Question about Refrigerators
Dear Sir/Madam, I own a Hotpoint FFA61P fridge/freezer. There is a problem with the fridge cooling to a point where it begins to freeze and the freezer not freezing enough. Could please let me know if this a common problem with this model.
  • 4 Answers
I dont know whatrefer you have but try replacing the thermister imrelly arv tech but i will try to help
Posted on Oct 17, 2008
WHERE IS THE THERMOSTAT ON HOTPOINT FRIDGE FFA60
i have a hot point,side by side,little old but great fridge.It is located where adjustments are you can hear it click when you turn it up or down but their is a element in freezer like a big fuse that gets hot and defrosts the coils behind the plastic in freezer.if it is out it will cause unit to freeze up and it will not cool properly.I replaced mine and man what a difference.At first icecream would sometimes be ok then not.if you turn fridge down for while then turn it back up and hear a click then it starts to run its the element in freezer
May 25, 2012 | Hotpoint Refrigerators
Freezer high temp light is on. So is fast freeze. It's been plugged in at least 24 hours but not freezing.
FREEZER HIGH TEMPERATURE WARNING LIGHT DOESN'T GO OUT.HOW TO CANCEL OR RESET?FOR HOTPOINT FFA74.THANK YOU
Mar 11, 2011 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint rla50 fridge is freezing up
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 06, 2010 | Hotpoint RLA50 Refrigerator
Electrolux fridge freezer, Motor never turns off. replaced thermostat, still motor keeps running. The back, top half of fridge freezes over but the temperature remains cool?
dear sir/madam
i think this is thermostat setting problem please make sure freezer,s thermostat nobe (nidle) is in correct position .then see thermostat temperature settings . may be thermostat is not controlling to compressor motor that why it,s running continuously.
hope answer the question,
thank you
please vote!
Sep 02, 2010 | Electrolux Freezers
Fridge only freezing on top shelf no gas /?
dear sir/madam
first make sure your freezers is clean well sometime evaporatore close by dust and dirt then its cause effect to our equipment,s performence.if its well clean then check tempreture sensor in right location. if all is ok then contect to your maintenance personnel for refilling the gas.
hope answer the question.
thank you
Jul 05, 2010 | Hotpoint Freezers
Hotpoint RFA52 fridge freezer
if you cant hear the motor/compressor running when energised then its likely to be a thermostat fault... but on energising the system if you hear a buzz then a click then its more seriously the main motor... turn off at mains for 5 mins then turn on... this should tell you either way
Dec 22, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Freezer is cooling, but refrigator is not cooling
take a look at your evaporator fan motor in the freezer to make sure it is running and not built up with ice around it. this fan motor pushes the cold air from the freezer into the fridge to cool the fridge. you say the freezer is "cooling" , is it freezing??
Oct 14, 2009 | Hotpoint Refrigerators
Hotpoint hss25gfphww refrigerator is not cooling on either side. All of the sudden freezer not freezing, fridge not very cold. Any suggestions? Fridge only 5 years old.
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 08, 2009 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
130 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
