Question about JVC KD-G230 CD Player
LIGHTER FOR MY SATURN
I have a 1994 saturn sSL1 and my lighter quit working I checked the fuses they were fine so I purchased a lighter they didnt have the exact one so they said I have to rewire I looked to see were it wascut and wired at I was going to look and replace it how it was on but its the original were do I cut and replace the wire at ????? THANK YOU PATSY
    Sergeant:
  • 227 Answers
Probably would have been a good idea to purchase a LED 12vdc tester while at the auto parts store. If the original holder is in the vehicle and the fuse was checked. The next thing you need to do is take the 12vdc tester and touch one lead to the side of the holder and look inside and see a center contact at the bottom of the holder, touch the other lead from the tester to that contact. If your light turns on then you actually have power there. If not the fuse to the lighter is out. You can not visually check a fuse, they must be tested. If you have power try to plug in another lighter. If you have to change or add a new holder the center wire is power and the ring or frame is negative. Depending where the lighter is located I have found coins, gum wrappers etc. in the holder you may also want to make sure nothing is in the holder.
Posted on Jan 05, 2009
How do I find out why my lighter is not working in my 1999 saturn sl1? where are the wires hooked up to it?
You can check for voltage at the lighter socket with volt meter. Have you tried a new lighter element ,they do go bad.
Jan 19, 2015 | Saturn Cars & Trucks
1994 Saturn lighter and interior overhead light?
Fuse 13 is for the lighter and fuse 18 is for the dome lamp.
May 01, 2014 | Cars & Trucks
Penny dropped into the cigarette lighter of my 2008 saturn astra. I got the penny out, but the cigarette lighter doesn't work
hi,
there must have been a weak connection somewhere in the line.
use a volt meter to trace from the lighter to the fuse box.
I have also seen the wire connection go bad during a short in the back of the fuse box itself where the wire goes in.
follow the 12 volts and you will find your problem.
chris...
Sep 26, 2012 | 2008 Saturn Astra XE
I need a free fuse box manual or diagram for my 1994 Saturn SL2 car. My Saturn SL2's cigarette lighter has gone out and I need to see if its just the fuse but a fuse for cigarette lighter is not labeled.
the fuse panel is next to the passenger's left knee. the cover is held on by velcro and the lay out of the fuses is on the back side of the cover. it is also in the owner's manual in the glove box
Nov 01, 2010 | Saturn SL2 Cars & Trucks
I have a 2001 saturn sl 200 & the ciggarette lighter in it doesnt work. it didnt come with a manual or anything & my dad wont help me. so if it could be a fuse what fuse would it be & where...
i could very well be a fuse. that would be the first check. it would be in the fuse junction block inside the car. usually the lighter and the radio are on the same fuse but may be on the accessory fuse. but if you look on the diagram may possibly be marked cig lighter. if its not a fuse and you are getting juice to the outlet it may just be a faulty lighter
Aug 07, 2010 | 2001 Saturn SL
1994 Saturn SL1 fuse box diagram what is #16?? it keeps blowing.
Your owners manual should be able to help you there; however, check you cigarette lighter and anything else that doesn't seem to be working at the time of this event. If the lighter is at fault, it will need to be replaced.
Mar 01, 2010 | 1993 Saturn SL1
Cigarette lighter not working on 1994 saturn
Check your fuse inside the fuse compartment .It may be burned . Replace it .
Also check for loose connections
Dec 11, 2009 | 1994 Saturn Sc
96 saturn sl1
It may not be a fuse issue. You could have a bad socket connection. Pull the wire from the back of the lighter socket to see if you have power there. If you do, then the socket is bad.
Jul 30, 2009 | 1992 Saturn SL1
Saturn / fuse for lighter
Fuse is in the passenger side kick panel fuse box. Look at the inside of the kick panel for exact location
Take a look there
Mar 15, 2009 | 1992 Saturn SL1
JVC KD-G230 CD Player Logo
49 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
