Question about Frigidaire Refrigerators
Hello i have frigidaire fve3803b its freezer is not freezing is working but it dosnt freeze
Master_Tech
  • 770 Answers
SOURCE: freezer won't freeze
is the fan running ion the freezer is the compersser runing and the cond fan >??
Posted on May 10, 2008
compressor may be the problem,by pass the thermostate connections & chelk cooling replace if working.some sort of leakage may also be the problem.
Posted on May 19, 2008
SOURCE: WATER LEAK IN FREEZER POOLING AT BOTTOM & FREEZING THEN MELTING
The problem was indeed a clogged frost water drain. I had to pull the frig out from the wall (found an incredible amount of dust accummulation in the alcove), then remove the vertical metal and horizontal cardboard covers to expose the drain catchpan. The 1/2" rubber drain hose end was only about 1/8" above the pan pointing directly into it perpendicularly. This was not enough clearance. There was a plug (formed by dust and water) in the end of the hose that came out easily when I 'roto-rooted' it with a screwdriver. The water flowed easily after that, but I went ahead and trimmed about 3/8" off the end of the hose and pushed it back into its slot. Then I cleaned as much as I could. The prevention is to keep the area behind the frig cleaned!
Bob
Posted on Nov 08, 2008
BNewberry
  • 93 Answers
SOURCE: Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
Posted on Nov 25, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Freezer Cold but not freezing
Usually this is a sign of the defrost is no taking place. On base of refrigerator behind the kick plate grill is a defrost timer. Turn the timer clockwise until compressor stops. Leave in that position for up to 30 minutes. The refrigerator should restart on its own after that wait. If not turn the timer again until compressor starts and replace timer. During the time off this should have put the refrigerator into defrost and inside the freezer compartment you should hear crackling and sizzling as the defrost heater melts the ice and water drops down onto the defrost heater. If this helps let me know. The replacement part number for the defrost timer is
215846602 If this does not help we will need to do some other test inside the freezer with the rear cover removed and power unplugged. Sea Breeze
http://servicepartstec.blogspot.com/
Posted on Jun 24, 2009
Frigidaire FGHN2844LP ice freezing together. Replaced filter. Twenty hours later, ice maker not working, freezer warm, refrigerator temp. steady 40.
Hello Pat Havard,
I was pulling your owners manual to TRY to determine what could be done to block your freezer door or ice chute open during the filter changing process...
Today the ambient air temperature was at least 90 - 100°F
(degrees Fahrenheit)... To maintain 40°F your refrigerator
has to be working...
You need to look at your FREEZER side...
Your food, a pizza box... ice tray...
SOMETHING... in your immediate WORK area
is blocking vents... or proper closure...
Look at the door switch... make sure your light is OFF
My best guess... FILTER FIASCO induced.
http://www.appliancepartspros.com/frigidaire-ice-maker-243297606-ap5809314.html
The icemaker won't run unless you can freeze cubes...
Carnac the Magnificent
Jul 16, 2017 | Frigidaire Refrigerators
Why isn't it freezing?
Hello friend, thanks for your inquiry!
From the information you have provided your Frigidaire freezer is no longer freezing and all the lights are on. You may need to perform a reset on your freezer and you can do that by disconnecting the power cord for at least ten minutes. If this does not start your freezer would you be able to provide me with your model number? You can locate the model number on your serial tag which can be found on the inside wall. I look forward to assisting your further. -Matt
Feb 28, 2016 | Frigidaire Freezers
Freezer wont freeze ice cubes
Hello Friend, this is Z. Thank you for your post!
I interpret that you are having trouble with the freezer of your Frigidaire refrigerator not freezing ice cubes. It appears that your refrigerator is not properly cooling. Make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly. Please allow 24 hours for temperature to stabilize. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your freezer status has changed successfully. Thank you!
Aug 26, 2014 | Frigidaire Freezers
It is not wanting to freeze. but it does keep things frozen. and some times water does come out at the botton
Hello
Check that it set cold because its not below -2 or -5 thats why dose not freeze anything it needs to be at least by -10 to -18
Jun 04, 2011 | Frigidaire 14.1 cu. ft. Upright Freezer...
Water filter inside fresh food compartment keeps freezing up? Frigidaire brand 3-4 years old. Thanks, Steve.
hello,
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze
Check the cold control, and also the air deflector. As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control.
Hope this helpout....
Aug 08, 2010 | Frigidaire FRS6R5EMB Side by Side...
Not freezing
Check your circulatation fan. It may be stuck. Keep me informed The Raz Shack
Apr 20, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer not freezing
sounds like your loosing freon.
Jun 09, 2009 | Refrigerators
Frigidaire twin freezer not working
Check the freezer back wall for snow or frost.If it's there you have a defrost problem.
May 25, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer is in garage and has worked up until now. Still runs, makes a humming sound and is cold but not freezing. Food is thawing.
jeskjw
If it is below freezing in your garage the freezer will not work.
No freezer except one Frigidaire freezer will work in the extreme cold.
This one has a button to switch it to a refrigerator in the winter and a freezer in the summer.
Apr 06, 2009 | Frigidaire Freezers
Appliance Outlet
Thanks,
Bill
Nov 10, 2008 | Frigidaire FRT15B3A Top Freezer...
Refrigerators Logo
115 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
