to buy just about anywhere.
Final note: do NOT finalise the DVD-RW you recorded (I hope you haven't already done this) - simply format/erase it - re-use it for something else or keep it until you need it.
You can use any brand of DVD, just take note of the format before recording/playing.
Mar 21, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
DVD-RW not recognising blank disk
Usually HPs are good with +R DVDs unless things have change over the last year or two.
Whats the model number on your computer?
Aug 09, 2008 | Tablets & eReaders
Lite-On LVW-5005 (DDW-813s)
I have same problem like you, but I have changed the DDW-813s to a new Lite-On DH-20A4P, it work perfectly, good as new. but you have to make some changes to fix it to the place
Oct 01, 2007 | Lite On LVW-5005 DVD Recorder
Televison & Video Logo
50 people viewed this question
Top Lite On Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
