Technics SU-G91 OVERLOAD PROBLEM
I have a technics su g91 amplifier and speakers a and b will not work and i believe that it has to do something with the "over load" icon being lit up.  I was wondering what that specific icon represented and what i can do to fix it?
I HAVE THE SAME PROBLEM WITH MY SU-G91, BUT THE LED DISPLAY DOESNT WORK EITHER, MY OVER LOAD LIGHT COMES ON WITH WHAT EVER I'M PLAYING "CD PLAYER,FM STEREO ETC." WHAT CAN I DO TO FIX MY STEREO AND HOW MUCH WILL IT COST ME TO HAVE IT FIXED?
  • Tijuan Wortham Dec 13, 2008
    where can i buy one from email me at tijuan88@yahoo.com if you can tell me where to get it
  • 4,234 Answers
THe amp has detected a problem and shutdown to prevent further damage. This unit has 2 amp pacs inside and one or both have failed. If you can solder, you can fix this yourself. The main amp pac is an SVI3206 and can be purchased online for about $60.
Keep me posted.
Dan
Posted on Oct 21, 2008
  • Gregory Thompson Feb 11, 2016
    I'm in need of a svi3206 main amp pac. I can solder. I'll try to find one online or elsewhere. Thanks for the tip!
    New Friend:
I just bought a Technics SU-G91, hoping to connect to my akai GX-230D reel to reel and speakers. do I need to get anything else to hear it, like a receiver/tuner? everything appears to be working or have I just hooked it up wrong?
Posted on May 31, 2013
  • Er-er Dyer May 31, 2013
    does the amp have to be hooked up to a stereo for the reel to reel to play?
Do you have a user manual for the SU-g91?
THANKS
Steve
Posted on Dec 01, 2011
I have a Technics SU-G91 amp that is stuck in overload even with no input. I have tried giving it a quick blast of air to dust and still nothing. All help is appreciated!!
Your Technics unit will remain in the overload (protect mode) state until component failures have been corrected. The output stages and/or associated components may have failed.
Sep 02, 2016 | Technics Audio Players & Recorders
User manual for technics su-g91
Check the Technics website, or Panasonic, as Technics was made by Panasonic.
Dec 14, 2014 | Technics Audio Players & Recorders
How do I hook up a stereo reciver to the technics su-g91
I assume you want to use the SU-G91 as a power amplifier to drive your speakers. If your receiver has connections for inserting an equalizer (may be labeled pre-amp output and power amp input), remove the jumpers between the pre-amp and the power amp, then run cables from the pre-amp to the SU-G91 inputs. You can have an equalizer between the receiver and the integrated amplifier.
If this is not available, use the recording output (for a tape recorder on older receivers). Note that the volume control on the receiver will be bypassed with this connection.
Sep 23, 2012 | Audio Players & Recorders
I have no sound in teh left channel , could be an integrated ?
Hey, The model of the amplifier is SU-G91 Technics.....If you could help......Thank you.
Apr 08, 2009 | Technics SA-EX320 Receiver
Su-g91
Have you checked the fuse in the unit?
Aug 31, 2008 | Technics SA-AX540 Receiver
Technics SU-G91 Left channel bad
Did you ever find the solution to the left channel issue? I have the same problem with mine.
Dec 02, 2007 | Technics SA-AX540 Receiver
I had the same problem. As soon as the volume reached about 24db it would go into overload. I was able to fix it by soldering all the connections on the larger power module. The one connected the the heat sink. When I took it apart there where several solder points that had come loose.
Oct 10, 2007 | Technics SA-AX540 Receiver
1,718 people viewed this question
 Grubhead
Grubhead
