Question about Numark Audio Players & Recorders
Change a Fuse on Numark Axis 9 Professional CD Player
While DJing, the CD turntable fizzed and lost power. I changed the power cord and it still did not turn on. Is it the fuse? Is there something else to check?
Thanks
Chris
SOURCE: Parts for numark axis 9
Yes You can get them from Instrumentalparts.com aka www.numarkparts.com
Posted on Sep 07, 2007
SOURCE: problem with numark axis 9!!
Hi, I’m from Yucatan, Mexico. I’ve always used Numark cd players, I have two Axis8 and two Axis9, and one day I had the same problem with an Axis9. I know a little bit about electronic so I opened the machine and began check it, I took the decision to change and electronic part, I took it from the another Axis9 which was working perfectly, this part is the memory, buffer, effects and it controls all the front panel, jog, play, pitch, etc. I discovered the problem, this electronic circuit part was wrong, I thought that it was impossible to repair so I began to investigate. I visited Numark web site, they sell any electronic part you need, I bought a new one from Numark Company for 200 dollars, and this is the most expensive. They sell parts for Dual Players, Axis, CDX, Mixers, etc. If I not wrong you need this part, now it costs 174 dollars: TWPC01C04603 PCB, Effects/Buffer - Axis 9 (Red) | I got it and my Axis9 works like new again!!! Good luck with yours!
Posted on Jan 20, 2009
SOURCE: jog wheel doesnt speed up or slow down music in
Get OLD KEVIN 000 THE WIZ to answer it for you
THANKS MUCH
Bufford4
Posted on Apr 03, 2009
  • 17 Answers
SOURCE: I have a 'Numark Axis 9' DJ standard CD player.
You will most likely need to replace the CD drive. I believe the OEM part is CM-H90. Only 8 screws to complete this task.
Posted on May 05, 2010
SOURCE: my numark axis 9 does not read cds, wot do i do
not reading my cd's it just keep saying no disc''
Posted on Dec 23, 2010
Numark cdn25 dual cd player when open close the lcd screen gets dim
Are you using the original factory power supply? That sounds like it isn't strong enough. The mA is what I mean.
Feb 28, 2013 | Numark CDn25 Professional DJ CD Player
Want to connect my nu mark axis 9 to my computer by using virtual dj
Hi gregory_fils,
Please read the manual which came with your nu mark axis 9 to see if it is compatible with your computer if so, there should be instructions in the manual.
i hope this helps.
Mar 27, 2011 | Nu Mark Numark Axis9 Table Top CD Player...
Numark Axis 9's. . Problematic. Ahhhh!!!
Sorry, this isn't a solution but I just wanted to mention that I just got an Axis 9 and it is not playing burned CDs either. And I see another problem reported on this site specifically called "my axis 9 wont play burnt cds". What in the heck, Numark? Are all the Axis 9's this way?
Jan 18, 2010 | Nu Mark AXIS 9
My axis 9 wont play burnt cds
I'm having the same problem with the Axis 9 I just purchased on eBay. And so is the person who posted "Numark Axis 9's. . Problematic. Ahhhh!!!" Seems ridiculous that this would be so common. I definitely don't want to re-burn 100's of CDs just to use this CD player.
Nov 08, 2009 | Nu Mark AXIS 9
Numark Axis 9's wont turn on
1. Check for internal fuse.
2. Check the power transformer.
3. Check the rest of the power supply.
Aug 11, 2009 | Audio Players & Recorders
How come my axis 9 cd players pitch control moves on its own?
i take it u know to press key when changing the tempo? if u press key it changes the tempo but keeps the pitch the same. i keep that on all the time. if i want to change the pick i hold key and press either + or -
Mar 22, 2009 | Nu Mark Numark Axis9 Table Top CD Player...
Problem with numark axis 9!!
Jan 04, 2008 | Nu Mark AXIS 9
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
