Question about Canon BJC 4400 InkJet Printer
Head stops in the middle and light flashes
When i power on my printer canon bjc4400 the head stop in the midle and flashes the powuer light
    Sergeant:
  • 279 Answers
That's the behavior of a printer that is missing its ink cartridge. It is possible there's a fault with your ink cartridge. Try replacing it and see if it works.
Posted on Aug 28, 2007
Canon inkjet PIXMA ip3000 wont print and has 5 blinking yellow lights
Canceled the jobs on PC and verify the inks.If you use the refill inks perform the head cleaning in the mantenance mode.
Feb 13, 2013 | Canon PIXMA iP3000 InkJet Photo Printer
My printer is not working... on screen it displays error 5200? the orange light flashes eight times. what will i do?
Before doing Resett ,Printer must be Ready (Service mode) , How to service mode;
  • Turn off Printer ( POWER + USB cable attached).
  • Press and hold RESUME button? .
  • Press and hold POWER button then free RESUME button But hold POWER button .
  • Press RESUME button five times (5x). not 4xprinter will turn off, but temporary.
  • Free both of button , the lamp indicator will ready in green /ready (printer will Found new hardware = canon device) Annoy it
  • Service tool v_1074.exe
  • Pairs of paper in the printer.
  • Find CLEAR INK COUNTER colom then click MAIN .
  • Printer will print
  • Turn off printer.
  • Turn on printer .
  • Printer is ready for use.
Reset Canon iP2770 error 5200
1. Turn the printer, and printer will look normal.
2. Run the printer for printing documents or print test, then the 5200 error will appear.
3. Jump unplug the power cord without pressing the on-off
4. Open it and slide it into the middle catridgenya manually (press the white penguncinya hook behind the head, for cartridge can be pulled into the middle)
5. Unplug all cartridges and leave the lid remains open
6. Turn the printer, hit the head will move left and right because the lid was still open and will stop in the middle.
7. Replace the cartridge, and close the correct
8. Your printer will return to normal
download: http://www.ziddu.com/download/14828683/ServiceTool_V1074.rar
Aug 29, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Pls let mr know Error number 5200 for printer Canon Ip 2700
I have found a solution for your problem. (1) With the printer turned on, unplug it (2)Open the top and bring the ink cartridge holder to the middle (3)Raise the gray bar and remove the print head assembly with the cartridges in it (4) Lower the gray bar with the head missing and close the top with the head out (5) Restore the power,wait til the printer wakes up (6) It will tell you to put in the cartridges (7) Restore the print head, close the top and the printer should resume working..... ;)
bhupi
May 03, 2011 | Canon Office Equipment & Supplies
When i switch on the canon ip4300 printer orange light flashing 5 times
5 flashes indicates a faulty printhead or possibly a problem with the p/head contacts. Try removing the head which is easier if you take the cartridges out first(no tools required) and re-seat it having checked the contacts for dirt.
If that doesn't work it may be that the waste ink tank is full. Try this ...
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Feb 28, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
Alarm and ink buttons all orange flashing E and 3 What do i do? first time both inks low cannot replace as do not stop in the middle holding down reset button turning printer on and off
You need to reset the Printer
Clear the EEPROM
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Jan 05, 2011 | Canon Office Equipment & Supplies
My canon mx310 alarm light will not go off after i used reset program for ink cartridges how do i stop alarm light and get it to go off?
Hi
You’ll need to reset your printer to clear the ink counters, after resetting it’ll not display the error code again. Follow this procedure to reset the printer--
1. Power off the printer.
2. Holding the stop/reset button, press and hold power button also. Hold both buttons together for 5 secs.
3. Still holding the power button, release the stop/reset buton, then press the stop/reset button twice.
4. Release power button (the screen should now say 'Service Mode').
5. Wait until the power button lights steady green, then press the stop/reset button three times with a 3 sec space between each press. On the 3rd press the indicator should turn steady orange.
6. Press the power button once, (the orange light should go off).
7. Open the printer and remove both cartridges. Wait for 10 seconds. Replace the cartridges and close printer. Wait for 30 seconds.
8. Press the power button, and wait until printer has shut down.
9. Press power button to power up. The printer will feed one piece of paper, then ask you to set the language.
10. The page counter is now reset.
First thing i would look at is the film that runs directly behind the print head i would think it is dirty. just turn on printer and get print head to the middle and turn off machine, gentle move print head to one side and gentle clean the film strip with a cloth with a little metho on it, move print head to other side and clean other part of ****.
i reckon that will fix your problem its a common problem they tend to get a bit of grease on the timming ****. Thank you Sir, Have a nice day.
Sep 18, 2009 | Canon PIXMA MX310 All-In-One Printer
Do I need a new print head?
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
Sep 13, 2009 | Canon BubbleJet i560 InkJet Printer
Paper feed pulls through on one side but jams.
check the troubleshooting steps in www.hp.com
Dec 10, 2008 | Office Equipment & Supplies
Canon BJC 3000 does not print - 6 orange 1 green
Clean the connectors located on the Printhead and the Printhead Carrier... It solved the problem in my case...
Nov 11, 2007 | Canon BJC 3000 InkJet Printer
Printer will not print
This worked perfectly for my printer:
Waste Ink Counter Reset
Power off printer and covers closed
Hold down the Resume button then press and hold POWER, the Green Indicator will light. While holding down POWER , release RESUME
Double click (2 clicks) RESUME then release BOTH POWER and RESUME and wait still the printer stops blinking.
When the indicator lights steady, press RESUME three(3) times. The indicator should be ORANGE.
Press Power to set data
I got the solution from the Internet at the following link:
http://www.fixyourownprinter.com/forums/inkjet/15620
Hope this helps.
Mar 05, 2007 | Canon BJC 3000 InkJet Printer
Canon BJC 4400 InkJet Printer Logo
170 people viewed this question
Clive
Clive
old marine
old marine
