Have to rev the engine to about to 3.5 to shift into second gear and about 2.5 to shift into third and my speedometer dosent work properly
SOURCE: 99 Jeep Grand Cherokee Laredo
Hi Guys!
I work in a transmission and torque converter remanufacturing plant and have seen this many times! I hate to tell you that your transmission is shot! There is metal in the fluid and some of it got caught in a solenoid not letting fluid through to shift the gears. You will need a rebuild! About $2500 dollars. Of course if you in Pittsburgh, Pa. area I could do it for about half that. Any questions e-mail me at [email protected]
SOURCE: 1993 JEEP GRAND CHEROKEE AUTOMATIC TRANSMISSION
Likely you have a shift control module malfunction. Module is probably on the right side fender in the engine compartment. Check to see if you have one (some do and some dont... go figure...I've got a 91 & 95... I have about five different diagrams and NONE apply to my vehicles)
SOURCE: 2005 Jeep Grand Cherokee Shifting Problems
Check the Trans fluid level with it running and at operating temperature. Jeep NAG1 transmissions are known to have the input electric seal leak trans fluid. Not an exspensive fix add Mopar ATF4 and then relace the guild seal.
SOURCE: shift indicator light 1999 Jeep Grand Cherokee
There are two parts to it, a voltage resistor, and the EL panel itself.
You need to remove the console first. There are 2 screws under the front rubber pad, two under the cup holder, two in the bin. Remove those six first, take the storage bin out, then slide the rear cupholder out, remove the two screws under the cup holder, and one in front of it.
There are a total of 6 flat screws, and 3 self tapping screws you have removed.
Put the parking brake on, shift the tranny to N, and the transfer case to the middle position if equipped.
Remove the entire console. Slide the shifter beezel as far up vertically as you can. There are 4 clips you ned to remove to do it.
You will see a blue and black wire running into the back. Follow those wires to the resistor. You will see a transparent EL panel attatched to the resistor by two clips.
Usually, one or both of these clips has come loose, causing the light to work intermittantly. Clip them back on, and turn on the headlights to confirm that the light works correctly now.
Re-install everything in the opposite order.
SOURCE: 2001 Jeep Grand Cherokee won't shift out of first
P0733=Gear 3 Incorrect Ratio
P0734=Gear 4 Incorrect Ratio,
your transmission is in "limp" mode,
Have the following sensors checked on the transmission,input sensor,output sensor,and speed sensor.
The transmission is not getting a signal from one of them,So it doesn't know how fast your going so it doesn't up shift.
