Question about Bose 3·2·1 II System
Bose 321 won't turn on
I noticed my Bose 321 displayed bose 321 so I unplugged from the back of the DVD player and plugged it back in and now it will not even power up.
  • Bose Master
  • 5,568 Answers
I'm amazed at the range of comments regarding this system; they range from unbridled enthusiasm to some **** words.
Before I try to help, if I am not familiar with a specific model but have a clue to what the nature of the problem might be, I research the item to see if I find some support for my suspicion.
You might keep tabs on some comments I found relating to a possible class-action lawsuit due to the array of problems that have appeared with this system.
This link will give you a sample of them:
http://www.amazon.com/Bose-DVD-Home-Entertainment-System/dp/B0002JY6SQ
Posted on Oct 17, 2008
Bose 321 not recognizing cds
Contact Bose and send your unit back. Most likely the CD/DVD drive needs to be replaced
Dec 06, 2013 | Bose 3 2 1 GSX System
Have a Bose 3-2-1 Series III. When I put in a DVD, I get sound through the Bose but no picture on my Pioneer TV. This is the second time it has happened. The first time it, we managed to get it going...
Here are 3 things to try and an if all else fails at the end.
1) Make sure the TV is set to the correct Video Input to see the video from DVDs on the Bose system.
• Make sure a DVD is in the disc tray.
• If the TV is connected to the media center using the HDMI cable:
Switch from one Video Input to another and then back to the original input.
2) Turn everything off, then:
Turn on the TV and set the TV Video Input for the Bose system video.
Turn on the Bose system and press DVD.
3) Turn off both the TV and the Bose system and then:
Unplug the HDMI cable from both ends.
Disconnect the power cables from both your TV and the Bose 321 system.
Re-connect power to the TV and to the Bose 321 system.
When the Bose 321 system startup message disappears from the display,
re-connect the HDMI cable to the TV then Bose 321 system.
Turn on the TV first, then turn on the Bose 321 system.
If all the above fail then disconnect the HDMI cable that connects the TV to the Bose 321 system and reconnect the two using a Component cable, an S-Video cable, or the Composite cable provided with the system.
Please leave feedback
Cheers
Andy
Apr 28, 2011 | Bose 3·2·1 II System
Error trying to play a DVD on the Bose 3-2-1- Lifestyle system.
Unplug the power cord leave the DVD inside the Bose 321 system. Then plug the power cord back in. Voilla your DVD starts playing.
Jul 05, 2009 | Bose 3·2·1 II System
Bose 321 tray will not open
If it's flashing on and off, then the DVD drive is the least of your problems. Check to see if there is a dual-voltage switch on the bass module. (if so, set it to 120v if you're in the US) As for the DVD drive--> Try another reset by unplugging the power for at least 30 seconds. Plug it back in, "Bose 321" will appear and disappear from the display, and then press the eject button before you power it back on. Wait about 3-8 seconds. If the drive won't open, it will probably need a repair. $150 for repair w/ new warranty through Bose- 800-367-4998.
Jun 21, 2009 | Bose (321GS) System
Placed dvd in to bose dvd player and it froze...wont go back to dvd mode and will not eject...any suggestions?
This can sometimes happen with a newly manufactured DVD (in which case you should call for a sw update) or a copied DVD. Either way, turn the 321 off, unplug the power cable from the acoustimass module, and wait 30+ seconds. After plugging it in, don't turn it on. Just press the eject button and wait about 5-8 seconds. If the tray doesn't open this could me a mechanical failure, in which case you should call Bose for a repair. Otherwise, just call them for a sw update if the DVD comes out.
Jun 17, 2009 | Bose 3 2 1 GSX System
Door won't open
Sure, just unplug the system, wait thirty seconds, plug it back in (the display should read "BOSE 321" or similar) and press eject again. It should work.
If not, try it again, but wait longer...
Feb 22, 2009 | Bose 3·2·1 II System
CD stuck in disk tray of (original) BOSE 321
NO NEED TO TEAR APART OR REPLACE THE UNIT! JUST TURN OFF THE UNIT, LEAN IT FORWARD AND A LITTLE DOWNWARD AND HIT THE LOAD BUTTON AND IT WILL OPEN. THAT'S THE TRICK!
Nov 23, 2008 | Bose 3·2·1 II System
Non bose dvd player for bose system
In short, you can. I did it last night. My Bose 321 DVD player is junk and it's always been junk, but I love the sound sytem. Last night, after the thing gobbled it's last DVD, I went through the whole, unplug, wait 5 minutes, plug back in, etc. and it still wouldn't eject so I ripped the DVD tray out of the thing with a pair of pliers, recovered my DVD, and slammed the tray back in, stripping all the gears and screwing up the motor in the process.
BUT, I disconnected the video cable from my Bose and plugged it into the video out on my el-cheapo Tru-Tech $99 DVD recorder. Then I ran the audio out cables from the Tru-Tech to the Aux 1 inputs on my Bose 321.
When I want to watch a DVD now, I put the DVD in my Tru-Tech, turn on the Bose, switch it to Aux 1, and I get a great picture and the Bose sound. Best of all, I don't have to plug and unplug that sorry Bose system everytime the wind blows.
They used the absolute cheapest DVD player they could get their hands on--a Toshiba model--for all the Bose 321 older models. Every single person who bought one has had these same troubles and they've made no offer to fix them.
This was my first and last Bose because of that and I hope more people stay away from Bose until they get their act together and protect their customers. $1000 for a system that eats DVDs like M&M's is ridiculous.
Aug 08, 2008 | Bose Lifestyle 28 System
Bose 321
yes as long as IDE cables and DVD player fits it shouldn't be a problem
Apr 24, 2008 | Bose (321GS) System
Bose 3·2·1 II System Logo
2,777 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
