Question about HP PSC 1315 All-In-One InkJet Printer
Deskjet f2180 not printing complete jobs/will not delete...
It started doing this before I added my apple airport express and continues to do so after I have the AEX set up.
I can send a test page to the printer, it starts and prints about 3/4 of the page and stops printing. No error message, no blinking lights, etc. If I try to print another job, like a .doc, it will send it to the spooler, it will show it, but it won't even start the job.
I have shut down, uninstalled, reinstalled, downloaded bonjour for HP and AEX.
Also, when I try to delete the printer from the printer folder, it says deleting but it never deletes it....
Any suggestions?
  • ksantoro Feb 10, 2009
    Mine is doing the same thing, did you ever find a solution?
Had a similar problem with an HP 1400 series printer. Check the HP support site. This link and the diagnostic utility work great for me:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&lang=en&custom_solutionid=rd_c01367104&rule=25494&product=458978&docname=c01072463
Posted on Mar 18, 2009
Printing using an Apple Airport Wireless network
I am not familiar with apple - However
Apple suggests resetting the printer system in the link below
https://support.apple.com/en-us/HT203159
Also driver may need updating which can be downloaded from brothers web site.
Other possibility I thought of is the port being used may not match the port that printing uses. port 515 TCP could be being blocked by a firewall of some kind or is not set up correctly.
https://support.apple.com/en-au/HT202944
Nov 12, 2015 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Deskjet F2180 not printing with Mac OS X 10.4.11
When you installed the new software did you delete your old print setup in the printer preferences as it may be conflicting with the new driver. I would delete all appropriate hp F2180 printers from the printer preferences and then install the print software again. When you do that does your printer show up? if it does not show up there could be a problem with the usb cable or the usb port on the back of your mac, swop it into another usb port, if it still does not show up, use a different usb cable. Hope this helps.
Jan 09, 2012 | Office Equipment & Supplies
HP DeskJet D2460 only prints grayscale through Airport Extreme
did you try going to printer properties? i think you will most likly find your answer there.
Jun 07, 2009 | Apple AirPort Extreme Wireless-N Wireless...
I can't connect apple airport expresses with a siemens 587 route
Login to your airport express using Apple's airport utilities (either in it's current configuration or after resetting it).
Using the airport utility do not choose manual setup, just select continue.
Adjust (as required) the airport express station name and password and select continue.
Select "I have a wireless network and I want to add AirPort Express or replace an existing device on my network and select continue.
Select I want Airport Express to wireless join my current network and select continue.
Choose if you want to extent the rance of your network or just join the network and select continue.
Choose the network you wish to join... etc etc etc....
You should be fine.
Jan 31, 2009 | Apple AirPort Extreme Base Station
F380 connected to airport express - usb /cannot print
Look for the drivers for F300 series - you may need to download them from HP's site. They're generic, but they work - unless you're trying to print through Airport!
Oct 14, 2008 | HP DeskJet F380 All-In-One Printer
Deleting completed print jobs on deskjet 5550
right click and delete. If they don't disapear try deleteing the printer and then adding it back.
Jun 22, 2008 | HP DeskJet 5550 InkJet Printer
Deleting completed jobs
Try going to System Preferences (either in the Dock or from the Apple Menu)
Then Print&Fax
Then on the left side of the window is a list of all printers.
If you double-click on the printer, another window opens
Your old print jobs should appear here.
Choose Select All from the Edit menu (or Command-A)
There is a Delete button at the top left. Click it and the old print jobs should be erased.
Jun 07, 2008 | HP DeskJet 5550 InkJet Printer
Using to Print Wirelessly
mac or windows? Here's the airport express firmware update which resolves a lot of known issue regarding the express.
windows:
http://www.apple.com/support/downloads/airportexpressfirmwareupdate63forwindows.html
mac:
http://www.apple.com/support/downloads/airportexpressfirmwareupdate63formacosx.html
May 29, 2008 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Vista compatibility
Vista has very little drivers for equipment sad but true. However in your case you can use Airport Extream. However here is what an apple tech had to say: If you are a Vista user and you don't have access to a Mac, you will not be able to get this working. Apple hasn't yet stirred itself to release a version of Airport Express Assistant that works with Windows Vista - you can't set it up via Windows' own networking software and nor does the Airport Admin Utility work under Vista. It installs and you can run it, but it returns error messages if you try and connect to the Airport Express. I had to use a Mac to get it working, though once it's set up as a client to your existing wireless network, you can stream from iTunes on a Vista PC to the Airport Express. The documentation is very poor, too, with this: I had to do extensive Googling first to track down the fact that I couldn't set it up with Vista and second to identify the device's IP address and default password. Having said that, it is a breeze to set up via a Mac and works like a dream witih Vista once it's up and running. But don't bother if you have Vista until Apple updates the software. Was this review helpful to you?
Aug 23, 2007 | Apple AirPort Express (M9470Z/A) 802.11g/b...
HP PSC 1315 All-In-One InkJet Printer Logo
433 people viewed this question
Ben Johnson
