Question about Graphics BV200 BizView 128MB (128 MB) PCI Graphic Card
Graphics card I cannot run the game Joint Task Force
  • Jamaine Robinson
    Jamaine Robinson Oct 27, 2008
    When playing games the screen moves slowly.Make it move like a playstation 2.
    Problem Solver:
  • 5 Answers
Then you probably need a new graphics card.. JTF requires these at a minimum to play:
Minimum System Specifications
  • Windows 2000/XP Home or Professional/x64
  • Intel Pentium 4 2 GHz or AMD Athlon XP 2000+
  • NVIDIA GeForce 4 (non-MX) or ATI Radeon 9500, DirectX 9.0c compliant videocard with 128 MB RAM
  • 512 MB RAM
  • 3 GB of uncompressed hard drive space
  • DirectX 9.0c compatible sound card
  • DirectX 9.0c (included)
  • 4x CD/DVD-ROM drive
  • Microsoft-compatible mouse and keyboard
  • 56 kbit/s dial-up modem for online play; 10 Mbit/s for LAN play
Posted on Sep 05, 2009
Serious sam 2 stops working on window 7 64 bit
To use compatibility mode the .exe has to be on the computer. If the software won't install from a dvd or cd you will have to iso it using magiciso or ultraiso or poweriso then once it is on your hard-drive find it using Windows Explorer (start/all programs/accessories/Windows Explorer) and use winrar to extract it to user data into a folder. find the .exe for the installer and right click it and choose properties then compatibility tab then choose run as.... keep trying a different method until it installs. ****Alternatively it may work if you just find the shortcut and right click it and choose properties then compatibility tab then choose run as...
Dec 02, 2013 | 2K Games Joint Task Force for Windows
I can only see top corner of screen
This sounds like you have the wrong video ratio configured in the game. If possible, see if you can access the in game menu and change the video settings to the appropriate ratio ( 1620 x 1200 etc). If you can't access the menu, you may want to uninstall and reinstall the game.
Additionally, some games have a separate launcher program you can run(within the install folder, usually located in C:\program files) which you can change video settings.
Further, make sure that your system meets the required system specs to play the game properly.
You can check the system requirements at the link below. It is the manual for the game. The last couple of pages should show this information.
Click Here
Regards,
G33k
May 07, 2011 | 2K Games Joint Task Force for Windows
Im on windows 7 and have joint task force, the game installed fine and i could play it fine for about a week, but then it came up with this message- Fatal error settings.ini(1): error: unknown...
NOOOOOIT jtf op windows 7 spele!!!! ik had het ook eens gedaan,het werkte maar na een paar dagen kreeg ik blauw scherm en dat is het ergste wa een pc kan overkome op een paar dinge na. men geluid bleef ook hangen en men pc begon rare geluiden temaken zelfs met de workshop van jtf. op vista werkt de workshop maar het spel niet. je moet normaal dan de 'settings' veranderen maar da helpt niets bij mij
Jan 08, 2011 | 2K Games Joint Task Force for Windows
Cannot open file plyr.sav
You must grant "full control" permission to the logged on user account for access to this file or to the following folder: "C:\Program Files\NovaLogic\Delta Force Task Force Dagger" if x86 or "C:\Program Files (x86)\NovaLogic\Delta Force Task Force Dagger" for a x64 system.
Jan 02, 2011 | NovaLogic Delta Force: Task Force Dagger...
Installed joint task force on vista. when the game loads the sound is good but the screen size is to large. i can only see the top left corner that fills the whole screen. so i cant see game settings to...
Change the following dots in settings.ini in the installation folder :
int FullScreenWidth=...;
int FullScreenHeight=...;
with your screen resolution
(Works on my Vista laptop)
Goog luck!
Aug 29, 2010 | 2K Games Joint Task Force for Windows
Sir I have a problem with spider man 2 game .when want to run the game an error occured Critical error negative delta time.sir please tell me how icn sokve yhis problem?
go to the .exe the app which opens the game right click and go to properties compatibility and change it ti windows98/windowsME then it will work
Jul 10, 2010 | Groove Games Combat Task Force 121 for...
Combat task force 121, Negative delta time,
Has it ever worked?
Are you running Vista?
If it has* worked,
GO TO: Start>>>>Accessories>>>>>System Tools>>>>System Restore. Do a system restore to a working date in the past.
Please, keep me updated.
Feb 23, 2009 | Groove Games Combat Task Force 121 for...
Delta force task force dagger
There is a recent update for multiplayer TFD. Can be downloaded from Novalogic at this link:
Click here to download.
-or-
http://www.novalogic.com/updates.asp
Security Update, Delta Force - Black Hawk Down, Delta Force: Task Force Dagger, Delta Force Land Warrior, and Comanche 4
This security update is to replace the existing Ibrowse.dll file, which manages some of the communication between the game and NovaWorld. The update assists in protecting communication from outside inspection, tampering, or theft. We highly encourage all users that have and use NovaWorld accounts to migrate over to the updated Ibrowse.dll. Make sure you are NOT running the game when updating.
Nov 02, 2008 | NovaLogic Delta Force: Task Force Dagger...
Graphics BV200 BizView  128MB (128 MB) PCI Graphic Card Logo
294 people viewed this question
Top Graphics Computers & Internet Experts
David
David
Vernon Taylor
dhnguyen
Are you a Graphics Computer and Internet Expert? Answer questions, earn points and help others
