RENEWING ELEMENTS IN ELECTRIC FIRES - Heating & Cooling
    Novelist:
  • 124 Answers
Dude........ this is vague question. i cant even spell vague is so seldom used . try again be specific
Posted on Oct 18, 2008
New Rheem electric 50 gallon not heating
Check the elements, if you have access to a meter to check them. If they are getting power to elements and you have no hot water.
The elements are not working correctly. I had some elements check out ok till the thermostat's turned on and the elements didn't heat.
Sounds like the elements are bad.
Jun 01, 2010 | Water Heaters
SLow to dry/low heat
Here is a tip which may get your dryer back to normal
Check the exhaust vents for obstruction of lint buildup.
If there is such a buildup the moister sensor prevents the heat to get to operating temperature
It is a saftey device installed on all dryers to prevent fires to start in the dryert
May 28, 2010 | Whirlpool LER8648L Electric Dryer
No heat coming from dryer
Double check the circuit breaker for the dryer (Electric Neptune). Turn it off, then turn it back on. Its possible that the breaker may have tripped for some reason, but wasn't able to trip all the way.
Does the interior of the dryer get warm at all? You could have a 1 of multiple heating elements that has shorted. If no heat at all, the likely a heating element has opened up. Unplug dryer from wall (turn off circuit breaker first!). Use a ohm meter to measure and check continuity of the heating elements.
There may also be a sail switch in the air path of the dryer. The purpose of the sail switch is to keep the elements turned off until there is enough air blowing through the dryer. This helps prevent fires, as well as shrunken denim.
Jan 04, 2010 | Maytag Neptune MCE8000AY Electric Dryer
The electric burner elements on my whirlpool Super Capacity 365 stove often won't heat. They seem corroded on one tip and the socket they go into looks dark. Can I simply replace them?
YES YOU CAN . FIRST TURN OFF THE POWER TO RANGE , THEN LOCATE THE SCREWS ALONG THE SIDES OF THE TOP REMOVE AND YOU SHOULD BE ABLE TO SEE THE ELEMENTS AT THE END OF EACH ONE THERE IS A TWO PRONGED CONNECTION REMOVE ELEMENTS FROM THESE PULL OUT TAKE ALL THE ELEMENTS TO AN ELECTRICAL AND PLUMMERS SUPPYLY STORE FOR REPLACEMENTS, REFIT NEW ELEMENTS AND YOUR COOKER SHOULD WORK FINE , GOOD COOKING .
Nov 17, 2009 | Whirlpool RF364 Electric Kitchen Range
No heat in kenmore series 80, model 85040
hello there:
here is some troubleshooting ideas for you to help
A dryer sometimes won't heat or heats too slowly because of a variety of reasons. By following the guidelines below, you can inspect the heating elements on a gas or electric dryer to pinpoint the source of the problem.
Electric heating elements, found in electric dryers, are self-contained units located in the back of the dryer. A defective heating element is frequently the source of no-heat or drying problems. Remove the back service panel to gain access to the elements.
The heating elements are located inside the heater ducts. If you think a heating element is faulty
Oct 26, 2009 | Kenmore Dryers
No operating instructions
the top one turns the broiler elements on 1 is for the center element 2 is for the 2 side elements and 3 is for all 3 elements. The next dial down turns the electric on or off . the third dial is the same as the top except for the bottom elements
Apr 11, 2009 | La Cornue Chateau 120 Dual Fuel (Electric...
Electric water heater elements.
after you shut off electric and water and drain tank they are unscrewed. they make a large socket like wrench to remove i have also removed using a basin wrench
Mar 25, 2009 | Water Heaters
MY ELECTRIC FURNACE WILL COME ON BUT THE FAN WONT COME ON WITH IT
Check your amps on your sequencers. Ensure they are pulln the correct amps. Ensure you have continuity in your elements. They should energize with your blower. Your amps should not exceed 25 for each element. If this is too technical, then, ensure your filters are clean, restart the furnace by resetting the breaker two or three times. Pull off your therm and connect red and white wire together and see if it fires up.
Dec 08, 2008 | Heating & Cooling
Inoperative oven electric elements
It could be contact problems where elements are pushed into in oven. Elements are usually plugged into heavy copper lugs at the end of both element ends. should look at manual for this unit to see how to remove and check for blackened ends. {Make sure to unplug before any work}
Nov 28, 2007 | Dacor Epicure ERD30 Dual Fuel (Electric...
Heating & Cooling Logo
54 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
