Question about Konica Minolta DiMAGE A200 Digital Camera
No Power After flying on a recent trip and having my camera x-rayed it acted strange. When I turned it on it asked me on screen if I would like to update the software. I selected the no option, then NO IMAGE appeared on the screen. I turned it off and back on again with the same results, update question then no image. I did this again and answered yes to the update question and it began the updating process as indicated on the screen by a bar but never made it past 50%. This went on for 5 minutes and I could not stop the update by pushing the on/off button so I removed the battery. BIG mistake. I have not been able to turn the camera on since then. Do I need to do a software reboot or something else? Help.
  • meandering Oct 28, 2008
    The updating process started when I initially turned the camera on.
  • 10,594 Answers
Your camera software got corrupted and possibly digital process board need to be replaced.
Sony Service centers are providing services for Konica Minolta camera as its announce at Konica-Minolta website.
Posted on Oct 28, 2008
  • Konica Minolta Master
  • 1,879 Answers
Need to restore power before you can continue troubleshooting. charge battery or use power adapter.
    Novelist:
    Scholar:
  • 149 Answers
It might also be a battery issue. do you have a back up battery you might be able to try? I had an issue like that with my Nikon since it was a certain recalls battery manufacturing date. I purchased a new one and also a new OEM one to have two on hand. It turned back on, and I gave it a firm ware upgrade by connecting onto the website via usb hub.
Let me know how that works out for you. Thank you for your time and I'm eager to hear back on how things work out for you.
Also, some film camera's do that not typically digital. It messes with the speed settings some times.
Here is also a blurb found on dpreviews.com:
X-ray scanners digital film safe The International Imaging Industry Association (i3a) has issued a press release which details tests it carried out in conjunction with SanDisk and the US Transportation Security Administration (TSA) to discover the effect of airport X-ray scanners on digital film (flash storage). The results showed that none of these such scanners, nor walk-through or hand-held metal detectors had any effect on the content of flash storage. (17:00 GMT)
    Sergeant:
    Champion:
  • 298 Answers
Remove the battery 5 seconds or so. replace the battery press and hold the power button for 10 seconds or so, this should reboot the device, then connect it to your pc,mac....and try the update agian.
  • 6,487 Answers
Try first removing the battery from the camera for 12 hours then before you put the battery back in make sure its fully charge or better if you can try a new battery for this.Then after that connect the camera to your computer and if you can download the software for the camera that will be good and run it to your computer..........
    Genius:
  • 2,035 Answers
You camera software is corrupted due and may need to update firmware of your camera,please click on this link and then update your camera firm ware:
http://ca.konicaminolta.com/support/americas/digital_cameras/dimage-a/dimage-a200/software_drivers/firmware/ver101_win.html
Good luck...
    Scholar:
  • 155 Answers
Taking it to the repair shop is much advisable as the device is shifting its problem from 1 to another.such as first it was software update problem.then running properly till 50% then just going off after and not comming ON. it could be internal circuit error in the device.as the repair shop will have all the necessary parts to replace and check for what and where the exact problem lies.
thanks.
    Guru:
  • 859 Answers
You could try this but its not guaranteed. Download the latest firmware to your camera. Have it ready.
Connect your camera to your PC and power the camera on. Now run the firmware update you've downloaded. When there are accompanying instructions with the download follow those carefully to apply the update.
However, there may be a good chance you've wiped out the factory installed Read Only Memory. This ROM is critical for the camera to bootup and perhaps have a firmware update applied. In the long run you could take it to a professionals camera store. You can easily find them in the Yellow Pages or you already know of one. These companies are normally authorized sellers and may be able to get your camera to bootup again.
Best of Luck with this one, its tough to be in your position so try not to over react Things happen and we call them mistakes and/or accidents. This can be resolved but you won't be able to use your camera for awhile unless connecting to your PC and apply the firmware update works for you.
In any case, would you keep us/me informed of your results.
Best of regards,
Worldvet
  • Glenn Rogers
    Glenn Rogers Oct 28, 2008
    Let us know if you try something and you get different results.
    WV
  • Glenn Rogers
    You need a software reboot.
  • 19,396 Answers
If you interrupt the update processor, the camera will be irreparably damaged, you need to take it to a repair shop.
Posted on Oct 17, 2008
  • Ginko
    Ginko Oct 17, 2008
    You need top send the camera back to factory, the eeprom containing the firmware must be re-flashed.
    Try restarting the update process, if you succeed by chance in completing the update, then the camera will be fine, if not , you need to send it for repair, in this case check here for contact: KONICA MINOLTA Global
    Genius:
  • 3,422 Answers
first do a reset by removing the batteries and the mem. card for 5 min and then installing the batteries back again.Make sure you do no insert the mem. card only the battery and then hold the power button for 30 sec.Let me know the result.
  • Priya darshan Oct 17, 2008
    I want you to polish the terminals of you camera with a soft cloth If the
    terminals are covered with oil or dust this may cause poor contact and
    the battery may not be able to supply the power to the camera.
    One more thing you can do is once try switching over to 2500 mAh Nickel
    Metal Hydride rechargeable batteries. you will see a difference.Digital
    cameras with zoom lens need more power than what can be supplied by
    ordinary batteries..
    IF you still face the problem then it is circuit board or the inner element not functioning properly and you will need to get this repaired.
My Marantz BD8002 (year 2008) after a while automatically turns off. Sometimes plays for hours and sometimes only a few minutes. Any idea what the reason for such behavior? I would appreciate for any...
I have a blu-ray player that was acting strangely - turning off unexpectedly - I finally noticed that it happened often when fire trucks were nearby - and tracked down two the lights triggering the IR remote detector.
May 25, 2014 | Televison & Video
Films
See the second item here: http://www.filmbodies.com/cameras/camera-faq/
If you're flying in the US, ask for hand inspection. If you're in another country, ask for hand inspection anyway: it can't hurt to ask.
Jun 24, 2013 | FUJIFILM Photography
I want to ask a friend to bring a few packs of Instax film from the US for me and I want to know how the x ray machines might affect the undeveloped film. My friend would bring them here to me in Mexico...
Films 800 and higher (800, 1600, 3200 iso), should not go thru the x-ray. I recently took a lot of films on holidays in the US, the security staff were very helpful and understanding. I put my high iso films and instax in a clear ziplock bag, and asked for hand inspection, they do a swab to check for whatever they are screening for. The x-ray machine has a sign that says films under 800 are OK in the machine, that means 400, 200, 100 etc. not 800.
There is a risk if you put it in the checked baggage, as sometimes this is x-rayed, and that's supposed to be even stronger x-ray.
So, take your film in a clear ziplock to the security people and ask for hand inspection due to 800 iso. Couple of times I was asked extra questions, they asked to see the camera, I explained it's big in Japan. Another time they asked me to open the package, opening the cardboard package, and even opening the silver wrapper is OK because the film is still safe inside it's black plastic cartridge.
May 23, 2010 | FUJIFILM Instax 200 Instant Film Camera +...
Samsung blu ray player bp 1500 is acting strange
Disc loading mechanism fault. Not loads properly. Might be of the fault of any broken gear wheel, of a loose loading belt or so. Contact any service technician to get this set repaired.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Mar 29, 2017 | Samsung Televison & Video
Strange noise
Well sounds like belt ore fly wheel the bearing go out on them
Bearing in the fly wheels go bad and make hell lot racket i had guy with honda this happend and i told him and that what it was.
Jul 20, 2009 | 2005 Ford Focus
Flat screen monitor functioning strangely
Sounds like there maybe bad caps on the power board in the LCD. Try a different monitor on your computer and if the known working monitor comes on with the computer and behaves properly then you know its a problem with your original monitor. If the known working monitor acts strange as well then you know its a problem with the video card. Let me know what happens.
Jun 11, 2009 | E-Machines eMachines Desktop PC
Black screen and won't take pictures.
there has been a recall on certain models of the powershot series. check their website to find out if yours is on the list.
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2112&fcategoryid=221&modelid=9828
Dec 30, 2008 | Canon PowerShot A75 Digital Camera
Camera acting strange.
i have the same problem. wat did u end up doing with it?
Nov 04, 2007 | Olympus FE-210 Digital Camera
Konica Minolta DiMAGE A200 Digital Camera Logo
202 people viewed this question
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Willem.
Willem.
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
