Question about Mitsubishi WD-65C9 65" DLP HDTV
White spots every few days more white spots shot up
    New Friend:
Replace the DLP chip at cost between $160-$300 for the part and about two hours of your own time to do it.
http://www.shopjimmy.com/samsung-mitsubishi-toshiba-4719-001997-dlp-chip.htm/
Posted on Jun 19, 2012
    Filmmaker:
    Uploaded 5 video answers.
  • 18 Answers
White dot for Mitsubishi DLP chip only caused by aging DMD Chip. Check our post to show how to replace and where to buy
Posted on Feb 23, 2013
SOURCE:
I have a NEC projector in my class but projects white spots on the screen which are multiplying day by day. Has anybody solved this problem ???
1,white spots appeared on screen,means the DMD is broken,you need a new DMD.
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD, motherboard, powersupply ... with high quality and competitive price.
Jerry China
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Feb 07, 2014 | NEC NP200 Projector
I have sanyo projector model PDG-DSU20E. Few white spots appeared on the right side of the screen. Gradually the spots has filled the right side about 1 feet is width till bottom of the screen. Now few...
2,the projector running off after only a few minutes,means the Inductor (Sensing element),near the Color Wheel. Use a cotton swab moistened with alcohol to wipe the Inductor.
Have a good day!
Jerry China
Skype: lampdeng.com
Sep 11, 2013 | Optoma PRO250X Projector
DSC-H7 camera, getting red eye or white eye spots
First, here is why they are red or white spots:
The red is the reflection of your flash on the retinas of your subjects. The white are generally animal eyes reflecting back.
You will notice this on flash shots only and mostly when you use the zoom. The zoom uses a "narrow" field of view so the light that reflects back is "direct", instrad of at an angle.
The fix: Change the ISO setting (it is set too high). It is probably near the maximum sensitivity (3200?)... set it to 400 or so and try that for a while. 800 is probably the best general setting, but try 400 first.
Try not to use the flash unless you really have to, but only if the subject is less than 12 feet away. If no people are in the picture, you may use the flash for subjects greater than 12 feet.
this should work for you...
Sep 11, 2009 | Sony Cyber-shot DSC-H7 Digital Camera
Samsung DLP with white spots
Hello rockel, As the commercial goes, "It's the mirrors" and that is exactly what it is. The DMD (digital micromirror device) DLP chip that is the problem. The areas that are white are due to stuck or malfunctioning mirrors. This will only get more pronounced as time goes on. The fix is to replace the DLP chip and or module. I would advise that you get a qualified TV technician to do this. I hope this helps Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Jun 11, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Mobile problem
i couldnt find disply for k550i cybershot model
Aug 25, 2008 | Sony Ericsson K550i Cyber-shot Smartphone
About the spots on photos..
I recommend returning it. Nikon's QC may be lacking these days
Feb 03, 2008 | Nikon D40x Digital Camera
Spot on every shot
Your sensor may have gotten dust on it to confirm this, set camera to a small aperture eg. f22 and take a picture of a white page then set camera to a large aperture eg f3.3 ant take the same picture. If it is dust you will see the spot on the shot taken at f22 and not the one taken at f3.3. This can be solved by having the sensor cleaned. If the gray spot is on both images you most likely have a damaged sensor
Oral Davis
Trinidad West Indies
Nov 24, 2007 | Nikon D80 Digital Camera with 18-135mm...
Spots on image when using built-in Speedlight flash
As is common in many compact digital cameras where the built-in flash is very close to the lens strange reflections can appear in images under certain conditions. Particulate matter in the air in front of the lens (between the camera and subject) such as water vapor (as in a cloudy day), smoke, dust or other items can reflect light directly into the lens causing neutral colored white/grey semi-transparent spots to appear in the image. In extreme examples there may be many of these spots in an image or there may be only one per image. Also, since these spots are completely random they will move or disappear from image to image. For example, if two images are shot consecutively with the same camera settings one image may have spots while the other is clean. To avoid these spots: When possible, avoid photographing in smoky, dust, or cloudy areas Do not use the camera's flash in locations such as above Use an external Speedlight flash if a flash is needed Review images on the camera and re-shoot if spots are visible Cleaning the lens will not have an effect on these spots, as the particles that cause this are not on the lens itself.
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Mitsubishi WD-65C9 65" DLP HDTV Logo
927 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
