Creative Labs Nomad Jukebox Zen Xtra MP3 Player
Problem for Creative Labs Nomad Jukebox Zen Xtra MP3 Player
Firmware problem
By gonzo83 on Jun 04, 2006
I turn on player, it says rebuilding library. A minute later it says FIRMWARE PROBLEM and it shuts off. I can't play any songs. Can it be fixed, what should I do?
Same Problem
Mar 31, 2009
-   my problem is :
when i switch on my zen xtra mp3 player then it comes a site .
there it says : FIRMWARE PROBLEM
Clean up
Format all
reload wirmware
Please help me !
my english isn´t verry good because i speak german !-   klara859
Mar 23, 2009
-   problem fireware
-   Guest
Aug 23, 2008
-   De Zen V plus gaf opeens firmware problem aan en mijn computer herkend het apparaat niet meer, dus de download van de creative site heeft ook geen zin.
Hoe krijg ik het apparaat weer aan de praat?-   Guest
Jun 18, 2008
-   i have d same problem as u do-   ngkarthika
Jun 11, 2008
-   I have a similar problem. I turned on my Zen V plus today and it gave me the "firmware problem". When I tried to turn off my ZEn, it wouldn't. My computer does not detect my Zen at all. What do I do??? -   Guest
Best Solution
posted on Jun 03, 2007
Very Helpful)
ScooterSES
Rank: Apprentice
Rating: 100%, 6 votes
Other notes...
For this to work, you must have windows media player 10 installed. For me, the first time I tried this I had update from WMP 9 directly to WMP 11, so when I uninstalled wmp 11 it rolled back to wmp 9. If this is the case for you, reinstall WMP 10.
Also, you need to use the newest driver from creative. It is version 2.01.00.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Feb 15, 2007
Helpful)
walkertron
Rank: Apprentice
Rating: 83%, 28 votes
To Fix any problems with broken firmware form attempted "playsforsure" firmware updates etc where your pc finds it as a 20mb drive and it sits in recovery mode and does bugger all:
(fix courtesty of cinderlee in creative forums)
1. Uninstall all creative software & drivers
2. Uninstall Media Player 11 and Media Player 11 runtime (will require a reboot for each thing). This is done by going to add/remove programs and uninstalling (this will put your pc back to wmp10).
3. Re-install the Zen Driver from the creative website and reboot
4, Plug Zen in.
5, Make sure you have the firmware update ready, run it but don't click the language bit yet), leave the mouse hovering over your language selection.
6. On the Zen- select "reload OS"
7. As soon as it flashes up "reload new firmware now via USB" click the language button
8. Tada, now the pc should find it and allow you to re-load the firmware. (it may take a few attempts)
9. Once complete, click close and restart the pc. Everything should now be fine.
10. once you are happy you can re-install WMP11 and it will work fine.
Cheers!
Was this helpful?
Yes
No
Solution #3
posted on Jun 05, 2006
Somewhat Helpful)
soldierruel
Rank: Wiz
Rating: 75%, 872 votes
Fully charge your battery. And if that doesnt work reinstall its firmware.
Was this helpful?
Yes
No
Solution #4
posted on Nov 10, 2006
Somewhat Helpful)
snake20
Rank: Apprentice
Rating: 76%, 37 votes
snake20 indicated that his solution for
Zen Touch MP3 Player Problem
is valid for all MP3 and Digital...
I have this exact problem, can you be a little more specific please? I just reinstalled the software (the cd) but still my player reads firmware error and when i go into Zen media explorer in says 'device is not connected. Please connect your Zen to the computer'. When it is connected.... PLease help
Was this helpful?
Yes
No
Solution #5
posted on Jan 29, 2007
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I had that problem.. but found a driver for a newer DM-av10 made by a nother company.. Same hardware, 90% same software.. a few extra functions.. and bla bla bla ... Fixed.. Works like a charm...
Solution #6
posted on Nov 13, 2006
Not Helpful)
MFINCA
Rank: Apprentice
Rating: 55%, 1 votes
I had this same problem. Just yesterday I reloaded the firmware and just like that it was cured.A copy of the frimware is available on Creative's website. You will also need to have Creative's software installed on your computer.
I do note that the original problem I was fixing was a "media failure". That turned out to be nothing more than the drive had come partially out of its plug. Turns out that some problems from dropping a unit aren't a bad drive.
After fixing the drive problem I got the firmware error.
Overall it was a good day.
Was this helpful?
Yes
No
Solution #7
posted on Dec 11, 2006
Very Helpful)
colmac
Rank: Apprentice
Rating: 100%, 2 votes
Go to the http://www.creative.com and navigate to the zen product under downloads. You can then Down load a new firmware for your zen. you should do this from time to time anyway. They Add new features to the zen and by upgrading the firmware you get the new features or bug fixes.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #8
posted on Jun 11, 2009
Not Rated)
JUS FOUND
Rank: Apprentice
Rating: 0%, 0 votes
Was this helpful?
Yes
No
Solution #9
posted on Sep 10, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
thnx finally some intresthing information
Solution #10
posted on Jul 13, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Boot your player in recovery mode by taking out the battery, holding the power button to the "turn on" position, and reinserting the battery. Hold the power slider until recovery mode is enabled. Once in recovery mode, click "reload firmware." Download new firmware from the Creative website, and reinstall it through your USB connection.
Solution #11
posted on Apr 02, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
My mp3 says it's low battery.The next thing it shuts off.Should I plug it to my computer so it should work?Should it work without a charger?
Solution #12
posted on Nov 17, 2006
Not Rated)
suppasit
Rank: Apprentice
Rating: 0%, 0 votes
suppa... indicated that his solution for
FM 6603 MP3 Player Problem
is valid for all Creative Labs MP3...
My 6602 MP3 player 256Mbs with FM was deads !! Need the Full (compatible)firmware Ver.3.1.15 cause i have only the DUMPS.bin (incomplete) firmware.
Was this helpful?
Yes
No
Popular Solutions for Creative Labs Nomad Jukebox
Questions and Unsolved Problems for Creative Labs Nomad Jukebox
Do you recommend Creative Labs Nomad Jukebox Zen Xtra MP3 Player?
Answer
Answer
Can't download the updated firmware to my MP3. So unable to transfer tracks from Napster. When... (More)
Answer
i lost my intalation disc for my noman zen xtra 30 gb what can i do
Answer
First I kept getting message that said 'firmware problem'. Then I got it into 'rescue mode' and it... (More)
Answer
Will not boot up. The initial screen comes up, then the unit cuts off after the EAX screen appears.... (More)
13 Other Users Have The Same Problem - Continued
Comment by Guest, posted on May 08, 2008
it says firmware problem cant get it off
Comment by tyrahc, posted on Mar 17, 2008
I can't move off this clean up page @ all.
Comment by gucci123, posted on Feb 12, 2008
same thing happened to me as it did to gonzo83
Comment by kila2289, posted on Dec 19, 2007
I just got the new zen and two days i get this firmware screen that work go away, and my pc wont see that my zen is connected. I swear I should have never swicth over the zen from ipod.
Comment by Guest, posted on Dec 18, 2007
still i see no fix for this problem it would have been better if i bought a ipod because this is garbage.
Comment by carmie21, posted on Dec 12, 2007
I plugged in my mp3 player and it said rebuilding library and then a minute later it said firmware problem and has been frozen on that screen for almost 10 min. .. what does that mean and what do I do?
Comment by oybek, posted on Dec 12, 2007
my player is broke when i trun on my player it write firmware problem. Please help me to the fix it
Comment by ssarig, posted on Dec 01, 2007
1 after deleting songs from the library i started the player
2 the player started to rebuild the library
3 after 2 minutes i got the "firmware problem" on the screen and no button is functioning
4. i reset at the back of the player and it happened all over again
5/ what should i do
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Creative Labs Nomad Jukebox...:
Top MP3 and Digital Med... Experts
Rank: Guru Guru
Solutions: 441
Experience: From previous experience, research, schooling, and studying the work.
Ask Me
Find more MP3 and Digital Med... Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
