Question about Honeywell Heating & Cooling
What is the difference betewwen a make on break and make on rise pipe thermostat
    Novelist:
  • 124 Answers
I want you to go to the truck and get a part as soon as i decide the part is bad and tell you. that is make on rise. you see that the part is broken and decide on your on to go get a new one as soon as you see it break that is make on break. the diffrence is the time that passed between my deciding i needed a part and your deciding the part was bad.
Posted on Oct 18, 2008
Would a closed thermostat stop the radiator fan from turning on when the temperature is within heat range.it turns on when I turn ac on,is that a different cause when not using ac.
There are two different thermostats--one in the cooling system, and one just to turn on fans. The AC has a separate circuit to turn on fans regardless of engine temp, so tind the the fan thermostat and test it.
Jul 03, 2016 | AC Cars & Trucks
Oven won't pre-heat or reach bake temp?
Could be the oven thermostat, that's the long skinny tube with the thin copper pipe coming off it follow it back to the oven knob. Test it by putting a putting an oven thermometer in and compare the difference they only cost a few dollars at good home ware shops.
May 07, 2014 | Maytag MGR5751AD Gas Kitchen Range
Cant get thermostat housing off (hot water thermostat)
You will have to get the bracket out of the way, just to get the housing off and back on in an easy manner that won't cause a leak.
The hose may be the one from the valve cover area, carrying the blow by and crankcase fumes back into the intake-so part of the positive crankcase ventilation. So that hose could have a lot of carbon like deposits. See if you can twist or work it back and forth carefully. Not sure how it connects or where it comes apart, If it is plastic, sometimes they break no matter how careful- age makes them very brittle.
Feb 27, 2014 | 1993 Oldsmobile Cutlass Ciera
What to disassemble to change thermostat
You will need to remove your air cleaner and duct assembly. You will then see the thermostat housing sandwiched between the back of the intake manifold and the exhaust crossover pipe. The service manual says to remove the exhaust crossover pipe, but trust me, you do not want to attempt this unless you have access to a torch to heat the nuts that hold the thing to the exhaust manifolds. If you break a stud, then you are going to be removing an exhaust manifold for broken stud removal. If you take the 8mm screws out of the heat shield on the exhaust crossover pipe, you can wiggle the heat shield out. This will provide enough room to get the lower thermostat housing bolt out. It is a pain to do it this way, but it works and will prevent broken exhaust pipe studs. Sometimes the little 8mm bolts will also break, but since they only hold the heat shield, it is of no great consequence.
Then all you have to do is remove the two bolts that hold the thermostat housing to the manifold. The thermostat is directly under it.
Then the only other real "trick" is getting the thermostat and O-ring to stay in the correct position while you put the thermostat bolts back in. A trick that I use is a small wooden wedge. I put the thermostat housing into place over the thermostat and O-ring, then place mt wedge between the thermostat housing and the crossover pipe to hold the thermostat housing in place while I start the bolts. Otherwise, the thermostat tends to slide out the bottom while you are trying to get the bolts started.
Let me know how it goes...
Jun 16, 2012 | 2002 Buick Rendezvous
The washing machine fills constant and water drains out straight away.
your drain hose is installed incorrectly. it rise at least 36" or so (preferably higher) before it enters the stand pipe (drain pipe connected to the houses plumbing), and there has to be an air break (i.e., not sealed off where the drain hose enters the stand pipe). hope this helps.
Mar 06, 2011 | Washing Machines
Over heating
When your temperature gauge reaches "H' it may too late to prevent a major breakdown. Knowing the symptoms of an overheated car and how they occur may be the difference between being inconvenienced and incapacitated.
Identification:---Other than a low oil level or low oil pressure light, there is not a more significant part of a car's instrumentation than a rising temperature gauge or a glowing "Hot" light. These lights are really the only confirmation a driver has that his car is really overheating. It is the identification of the symptoms of an overheating car that enable the motorist to avert a badly damaged engine. Overheating is always a traumatic event for a car's engine, which makes the early identification of the symptom an important addition to the informed motorist's tool kit.
Stuck Thermostat:--The car's thermostat is a valve that controls coolant flow from the engine block to the radiator. When the engine is cold the thermostat remains closed so that the coolant can reach operating temperature quicker and also provide heat to the passenger's compartment. The thermostat has a spring on it that moves depending on coolant temperature causing the thermostat to open. Sometimes the thermostat fails to open thus restricting coolant flow to the radiator where it would be cooled down. This condition is often the cause of overheating. The symptoms of this cause would be a rising temperature gauge and possibly the loss of heat inside the car.
Restricted Radiator:---A car's radiator will have thousands of gallons of coolant passing through in its lifetime. Along with the coolant comes particulate matter in the form of corrosion breaking loose from various parts of the car's cooling system. These contaminates collect in the tubes of the radiator reducing its efficiency. Extensive "plugging" in the radiator will cause the car to overheat. The symptom of this condition would be a rising temperature gauge which goes up when you accelerate.
Coolant Loss:--A car's cooling system is a closed loop system. You are not supposed to lose coolant. Sufficient coolant loss will cause the engine to run hot because engine is heating less coolant to higher temperatures. The symptom of overheating induced by coolant loss would be a pool of coolant on the pavement when the leak is external. Steam under the hood as the lost coolant hits hot parts of the engine, or a rising temperature gauge in the case of a undetectable engine related leak. Of course, the gauge would also go up if the leaks were not detected. Deteriorated Water Pump:--Cars use a belt driven pump to push the water and coolant mixture through the cooling system. This part is called the water pump. Rarely the impeller that draws the coolant through the pump will rust away making it impossible to push any through the system. If this occurs the temperature gauge will climb and coolant will boil over in the radiator. Inoperable Fan:----Most cooling fans are electrically driven. Some are driven by fan belts. If a belt breaks or the electric supply to the fan is interrupted overheating may result. Electric fans are tuned on thermostatically when needed. When the car runs at idle for extended periods or the weather is extremely hot, a failed fan will cause overheating otherwise it serves as a standby assist to the rest of the cooling system. In stress conditions an inoperable fan will cause the temperature gauge to rise. This will help. Thanks please keep updated.please please do rate the solution positively .thank you for using fixya
Mar 19, 2010 | 2001 Hyundai Accent
The door won't lock and water is leaking out
it may be being sucked out by siphoning through your sewer pipe .Probably a siphon problem . Check your drain hose to make sure hose is not stuffed too far down drain and air can get between the hose and the drain pipe . If you have tapped the hose to the drain to keep water from coming out the drain pipe , go to home depot , and get a siphon break . When a washer fills , but water level doesn't rise in the machine ,
Aug 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water drains out during wash cycle
it's being sucked out by siphoning through your sewer pipe .Probably a siphon problem . Check your drain hose to make sure hose is not stuffed too far down drain and air can get between the hose and the drain pipe . If you have tapped the hose to the drain to keep water from coming out the drain pipe , go to home depot or an appliance parts house , and get a siphon break . When a washer fills , but water level doesn't rise in the machine ,
Aug 17, 2009 | Whirlpool 24 in. DU930PWP Built-in...
I have a 2002 renault laguna, every now and again the cluth pedal stays in the down position and the car struggles to go in gear, once i lift the pedal back up into the normal position the clutch works...
try bleeding the cluth it sounds like you have air in the system.and have a look and se if the brakes and the cluth use the same fluid if there do bleed the brakes to
Sep 20, 2008 | Renault 18I Cars & Trucks
Heating & Cooling Logo
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
