Question about HP Compaq Presario R4000 Notebook
Monitor problem I have a one inch vertical off color stripe running down the screen. It apears to be missing one of the color groups. About i/3 of the way soen the stripe it is missing all color. I have updage the video drivers. What to try next??? Thanks
  • 64 Answers
My Friend, This one rings like a hardware malfunction with lcd. Try contacting contacting compaq/Hp
Posted on Jun 06, 2006
My hp vs 15 displays vertical color stripes that alternate different colors wether its hooked up tp computer or not what is wrong, is it junk
It may sound strange but be absolutely sure the cable is plugged into the monitor. Adapter on the computer. The serial adapter on the back looks just like video. Video actually has a faintly noticeable monitor icon rigtht next to it. Plugging into a serial can eventually blow out your monitor. Also, a.badcable can do the same thing. And if you have messed up the monitor's settings you will see the same
Apr 13, 2012 | HP vs15 15"LCD Flat Panel Monitor
LG Flatron L1930B lcd monitor - 3 vert. stripes, center one dead
sounds like the pixel controllers have gone bad or one or more of the color (RGB, RED, GREEN, BLUE) controllers have gone out. this is quite common in lcd monitors/tvs and is usually caused by pressure on the edges of the screen (you grabbed it too tightly when moving the monitor) or just faulty controllers. they are expected to eventually go bad, ask LG for yourself, they will tell you the same thing. If you just bought it, that can be considered a mfr defect that they will replace, IF IT IS IN WARRANTY!!!!! Unfort. there is no fix due to seal that placed on the actual lcd panel inside the plastic casing. Youd spend more money trying to find the part and install it than just buying a new monitor. hate to say it but im an avid gamer and have gone through about 4 lcd monitors in tha past 3 years due to everyday use
Sep 18, 2009 | LG L1930B 19" LCD Monitor
Right half of screen is Black with a White vertical stripe
Yeah, I have this exact same problem, except my mom slammed my laptop shut in frustration around half an hour ago, so that's why it's like this. The right half of my screen is black with two colorful stripes (mostly white), but the left half is visible. I've researched a bit and found out that this is because the LCD in your monitor has burnt out, and since you don't have a monitor to attach, the only thing you can do is to go to where you bought the laptop and either get it fixed for free or return it for a brand new one (if your warranty still stands). If not, you might as well get a new laptop. I think my warranty has expired, so I'll get a new laptop, hopefully.
Hope this helps!
~Sam.
Jun 08, 2009 | HP Compaq FP 7317 17" Flat Panel LCD...
Dark vertical stripe on monitor
You screen "LCD" is broken , need new lcd panel. Very expensive
Feb 01, 2009 | Samsung T220HD LCD Monitor
Display comes on with stripes of color then turns white
Try Booting To An External Monitor If able to...
If Display is Normal In It, Your LCD Display Panel Is Bad... The Circuit Board Attached to the Display Panel has Gone Bad...
But If You Hook It Up To External Monitor and It Doesnt Work...
Your Video Card/Chip is bad
Nov 17, 2008 | Toshiba Satellite A105 Notebook
IMAC lcd vertical colored stripes
First, plun a external monitor and toggle the screen with ALT+F5. This will determine if you have a hardware or software problem (drivers, configuration, etc).
If the image in the external screen is correct then the problem is in the LCD panel or its cabling.
Here you can get the replacement LCD panel and change it yourself.
http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ObjectPath=/Shops/demo132390/Products/%22Pantallas%20portatil%22
May 22, 2008 | Apple iMac Flat Panel Fan (p/n 922-4677)
Dark Vertical Stripe on Right Edge of Screen
I experienced the same approx. 1/2" vertical stripe on a Viewsonic vx1945 and ATI Radeon x1050 video adapter on Vista Business SP1, but the stripe appeared along the left edge of the screen, instead of right edge. I then temporarily decreased the monitor resolution, and the stripe went away. I then increased the monitor resolution back to its original setting, and the stripe did not re-appear. So, that was the 'fix' in my situation, hope this helps.
Dec 11, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Black Out
Hi Detrix, Check with www.lcdrepair.net if you want a repair. Something is wrong with your LCD controller and or GUI interface circuit or the circuit supplying power to it. If your technically endowed, you may want to open the monitor case and clean the dust and lint from around the circuits using a Small paint brush to sweep away any built up dust. These circuits take the Signal from the computer and controls the 2.5 million pixels on the LCD screen. Dsut can cause major problems with handling all that data. Give it a shot, what do you have to loose, its not dangerous if the monitor is unplugged.
Oct 09, 2007 | Samsung SyncMaster 193P 19" LCD Monitor
Computers & Internet Logo
89 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
