Question about Whirlpool Kitchen Ranges
I have a Whirlpool Self-Cleaning Electric range I was running the self-cleaning cycle and at the end I received a error code f5. The modle # is rf199lxh
the dr
  • 447 Answers
SOURCE: problem with electric range
Most likely the switch has welded closed
Posted on Sep 28, 2007
  • 1314 Answers
SOURCE: Whilrpool Self Cleaning Range Door won't unlock
try this 1. Verify error code by pressing and holding CANCEL/OFF key for 5 seconds.
Momentarily (less than 5 sec.) press CANCEL key again to remove error code
display.
2. Press and hold any key for 1 minute until F2 E0 code is displayed.
3. Cancel F2 E0 error code.
4. Program and start the clean mode. Observe to see if door locks. If it does not,
inspect the locking mechanism from the solenoid to the latch pawl and door to
find the cause of the problem. If the door is not locking, then 1 minute from the
start of clean, the F5 E1 code will again be displayed. Steps 1 through 3 will
have to be repeated before another clean can be started.
5. Once any mechanical problems with the latch mechanism have been corrected,
program and start a clean cycle (after, if necessary, clearing F5 E1 error code)
to ensure proper operation of the door lock. Immediately cancel the clean mode to observe proper operation of door unlock
Posted on Feb 12, 2008
Agent Matt
  • 8 Answers
SOURCE: Unlocking Oven controls
According to the manufacturer's website you should only need to Press and hold the "Lock" key for 5 seconds. A single tone will sound and the "Loc" will disappear off the display.
This is the link to Whilpool's website and to the manual.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209761079.pdf
Thank you
Agent Matt
Go Ahead. Use Us.
Posted on Apr 07, 2008
blueextc3221
  • 15935 Answers
SOURCE: I tried to set my self-cleaning on my Electric
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 23, 2010
blueextc3221
  • 15935 Answers
SOURCE: Super capacity 465 Whirlpool range . E1 F5 code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.ER%^
Posted on Oct 01, 2010
My oven has an error E1 F5. It was working fine until I tried to use the self cleaner. Now the oven and self cleaner will not work . Only beeps when I try to cut it on.
Hey I found your manual and error codes on-line and was surprised that Whirlpool did not have it hard to reach. Click Here=> Whirlpool 30 in Self-Cleaning Freestanding Electric Range Error Codes
Have questions please ask and rate this solution, Thanks Sea Breeze sea_breeze_128.jpg
or greater.
Error codes are on page 61 section 5-1
Please Rate This Solution, Thank You! Sea Breeze
Mar 27, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Trying to selfclean oven and getting error code E1 F5. What does that mean?
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Feb 20, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Trying to self-clean...code F5 and E1 pops up...whats wrong?
heatman101
Jan 08, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Self cleaning cycle doesnt work. I keep getting an E1 F5 error. How do I get the self cleaning cycle o work?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!$WR
Sep 24, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool Self Cleaning oven error code
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Jul 15, 2010 | Whirlpool Gold GW399LXU Gas Range
I am trying to run the self cleaning oven and keep getting a toubleshooting code of e1 f5. Not sure what this means or how to fix it/
Hello- The code you describe- E1 F5 - indicates a problem with the door switch. This little switch tends to fail during or after the 'self-clean' function is used. The switches are difficult to get to on some of these units so plan on just replacing it with a new one. This part is available locally at an appliance parts store with a complete model # from range tag. When power is re-connected, door motor should cycle back to correct position. Remember- techs call it 'self-destruct', so avoid 'self-clean'. The tried and true cleaning methods are a lot less destructive on the circuits and electronics. Let me know if this info helps- have more if needed. Thanks- Ed.
Mar 15, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Self cleaning feature
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.FGRT%$^
Jan 15, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Clean cycle will not work.
F5 - E0 F5 - E1 and E2 -------- this all codes relates to ----- Check door/latch switch ------------ clean it and check if stiil the same problem ---- Replace switch if defective
Apr 01, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
display.
Feb 10, 2008 | Kitchen Ranges
The F5 error code?
WHIRLPOOL
Range/Stove Oven Fault Codes, Common Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective
Nov 03, 2007 | Whirlpool GBS307PR Electric Single Oven
Kitchen Ranges Logo
53 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
