Question about Premiere Ranges P36S328BP Stainless Steel Gas Kitchen Range
Premier P36S328BP: Brand New
I haven't yet installed the range, but I can see that the oven door does not close quite properly. In fact on one side, you can easily slip a few sheets of paper between door and gasket when the door is 'closed'. Door does not appear warped or damaged, so I am assuming this a a hinge adjustment, but I don't know how to do this.
  • 641 Answers
To my opinion, the gap you have between door and gasket should not effect ranger's performance. You will have an access to the hinge by opening ranger's side panel. If I understand well,it's a new ranger.If so,in case you are insist to fix it, just call for Premiere's service for it. Good luck !!
Posted on Jun 05, 2006
Oven door won't close all the way
Check to make sure the latch isn't bent - see if it lines up with the hole in the door designed for it. Also make sure the door hinges are properly installed and settled all the way.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Aug 07, 2014 | Kenmore 95002 / 95004 Electric Kitchen...
Premier free-standing gas range, 20", how much clearance from wall?
If you are seeing the bubbled paint on wall when you open the oven door, it is more than likely heat loss past the door gaskets. They are easy to install clip on gaskets
Feb 05, 2013 | Premier Kitchen Ranges
Ge profile range door wont close
was the door removed during delivery? Hinges not being fully seated can cause this. also check to see if the lock is striking the door liner, it should line up with a slot in the inner surface of the door and not touch anything unless the oven is in self-clean
Sep 01, 2009 | GE Kitchen Ranges
Oven door does not close properly
replacing hinges on this oven. Take a look.
Dec 14, 2008 | Hotpoint RB787 Electric Kitchen Range
Oven door just barely closes- light stays on
put a tea towel on both sides of the door [folded] down by the hinges then close door. gently push the door close try a few times with a little pressure.
Nov 12, 2007 | Kenmore 96422 / 96424 / 96429 Electric...
Premier Pro•Series 36" Model P36S318BP
Sounds like you have shorted out the ignitor module and you may need to replace it. Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into. Hope this helps.
Sep 17, 2007 | Premiere Ranges P36S328BP Stainless Steel...
Premiere Ranges P36S328BP Stainless Steel Gas Kitchen Range Logo
400 people viewed this question
Top Premier Kitchen Ranges Experts
Paul Carew
ray gallant
tmaree
tmaree
Are you a Premier Kitchen Range Expert? Answer questions, earn points and help others
