Panasonic pt-53tw53g projection tv,convergence problems -green hill on bottom.i replaced the convergence board with no luck,whats next?
  • virreb Oct 18, 2008
    once in a while in the beginning,it would stretch out to full screen for a second then go right back.voltages are correct.
    this is a projection tv not plasma
    Genius:
  • 2,035 Answers
You will need to reset the TV . To reset your TV press and hold the [VOL -] button on the TV and the [OK] button on the remote at the same time until the words “Self Check” to appear on screen. Turn the TV off and back on ,and check if its working....
Posted on Oct 18, 2008
    Genius:
  • 1,226 Answers
since you had been observed the green in the bottom, it means that voltage drops in its components is not correct. please check the Vertical and Horizontal regulator and then the capacitor that digest right voltages to project in the projection screen.
melnavz
  • 507 Answers
I suggest you make sure the bulb/lamp is properly installed and working correctly. It may need replacing.
it seems like the plasma display driver circuits are going bad.
  • 2,322 Answers
Did you replace the entire convergence board?
With the information you are giving us, we can suggest to check the voltages from the power supply going to the convergence board. Double check the connectors that connect to the convergence board as well.
Posted on Oct 17, 2008
Convergence problem Panasonic PT-53TW53G
First I know this set well, did you pull out the board or the light box to replace the chips?
Convergence problems are usually easy to see...
see attached photos and tell me as much as possible.
SD TECH
Nov 10, 2011 | Panasonic PT-53TW53 53" Rear Projection...
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Yellow band on bottom of PT. Double image on news scroller at bottom of PT. Have tried convergence - no luck. Green will not align and will not come down.
Ur tv have any colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures.Ur tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.The parts,must be replaced on the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Oct 13, 2010 | Panasonic PT-47WX49 47" Rear Projection...
I have a Panasonic Projection HDTV that i recently adopted. When i took it home I found a blue "bowing" at the bottom of the video. The experts i spoke to said i need to replace the convergence chips and...
The 2 STK convergence ICS are dead,all the resistors too,if it is smoking and glowing.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it again.Find the correct tv make and model.The convergence kit buy from one of these website's will have all the parts to repair it right this time.
Jul 16, 2010 | Panasonic PT-53TW53 53" Rear Projection...
I have a panasonic PT-47wxc43 projection tv. I have green and purple halos coming up from the bottom. The screen has purple and green double images which are worse from the bottom up.
This problem is due to convergence output ICs failure and both chips will be replaced to fix the issue.
There are two big black ICs installed with aluminum heat sink on deflection board, these are convergence output ICs and will be replaced to correct the problem, it is common problem of rear projection tv.
Below image of deflection shows ICs (marked in red) that are need to be replaced.
IC number is STK392-110 and available with Part Store for $32 each.
Click above link to see an image of IC.
If you are handy with electronics stuff repair and can replace parts in tv circuit board then can replace these parts yourself or ask local tech to help you.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
May 25, 2010 | Panasonic PT-47WXC43 47" Rear Projection...
My panasonic TV Model: pt 53tw53g turns off by it self
My Panasonic has exactly the same problem. The repair man just came in and said that the convergence and resistor burned under heat and have to be replaced. Will cost $400.
May 13, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-53TW53G 1 Blinking red light, will not stay on.
just got back today for same problem. convergence went out. took to repair shop. $200 part plus $60 labor. second time in a year convergence went out. was told it will happen again.
Mar 19, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Tv trouble
djbone30, you need two STK392-110 convergence amplifiers.
Sep 25, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Phillips 60 inch HD rear projection? Convergence!
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 26, 2007 | Panasonic PT-53WX53 53" Rear Projection...
Washing Machines Logo
Top Washing Machines Experts
