Question about Westinghouse L1975NW Monitor
Wrong plug-n-play display selected.
My display adapter is auto detecting the wrong display. Just wish to verify that the L1975NW do not have a driver that I can download to force the display adapter to select the right display. It says that the display is a Optoma EP719H. I am using a nVidia GeForce 7300 LE Display adapter. Actually the card has two outputs. The main one it detects correctly the secondary it does not.
Thanks in advance.
  • Anonymous Nov 13, 2008
    i have the same problem
  • 558 Answers
Double adapter output display adapters generally need a multible monitor driver to run correctly,
see here http://www.nvidia.com/object/feature_nview.html
Posted on Dec 03, 2008
When I have the tuner in FM mode and select Dolby Digital the center channel is the only one that plays
Seems that you hav checked and set up rightly and the fault seems to be with the main amplifier drivers. Remove the left and right speakers and test, if these are OK then the fault can be with the outputs if there is no output even with a normal aux input .Take consensus to confirm.
Nov 07, 2011 | Yamaha HTR-6090 Receiver
I just bought the NetGear wireless adapter today. the process runs smoothly until it asks me to hook the wireless adapter. A box pops up stating "detecting wireless adapter" it stays like that...
It looks like your NetGear WNA3100 is dead out of the box.
The software looks like it operating correctly (runs the installed diag, tries to detect, etc.), but
the software isn't having any luck finding the hardware.
The reason that the adapter is disabled in Device Management, is that the software seems
to have correctly installed the driver, but Windows couldn't detect (plug & play) the device, so
Windows didn't enable the device driver - Windows won't load a driver for a non-existent device.
Other (remote) possibilities:
(a) Wi-Fi adapter plugged into a bad USB port. - try another port.
(b) there's a little corrosion on USB contacts of USB port or WNA3100. Try plugging adapter
in and out of the port a few times (this shines up the contacts a bit).
(c) there's a slight misalignment of contacts within the USB connector or either the laptop, or
the WNA3100.
Your fix may be returning the NetGear WNA3100 to the retailer for an exchange.
Sep 04, 2011 | NetGear WirelessN 300 USB Adapter WNA3100
Laptop died and now I cant connect my desktop with the belkin usb adapter. It just keeps saying aquiring network address.
Use the Ethernet cable to verify the router or modem is working and connects to the Internet. If so, then check your wireless adapter in the desk top through device manager - it should detect the Belkin. Also, verify you are entering the correct WEP keys to access the wireless connection to the router or modem - sometimes it gets typed in wrong.
Feb 19, 2011 | Belkin (F5D7050) 802.11a/g/b Wireless...
Igxprd32 display driver stop responding is flashed on my computer when i play games on my desktop .what can i do to fix that problem so that i can play games on my desktop
This is a problem with the GM965 chipset display driver. you need to search for the updated display driver for your computer/laptop and then install this to your system.
steps:
  • Right click on 'My Computer' and select 'Properties'
  • In Properties screen, select 'Hardware', and then 'device manager'
  • Look for 'Display Drivers/Adapters', and then look for your display drivers (e.g. Intel(R) GM965 chipset display).
  • Right click on the name of the display driver and choose 'Uninstall'.
  • Reboot your computer.
  • Go to http://www.update.microsoft.com
  • Choose Custom Update option
  • you will see microsoft page checking for updates for your system
  • once it has detected that your display driver is missing or needs to be updated
  • you can click in Hardware link on left side of screen and it will show you the old version of your display driver
  • simply install this one and you are done.
Oct 19, 2010 | Computers & Internet
Have a Kenmore Elite HE 3t front loader washing machine that will not complete spin cycle since moving, symbol coming up FH what is wrong?
F/H No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operati
Jul 07, 2010 | Kenmore Elite 45986 Front Load Washer
I am looking for a monitor driver for Windows Vista for LT1919
Windows XP and Vista should "auto-detect" the capabilities of this LCD screen.
If not, access http://WindowsUpdate.Microsoft.com
and scan for updates.
When the scan is done, look for "optional hardware" updates.
If Microsoft has a driver, it will be offered for download.
Nov 20, 2009 | Mag Innovision Computers & Internet
Cant see my screen due 2 lots of dots and stripes
Sounds like you need to re-install your Display Driver...it may have gotten corrupted. Either download a new one, or re-install the one you have.
If that deosn't work, then the display adapter is bad... then you will need to order a new motherboard(if it is onboard video) or a new video card.
In order to properly see your screen, try starting your PC in 'Safe Mode', that way it won't load a display driver. To do this.. when you first turn your PC on, press F8 repeatedly, and it should bring you to a boot menu. Choose to boot into 'Safe Mode'... and see if you can re-install a display driver from there.
Sep 15, 2009 | HP Hewlett Packard Compaq D51S Intel...
My gemtek wl-299c wont work on my computer, it detects it but even if i manually put the IP address it wont connect, its supposed to be plug and play I dont need drivers but in case I do where can I...
It seems that your adapter is plug and play since it does not require drivers to work. Check the device status under the Device Manager and see if it was detected and properly installed.
How to got o Device Manager:
1. Right click on My Computer then select Properties
2. Select Hardware tab then click on Device Manager option
3. the adapter should appear under Network Adapters
If the drivers were properly installed PING the adapter to see if it is responding.
How to PING the adapter:
1. Go to command prompt by clicking on start then under accessories.
2. Type "ping loopback" on the space
If you get replies then the adapter is working!
Hope this helps. Please do not forget to give comments to this solution.
Thanks!
Jul 05, 2009 | Computers & Internet
No input...
spacer.gif spacer.gif spacer.gif spacer.gif Service and support team is available:
Monday through Saturday
9 AM - 9 PM Eastern Time
1 (866) 287-5555
Note regarding LCD Drivers
Since Westinghouse LCD (TVs and Monitors) are plug-and-play devices, they do not require any drivers. If your computer is unable to display at the recommended resolution, please check your graphics card to see if it supports the recommended resolution. You can periodically check the graphics card manufacturer's website for any update.
Good Luck, Please dont for get to Vote. Thank You.
Dec 12, 2007 | Westinghouse L1975NW Monitor
Westinghouse L1975NW Monitor Logo
506 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Alun Cox
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
