Metal spur Gear broken
If anyone has an Aurora AS1200x and would like to sell me one of its metal spur gears, please contact me. gladestro@aol.com
  • 58 Answers
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Posted on Mar 27, 2009
When turning agitator on it gets jammed in the spur gear.
This is a hard symptom to troubleshoot, it can have many different causes.
1. Is the stire wire in the kettle straight and spinning freely?
2. Does the agitator shaft spin freely in the crossbar?
3. Is there a small needle bearing on top of the spur gear attached to the kettle? it is a small metal circle that spins independently of the agitator shaft located ontop of the kettle spur gear, it can fall off.
4. The plastic block in the cabinet roof that has the motor spur gear coming out of it, is it cracked?
5. Does the motor turn when the switch is turned on with the kettle in the dump position?
All of these can lead to an answer of why the agitator stops turning while popping.
Sep 06, 2013 | Gold Medal 2656 Ultra Popcorn Maker
Is there a gear kit for the Fellowes MS-450CS Micro Shredder?
Hello Jay
I have the same problem. I found a place that sells nylon gears. They are not to good in responding back though.
This is the email address and the lady's name is Delores
sdp-sisupport@sdp-si.com
The cog below is shattered on the spindle and the bottom one, the skew spindle has chewed a hole in the cog in one place. I would like them all replaced with bronze.
Here are all the Cogs, tantalisingly close. Tell her I sent you!
http://www.sdp-si.com/eStore/CoverPg/Gears.htm
SDP SI ON LINE eStore offers Spur Gears Helical Gears Miter Gears Worm...
Dec 19, 2011 | Fellowes Manufacturing Powershred ...
The rollers will not go up and down anymore; looked inside and everythink seems intact
Your set up is most probably: an electric motor turns a worm gear that turns a large spur gear that turns a smaller spur gear that rides on a rack gear. The smaller spur gear (pinion) that rides the rack (yes, as in rack-n-pinion), allowing the up-and-down travel of the massage balls, has broken teeth which may not be visible because it's hidden under the larger spur gear. They are all plastic gears with lots of white grease.
Aug 14, 2010 | Homedics SBM 300H Therapist Select Shiatsu...
The massargers will not go up to the top is the hole at the back a reset button or not or is the massarger on the way out
An electric motor turns a worm gear that turns a large spur gear that turns a smaller spur gear that rides on a rack gear. The smaller spur gear (pinion) that rides the rack (yes, as in rack-n-pinion), allowing the up-and-down travel of the massage balls, has broken teeth which may not be visible because it's hidden under the larger spur gear.
Aug 13, 2010 | Homedics SBM 300H Therapist Select Shiatsu...
Shredder is not working. Motor is working. It's
Have you received an answer yet.Please advise. pumicepal@aol.com
Oct 10, 2009 | Aurora Global AS702MX Shredder
Large Metal Gear Wanted
Good luck, Tom
Sep 14, 2008 | Cross Infoguard Shredder SX102M
Parts available from broken SX102M
is this gear still available, if not are the bushings that it goes into still available. if so please contact me at iseicon@aol.com
Jun 21, 2008 | Cross Infoguard Shredder SX102M
Aurora paper shredder AS1200X Parts
blendervill,
If I am unsuccessful in locating the replacement gear for my AS1200X, I will joyfully sell you my unit-for parts.
Regards, MOTORRR
Feb 19, 2008 | Office Equipment & Supplies
Plastic drive gear from motor broken
I have a left over set of these plastic gears that I can send to you. The motor bracket on mine snapped. I took it apart to check. It looks unrepairable.
edbwest@aol.com
Oct 31, 2007 | Cross Infoguard Shredder SX102M
202 people viewed this question
jasbo
jasbo
