Question about Cameras
CANON POWERSHOT A570 - CAMERA WILL NOT TURN ON - REPLACED BATTERIES - JUST STOPPED WORKING - BOUGHT 9 MONTHS AGO
  • Anonymous Feb 02, 2009
    My camera is not under warranty and it does not turn on. Any help will be appreciated.
  • Cameras Master
  • 4,738 Answers
It should still be under warranty. Call 1-800-OK-CANON to resolve this.
Posted on Oct 19, 2008
My canon powershot a495 has a problem. it always shows low battery and turns off. i have changed to new batteries three times but the same problem. i bought 3 months ago. help please thanks
my canon powershot a495 has a problem.
Apr 18, 2011 | Canon PowerShot A495 Digital Camera
My Canon PowerShot A570 IS won't turn on. I put new batteries in and checked the memory card. What else can I do?
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
May 19, 2010 | Canon PowerShot A570 IS Digital Camera
Canon Powershot A570 keeps showing change the batteries
I had the same problem. Here's the solution. Go into menu settings, then over to tools, select reset all at the bottom of options list. You may have to re-enter the date and time. This solved the low battery problem for me. I hope this helps.
Apr 02, 2010 | Canon PowerShot A570 IS Digital Camera
My Canon PowerShot A570 IS wont turn on and it was
Your problem is likely due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you're using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may be due for replacement, or the camera may have a problem that requires professional repair.
Dec 05, 2009 | Canon PowerShot A570 IS Digital Camera
My Canon powershot A570 is will not turn on, have tried new batteries and still will not work
get a new camera...this camera sucks...wasted tonnes of money on new rechargables...just didn't last long for more than 50 shots each battery change...after that, it couldn't turn on after connecting to DC input....just get a new camera and chunk this away....
Jul 03, 2009 | Canon PowerShot A570 IS Digital Camera
Canon a570 battery fail - with any and all new batteries
Hmmm...... there might be a time battery that needs replacing. Look fore something like CR1220 or time battery. Pry it open and replace it with a battery of the same size.
Jan 05, 2009 | Canon PowerShot A570 IS Digital Camera
Date/TIme Screen ALWAYS appears when camera turned on.
You need to replace the lithium date/time battery. It is a CR1220 coin cell and it's replacement can be done using the instructions on page 109 of the advanced guide. If you don't have a copy you can get one here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=221&modelid=14905#DownloadDetailAct
Hope this helps, if it does please rate my solution.
Nov 16, 2008 | Canon PowerShot A520 Digital Camera
For some reason the camera won't turn on. We just bought it a few months ago, and it was working.Suddenly it stopped. We even changed the batteries. What happened? It is a Canaon Powershot A570 IS
This can be anything from a bad battery contact, to something that went defective on the circuit board. Just double check that you are inserting the batteries properly if it takes AA types.
You would be best off to call Canon's tech suport and arrange for warrenty service.
Jerry G.
Apr 19, 2008 | Cameras
No this is free, but Fixya does not have a team of experts waiting to answer your questions. The answers just come from average people reading this website. You just have to wait, BE PATIENT, and take a lot of the answers with a grain of salt.
Your problem sounds like a defective flash mechanism. As you just bought the camera, it should still be under warranty. First try to take the camera back to the store for a replacement (be nice when you do it). If they can't help, Canon will certainly help under the camera's warranty. See the following link for details:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=221&modelid=14905
Dec 29, 2007 | Canon PowerShot A570 IS Digital Camera
Cameras Logo
127 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
