Frigidaire a/c fan motor
I need a fan motor for a wall mounted unit, model number FAH106N2T. The model number doesn't show up in your catalog, and I talked to two distributors who don't recognize it. They both found the number but say it is incomplete because there is supposed to be another number after the T, and there is definitely not. They asked for the motor number, and I gave them that and they don't recognize it either. How do I get a motor for this thing? It is barely 2 years old. It is just a simple 220V, 1/8 hp, 3 speed fan motor with a fan on each end.
    Genius:
  • 1,124 Answers
  • 2,336 Answers
Click here to find parts for your appliance.
Posted on Oct 17, 2008
    Genius:
  • 3,422 Answers
HI,
Please go to :
www.repairclinic.com
You will get all the parts for your model.
  • Priya darshan Oct 17, 2008
    Just click on the below link and on the top left enter your model no. in the search box and click search.You will get all the parts for that model.
    Master:
  • 538 Answers
Ok...can you provide the full motor number, and lets see what we can find out..
The model number is: Lithonia Lighting Model # OALS10 65F 120 P LP 3.0476 already installed and doesn (105) Wall-Mount Outdoor Metallic Fluorescent Area Light
You might have to adjust the light sensitivity of the unit... also check for power to unit if it has one with a voltage meter.
Oct 18, 2016 | Hardware & Accessories
Need fan motor for model 2E440
Try Grainger
dayton 2e440 heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
... a Dayton Model 2YU40 electric heater Need manual for Dayton. ... looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
Dayton rheostat fan motor Heaters Questions & Answers ...
www.fixya.com > Forum > Tags > rheostat fan motor > Heaters
Dayton heaters rheostat fan motor related questions and answers. ... UP BUT FAN WONT KICK ON Could be one of several problems dependant on the model you have.... The motors are noisy in 2 Dayton 2e440 heaters. I ... I'm looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
DAYTON Electric Wall Heater, Recessed or Surface ...
www.grainger.com/.../DAYTON-Electric-Wall-Heater-3...
W. W. GraingerShop DAYTON Electric Wall Heater, Recessed or Surface, Voltage 208/240, Watts ...Item # 3UG56; Mfr. Model # 3UG56; UNSPSC # 40101814; Catalog Page # 4277; Shipping Weight 20.65 lbs. ... Additional features include a built-in thermal cutout andfan delay switch for added safety ... Need Help Finding Repair Parts?
Jan 09, 2016 | Dayton Electric Heater
Working but extremely noisy freezer
most likely noise is coming from evaporator fan motor.go here,it will show you the parts in your model,
http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Freezer-Parts/Model-PLFU1778ES0/1428/0142000/R0510085/00002?blt=06&prst=&shdMod=
unplug the freezer,remove shelves and remove back inside wall to get at the fan motor.you might see yellow stains around motor area,that's from the oil that leaked out of fan motor,also if noise stops and you notice that the freezer is cold on bottom and warm on top the fan motor died and needs to be replaced right away.hope this helps and you should change the motor out before you loose any food.
Dec 08, 2013 | Frigidaire PLFU1778ES (16.7 cu. ft.)...
REFRIGERATOR AND FREEZER NOT GETTING COLD. ERROR CODE 5Y.MODEL NUMBER LGUS2642LF2 SERIAL NUMBER 4A23305873
That error code is "SY" and not "5Y" and it is for the evaporator sensor error. You will need to replace the sensor.Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Access the evaporator assembly cover in the rear of the freezer section. In convertible units that can function either as refrigerators or freezers, and is located toward the bottom of the unit on the inner back wall -- if necessary, remove the two lower glass shelves and the crisper compartments.
Remove the screws securing the evaporator cover to the freezer wall, using a Phillips screwdriver.
Pull the evaporator cover away from the wall just enough to access the electrical connection behind the cover. Be careful not to damage the gaskets on either side of the evaporator cover. Reach behind the cover and disconnect the electrical connection from its wiring harness. Remove the evaporator cover from the freezer.
Remove the wires inside the exposed evaporator assembly from their retaining clips, then squeeze the quick-connect mechanism to detach the wires from the fan motor.
Remove the two hex-head screws that hold the fan motor mounting bracket to the back wall of the unit, using a 5/16-inch socket or nut driver.
Remove the two hex-head screws holding the fan motor to the mounting bracket, using the 5/16-inch socket or nut driver, then pull the fan blade off the motor shaft.
Examine the fan to make sure the blades are not damaged; if necessary, replace the fan itself as well as the motor. Slide the fan onto the motor shaft.
Attach the new motor to the mounting bracket, using the 5/16-inch socket or nut driver to secure the two hex-head screws.
Replace and tighten the two hex-head screws that hold the fan motor mounting bracket to the back wall of the unit, using the 5/16-inch socket or nut driver.
Reattach the the fan motor wires by clipping them back into the quick-connect mechanism, and set the wires back into their retaining clips in the same manner as they were attached.
Set the evaporator assembly cover back into place, then reach behind and connect the electrical connection into the wiring harness.
Secure the Phillips screws that hold the evaporator cover to the freezer wall.
Replace the shelves and crisper compartments if they were removed, then plug the refrigerator into its power source and verify proper operation.
Regards,
Richard Roth
http://appliancecafe.com
Nov 07, 2012 | Frigidaire Refrigerators
Frigidaire Gallery Electric Wall Oven - Exhaust fan keeps running
Are you sure you gave us the right model number? My system doesn't show it and neither does the SearsPartsDirect web site. It shoulds like the switch is bad, but it could also be the thermostat if it is a thermatically controlled fan. The hardest thing in replacing a switch is getting to it and then putting everything back together correctly. Suggest taking digital photos on each step of disassemble process so that you can refer to it when you go to putting it back together.
Jan 13, 2012 | Refrigerators
Had a problem with the thermostat connected to GW-50-4 Wall furnace. One fan is not working at all, the other fan runs continuously even when the furnace isn't running. Is there a control swith or...
Jake, it sounds like the motor coil wiring on the blower that doesn't work may be damaged or has been disconnected.
Regarding the one that is still running. The automatic fan control is located on the bottom of the blower assembly. The fan control is a nonadjustable, automatic type. The fan control will require between 3 and 7 minutes of main burner operation before the fan control "closes" and activates the blower. The blower will continue to run between 3 and 7 minutes after the main burner shuts off, before the fan control "opens" and deactivates the blower. In which case, if it continues to run and run and run, the fan control switch (part # R-2503) may have failed and will need to be replaced. You can order the part from Empire Comfort Systems Tech Service 800-851-3153. Have the Model Number, Serial Number of the heater handy, as well a the Part Number. when you call.
To help you further, I have included a link to the Owner's Manual for that model wall heater. You can download and print it for future reference.
http://www.empirezoneheat.com/assets//EHS/manuals/GWT-%2825,35%29_Manual.pdf
I hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
Jun 11, 2011 | Empire GWT-50 Wall Mounted Panel Heater
I have a wall mounted accutek oval fan.been running for 5 yrs.now it wont start.i bypassed the reostat and the motor works at h speed but tuns in the wrong direction.i live in witbank in south africa and...
The motor may have a capacitor that has failed. Start Capacitors and/or motor winding "shades" are used to determine the direction of rotation, if the capacitor is checked and is defective replace it, if the capacitor is tested and is functional the fan motor may need to be replaced. it is helpful to include the model and serial number of the unit to ensure the wiring diagram is correct for your fan.
Nov 01, 2017 | Heating & Cooling
I have a fahrenheat wall mounted heater, 120 v model,(can't find a model number on the unit) with a dial temp control. No matter which number setting it is on, the unit cycles off after about 50 seconds....
UNIT SOUNDS LIKE ITS SHUTTING DOWN ON A LIMIT SWITCH IN HEATER. THEY LOOK LIKE ROUND BUTTONS OF DIFFERENT SIZES. THE HAVE 2 WIRES GOING TO THEM AND THEY ARE A NORMALLY CLOSED. THERE IS A FAN DISK NORMALLY OPEN TO UNTILL IT GETS HOT AND CLOSES TO TURN ON FAN.  IF THE FAN SWITCH TAKES TO LONG TO CLOSE THEN LIMIT OPENS TO PROTECT FROM OVER-HEATING
Apr 23, 2010 | Fahrenheat (FFH1614) Wall Mounted Panel...
Heating & Cooling Logo
90 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
