Question about JBL PSW-D110 Speaker
No output from d110
I recently purchased a used d110 and am getting no output out of it. Led on front stays red. If i partially remove one of the RCAs i will get a loud hum, but no results otherwise. I have tried all inputs I have available to me with no different results. Any suggestions? The D110 I have has a shorted C6 cap also . I was told that Best buy had repair it before but he did not remember what they did. The C6 cap is NP 4.7uf @100v .Should I use aNP 10uf @100v ?and if it shorts with 100v cap is something else in the circuit that should be changed ? thanks
  • calman46 Oct 18, 2008
    would increasing the uf value help ? the original value may have been 10uf.
    Ok I put in a 4.7uf NP 100v cap and the sub now works. In another post it is mention that JBL sent a 10uf NP 100v cap to replace C6. My sub works but has a hum so I put a AC meter across the main PS caps and I'm getting 105AC across one cap the other is fine at 0v ac ,there both about 47vDC. So it would seem that filter cap(s) need replacing also ,is my diagnosis correct ? thanks
  • 19,396 Answers
You can use a cap of same or bigger voltage,
Posted on Oct 17, 2008
  • 1 more comment
  • Ginko
    Ginko Oct 17, 2008
    Try a bigger voltage cap, if the cap keep shorting then it is something else on the circuit. Probably something wrong on the power supply area, since you get an overvoltage.
  • Ginko
    Ginko Oct 18, 2008
    You can put a capacitor with bigger Voltage, you cannot use a capacitor with more capacitance (more uf ). If you put a capacitor with more uf, that will have bigger capacitance, the circuit probably wont work, or it will blow something else when the capacitor discharge. If you use more voltage the circuit will work the same, and the capacitor will be more difficult to blow, the risk doing this, is that the same problem that blew the lower V capacitor, wont blow the new one, and blow something else. For this reason is always better sticking to factory specifications.
  • Ginko
    Ginko Oct 18, 2008
    To be more precise I checked the service manual for your specific model.
    C6 in your circuit is a safety component, that means that it needs exact replacement, as when it is blowing it is saving part of the circuit from blowing.
    You must replace C6 with 4.7uf 100V 80/-20% Electrolytic redial NP, same as the original one.
    See the list of safety components at page 2 of service manual here :PSW-D112/DPS-12
    If no sound or humming noise (probably a fault in the final amp region of the board) persist, then follow testing and troubleshooting diagrams to find the rest of the faulty components.
Need help with Proliant Dual XEOn ML350 G3. Front
Sounds like the power supply has gone bad on some outputs - most likely the 3.3 volt source.
Jun 07, 2010 | HP (302203-001) Motherboard
JLB PSW-D110 Subwoofer Issues
Hummmm is from Output amplifier and you need to replace it because power supply blow it too.
Sep 09, 2008 | JBL PSW-D110 Speaker
Front Speakers Not Working
Hi, as a retired installer maybe i can suggest a better configuration. I would run your front speakers in series with your rear mids in low level. Your sound will be alot cleaner. Hppe that helps.
Aug 26, 2017 | Kenwood KDC-MP332 CD Player
My powered subwoofer has RCA inputs for four jacks. (two front, two rear) My CD head also has four RCA outputs (2 front and 2 rear). Is there some advantage to connecting all of these with patch cables, or...
the advantage is every time you split a pre-amp signal, the voltage, too, divides in half. Your signal (music) is going down the river at 2 volts say, and when it gets to the amplifier, it is split into 4 streams. The signal will be distorted and the amplifier will not work as efficiently. Use the Front AND rear RCAs so your amplifier uses the best possible signal - for the best possible results!
Also, if you are using 4 RCAs you get true stereo FL FR RR RL Instead of L and R
Dec 30, 2008 | Jl Audio 500/1 Car Audio Amplifier
Power PC G5 Dual 2.5 sudden shutdown and no reboot
In G5 always the cover should be closed properly if not it will start the fan very fast like a blower and the red leds will be on showing that the heat is over so please check that the cover is closed and locked from behind so itworks smooth and the power supply is standard or normal
u should always use genune parts with mac..
thanks
Dec 19, 2008 | Apple Power Mac G5 Desktop
How do I connect a mac audio output to a yamaha sound projector?
NO!!! get a 3.5 male TRS to stereo RCAs to either the Aux input on the amp or the audio portion of the front A/V Aux. the audio jacks will be red and white.
Dec 04, 2008 | Yamaha Digital Sound Projector Home...
Hi i am matt
If the protection LED lights only after the remote voltage is applied (head unit is switched on), the amplifier likely has shorted output transistors. If the protection LED remains lit without remote voltage applied, the amp may have other problems.
Does the protection LED light with no speaker wires connected to the amp and no RCAs plugged into the amp?
Jun 22, 2008 | Car Audio & Video
JBL d110 /w no sound output
There is a standby indication that activates after 10-15 minutes without any input signal. I suspect that might be what the red light is telling you - no signal.
Loud hum from a loosened cable is normal as hum usually means there's an ungrounded connection somewhere acting as an antenna and the amp is doing its job to amplify what it thinks is a signal, in this case 60hz stray ac current is being sensed nearby. It's a good sign that you get hum from the sub because that means the amp is alive.
Avoid manipulating cable connections with the Sub or Receiver turned on as you could introduce a static spike that could harm any connected equipment.
Are you certain a bass signal is making it into the sub? The complexities of modern AV receivers vary in how you configure them to direct LFE to a sub. Bone up on that end of the chain.
Or, just hang a CD player on the Inputs of the sub and play something with a reassonable amount of Low Frequencies.
>>>> Be advised that this way of testing has NO VOLUME CONTROL because amps without volume controls always operate at maximum gain, relying on your external controls to attentuate it (hence, the loud hum from a loose cable); so choose a track that eases into the loud parts with some quiet parts up front and BE READY TO PAUSE THE PROGRAM AT ANY SIGNS OF STRESS. <<<<
A living sub will produce only muffled rumble in the absence of other speakers producing the higher frequencies which carry the intelligence of the signal. If that works, back to the receiver for settings. If not... sigh.
For hum problems, even those you cause yourself:
Disconnect all inputs to see if that helps. If it goes away start with the signal cables and add in things until it comes back.
Sometimes the reversing the orientation of the AC plug can help with hum. Or it could be something like a loose or high resistance connection internal to the sub. Good luck.
Jun 17, 2008 | JBL PSW-D110 Speaker
No output from d110
Hi Chadwik
The fact that you do get hum when you partially remove one of the RCA's would tend to say that the output stages are working ok. Is the hum "solid" and bassy, or distorted?
There are a few issues that these subs have had, mostly to do with capacitors in the power supply failing. If you are up to it, I can talk you through repairs to it.
regards
robotek
Jun 16, 2008 | JBL PSW-D110 Speaker
JBL PSW-D110 Speaker Logo
146 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
