Question about Dryers
Amana LE1100W What all did you have to do to replace the belt? I have the belt now but I am a little stumped on what needs to be removed to replace the belt. Thanks Bryan
3 Suggested Answers
catriver
  • 878 Answers
SOURCE: kenmore 417.90812990 dryer element is broken and needs replacing
That is correct, it can be a beast sometimes. Always better to have 2 people to make it easier.
Posted on Apr 17, 2008
  • 65 Answers
SOURCE: REPLACE BELT ON AMANA WASHER
REMOVE THE FOUR BOLTS HOLDING ON THE MOTOR MOUNT TO THE MILK STOOL. DISCONNECT THE DRAIN HOSES, UNPLUG THE WIRING HARNESS AND THEN ROLL THE BELT OFF THE MAIN PULLEY OF THE TRANSMISSION. FLIP MOTOR OVER AND REMOVE THE DRAIN PUMP, NOTING HOW THE BELT WAS THREADED THROUGH THE PUMP MOUNTS.
Posted on Jan 27, 2009
Hello! The belt broke on our Amana Mod.# DLW330RAW . Could you explain how to install the new belt? Thanks Ron
Remove the bottom kick plate.
Remove 4 big bolts and unplug the motor. Move the motor assembly to a work bench. You need a T-20 torx driver to remove the pump screws and remember the rear pump leg goes between the belt. I have your Amana washer repair manual HERE
Mar 17, 2010 | Amana DLW330RA Top Load Washer
HOW HARD IS IT TO REPLACE THE BELT ON A AMANA ALW430RAW WASHER
that belt replacement requires some effort but you can do it with a little patience. then you will have your reward plus your washer will be fixed. you'll need a torx head screw driver ( if u don't have one they sell them at the hardware store) and a 1/2 inch socket. it requires removing motor pump assembly from washer and then removing pump from motor. it will take you a while. it's not as hard as it looks. good luck.
Jan 29, 2010 | Amana ALW480DA Top Load Washer
Broken belt . The belt broke on my ALW480DA Amana Washer. I can seem to be able to replace it becuase thre are four posts in the way holding the water pump housing. How can I change the belt.
you need to remove 3 or 4 bolts out of pump mount and slide pump down on shaft string belt and push pump back up and reinstall bolts in pump
Sep 26, 2009 | Amana ALW480DA Top Load Washer
I have an Amana ALE643RBW drum needs manual assistance to tumble
If you remove the back panel you will be able see the drum rollers. There's a good chance they may be worn out. As long as you are replacing the rollers I would suggest replacing the belt at the same time.
Typically when the rollers wear out, the drum drops ever so slightly and the drum wears on the front and rear drum to cabinet seals.The added drag can cause a slow drum and squealing noises.
Good luck, let me know if there is anything further you need.
Regards,
Aug 18, 2009 | Amana ALE643RB Electric Dryer
I need to replace the belt
You shouldn't have to remove the pump to replace the belt. The motor mount can be loosened and the motor moved so the belt will fit over all pulleys without removing the components.
Loosen motor, move it in, install belt, move motor out to correct belt tension, tighten motor mounts.
May 28, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Jan 19, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Kenmore 417.90812990 dryer element is broken and needs replacing
Apr 10, 2008 | Kenmore 94812 Top Load Stacked Washer /...
Amana ALW480DAW washer
Remove the front panel by loosening the two screws that hold it in place. Unhook the spring that puts tension on the tension pulley. Remove old/worn belt and replace with new belt. Very important that you use the correct size belt or the motor may be damaged and remember to hook the spring back for the tension pulley. The new belt has to go around the inside of the tension pulley.
Oct 22, 2007 | Amana ALW480DA Top Load Washer
Dryers Logo
70 people viewed this question
Top Dryers Experts
