Question about Envision EN-7100e 17" Flat Panel LCD Monitor
Color I had unplugged my computer and monitor and when I plugged them back in the colors on my screen are not right anymore I have tried to ajust them but can seem to get even close to where it should be, what would make the color go bad.
    Scholar:
  • 45 Answers
The most likely problem is that a pin on th cable is either bent and missing a color or the cable can be bad. If you use VGA a pin can bend and cause a color disappear. DVI cables can sometimes be the same issue.
Most likely if the cable is not in correctly it could also be the cause of the problem. Check the pins and make sure they are straight up correctly and if they are let me know what displays on the monitor and maybe i can help you out more. I specialize on monitor issues. :)
Posted on Oct 17, 2008
Resolution is horrible and will not ajust
Try this... unplug the power to the monitor. While unplugged, press and hold the power button for 30 seconds. Plug back in and test.
Apr 13, 2011 | Westinghouse Electric L2210NW Monitor
Green screen
There should be a reset in the menu on the monitor where you would change color, vertica,l etc... it will say reset or reset to factory.....if not try shutting down the computer completely and unplug monitor and pc for a couple minutes then plug back into electrical connection and restart
Jul 15, 2010 | Westinghouse L2046NV Monitor
Montior screen is half shaded and half bright
Do this to check if your monitor is in working state or not...!
Step 1:- Turn on your computer.
Step 2:- Unplug the Video Cable of your monitor which is connected with the computer.
( Video cable:- Cable going from the back of your monitor to the back of your tower. It has a plug with two screws on the plug ends, which you can unscrew to unplug it. Thats how it looks like. Some times it is in grey in color some times in blue.)
Step 3:- Now check on your monitor. If the display says " No Input Signal " :- your monitor is fine. Some thing wrong with the computer graphics.
If there is not display and the monitor light is blinking or solid the monitor has gone bad.
( Note :- Remember when you unplug the video cable do not unplug the power cable of the monitor. )
Let me know if it helps.
May 18, 2010 | Computers & Internet
Monitor screen begins as computer is booting up and then screen goes black. Message says there is no signal.
If the power light dims or changes color after the no signal message comes up, that means the monitor went to sleep.
While the monitor is plugged in and on and the computer is also on, Try unplugging the VGA cable from the monitor. wait 30 seconds and then plug it back in o see if the power button light comes back to normal color and the screen flashes on.
If not, then the monitor is not getting a signal from the computer.
If using a desktop computer,Try a different cord or try the monitor on another computer.
If using a laptop, you need to activate the laptop to use an external monitor. That can be done through the display settings, OR, most laptops have a shortcut key feature which usually involves pushing the Fn key and one of the F keys at the same time. The F key may say CRT/lcd or have a picture of a monitor and a screen.
If the power light does light back up and still no picture, There may be an internal issue on the monitor
Nov 17, 2009 | ViewSonic VG2230WM LCD Monitor
Cant ajust picture to fill out screen, 3 inches
try this restore to defualt values monitor and cpu
Jul 10, 2009 | Acer Computers & Internet
SVA 17" flat monitor screen color is pink.
It's not a "windows" problem. At the bottom of your monitor there should be a 'menu' button. Push the button and use the up and down, right and left arrows on your keyboard to scroll to color. Get the "red" color and adjust it down. You can also scroll through to 'contrast' and adjust that. You don't need to pay a bunch of bucks to have this fixed.
Apr 10, 2009 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
Blue tint on computer display monitor
Try
1. Unplugging the video cord from the back of the computer (and screen if it comes off) and plugging it back in. Sometimes it can become loose and cause a screen to have a abnormal color contrast
2. Updating the drivers to your card
3. Trying a different monitor on the computer. Mind you, if you plug in a differant monitor and the color stays the same. Check the videocards pins on the back of the card. I dont know if you gave all the info on how it became like this, so maybe it got undone and plugged back in forcably and one of them got bent? I
Also if the pigment goes away. Plug the normal one back in and if its gone, great!, if its back. Try the OSD settings on that monitor. Still no luck. The monitor is junk.
Hope that helps
Nov 30, 2008 | ViewSonic Computers & Internet
Mag innovision LT716s monitor
When I turn on my computer the monitor takes a long time to warm up and colors change and vertical lines flash across the screen from right to left before the screen becomes normal again. Now the power light even goes out upon turning on my computer and I have to unplug the video cord and plug it back in to start the screen back up which even takes longer.
Feb 19, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Monitor Switched Itself Off, Won't Turn Back On
With the computer on shine a flashlight on the screen where the Windows Start button would normally be. If you can faintly see it then your backlight has malfunctioned. Check your warrantee to see if you?re still covered. If not then it is repairable at most TV or computer repair shops. If you can?t see anything with the flashlight try connecting the monitor to another working PC. If the problem follows the monitor: -Check the monitor for bent or corroded pins. -Again see if you warrantee is still active or take it to a repair shop. Let us know if you have any other questions and please don?t forget to rate this post.
Mar 22, 2007 | E-Machines e15t 15" Flat Panel LCD Monitor
Envision EN-7100e 17" Flat Panel LCD Monitor Logo
Top Envision Computers & Internet Experts
Steve
Martin Murray
Dimitar Todorov
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
