Question about Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite A135 Battery Issues!!!
My Toshiba (a135) will not stay charged!
*This is ONLY when the computer is turned off completely... I plug it in, it will charge for about 2 seconds, the orange battery light will turn off for about 3 seconds, then it will charge for anywhere from 5 seconds to SOMETIMES a full charge until the battery light turns blue. It usually takes me about 10 tries of plugging it in and unplugging it in for it to keep charging.
*As soon as I turn the computer on, it uses battery power, even if it is plugged in. My task bar battery says "plugged in, not charging"
I have replaced the battery, this is a brand new one I am using and it is having the same issues as the last battery.. what should I try now?!? This is extremely frustrating!
  • jessicaray Oct 17, 2008
    I had a previous issue with a connector (the plug in the back of the computer) in a Toshiba laptop before, so that was the first thing I checked. It doesn't seem to be the problem. I've had this same problem for about 2 months, and since that time we've moved into a new house, so I know it isn't the plug.
    Could It be the actual AC power adapter? If it were shot, would it charge sometimes and not others?
    I hate to spend more money on another AC adapter if i don't have to... since i just bought a battery for no reason! :)
    Problem Solver:
  • 6 Answers
Here's what happened (The fix is at the end):
8 months after buying my Toshiba A135 the battery began charging only intermittently. It also would not run without the battery. I put up with it for a month then took it back to Best Buy to get it repaired under warranty. They kept it over 2 weeks then gave it back saying it was the battery, which they replaced. One week later I had the same problem again. Back to Best Buy. The guy at the counter said it was probably the battery, they had encountered a lot of that. I said no, explained it, and gave it over to be fixed. 2 weeks later I got it back. They had reset the BIOS, no hardware replacement. I got it home and it was not fixed. I took it back the next day. They kept it 2 more weeks. They replaced the motherboard. I took it home and...you guessed it the same problem on the day I got it home!!! I took it back with one week left on my warranty. I don't remember what they replaced the last time but I think it was the motherboard again. I got it home (2 weeks later) and THE SAME PROBLEM on the day I got it home. So, the lesson there is that Best Buy computer maintenance SUCKS!!
I called Toshiba to try to get them to fix it for free, and out of warranty. After several frustrating minutes of conversation with an accented person who just kept telling me that my warranty was up, I hung up and called back and got an English speaking person. SHE was very helpful, listened to my problem, agreed to give me a one-time fix ticket. They paid for the postage. When I got my computer back it was mostly fixed.
The problem was the module at the back of the computer where the power cord plugs in. It was defective. Some wire or solder had gotten loose. They replaced it and it worked fine after that, except that when it goes into sleep mode it will not wake up. I fixed that by turning off all the sleep mode options. BTW, a friend of mine with the same computer is now having the same problem.
Posted on Oct 22, 2008
    Novelist:
  • 137 Answers
Are you sure that it's not a connection problem? That is, check to make sure that when you wiggle or push on the plug end it doesn't effect the charging. Have your computer on and running then unplug and plug in your adapter. also try wiggling it slowly to see if the charge/plugged in icon changes.
I'd also check to make sure you have consistent power. If you have it plugged into a power strip, try plugging it directly into the wall and vice versa. Also you may want to make sure your power supply is providing a consistent output. If you can, find a multimeter and check the plug end of the adaptor to make sure it's providing the same voltage as called for on the bottom of the Laptop (probably 16v). If there is much variability, maybe greater that +/- 1v that might be part of the issue. I'd also take a listen to the adaptor. I've had a few bad adaptors produce a slight buzzing sound.
It sounds like you are insinuating that there is no problem with the charging when the computer is turned on and THEN plugged in but maybe this isn't right.
Posted on Oct 17, 2008
3 Suggested Answers
insomniac
  • 103 Answers
SOURCE: Windows xp Driver for satellite A135-S2246
what operating system are you running now? when you install xp with the cd the software has the drivers on it. if you have the cd hopefully it has service pack 2 if not once you install xp you will need to update.
Posted on Feb 22, 2008
  • 1257 Answers
Just use the below link to download all the drivers for your laptop.
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_modItemList.jsp?moid=1596138&rpn=PSAD6U&ct=DL&BV_SessionID=@@@@1918011271.1211034556@@@@&BV_EngineID=cccdadeedmeimggcgfkceghdgngdgmn.0
Click on the link if you dont know how to install windows xp
http://www.petri.co.il/install_windows_xp_pro.htm
_____________________________________________________
Low feed backs hurt my ratings and I tried my level best to resolve the issue. so it will be highly appreciated if you could take a minute and provide me your feedback..
"FixYa!" - The solution provides great advice on how to solve the problem.
"Helpful" - The solution provides useful leads that helps solve the problem.
"Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
"Inappropriate" - The solution has absolutely nothing to do with the problem.
Posted on May 17, 2008
Toshiba satellite a135 s2386 will not turn on
Remove the battery and leave it for ten minutes. Refit and if there is any charge in it ,it should turn on. If when plugged into the charger it still will not turn on then either your charger is faulty or the dc jack in the laptop has a bad joint on it.
Jul 25, 2011 | Toshiba Satellite A135-S2386 Notebook...
My Toshiba Satellite A135 laptop just started beeping. regular sounding beep every 15 seconds or so. please help!
Hi
could it be because it may be telling you that the battery is getting very low and that you need to plug in and charge
my toshiba laptop does it when its very low
Apr 29, 2011 | Toshiba Satellite A135-S2246 Notebook
Hi, My toshiba A135-S7404 satellite model laptop will not charge when it is plugged in. When i try to turn it on, it will come one for a about 3 seconds then turn off. what do i do about this issue? the...
could be motherboard related issues as the battery would still take a charge and indicate that whit the indicators on the front but a motherboard related issue would not affect that at all so i would get it looked at
Jan 14, 2011 | Toshiba A135-S7404 Notebook
Toshiba Satellite a135 will not power on. The LEDs at the bottom are showing that the computer is both charging and has power going to it, when I press the power button it will not power on.
Unplug battery and Power cable from laptop
Press and hold the power button for 20 sec(no battery and no adapter)
connect the power cable back to laptop.
Try turing on the computer.
Nov 26, 2009 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite A135-S4656 Laptop
Either the battery is bad and not holding a charge, or the laptop's power jack needs to be repaired. Try this check.
Take out the battery and plug in the power adapter. Turn on the laptop and see if it operates normally. Gently wiggle the power plug and see if the power indicator on the computer remains steady. If it does, you should replace the battery. If the power light flickers as you wiggle the plug, the power jack in the computer needs repair.
It's a common problem for the power jack connections on the motherboard to break because the power plug gets flexed. When this happens, power doesn't get in from the charger to run the laptop or charge the battery. These connections can be repaired, but it means taking the computer apart to get the main board out to make the repair. Also, in some cases the board may be damaged by arcing and heating from the bad connections and may not be repairable. Usually resoldering the bad connections fixes the trouble.
A computer service shop could give an estimate for the repair. When I worked at a shop our repair charge was about $75 (I think; it's been over 5 years now). If you have electronic soldering skills and the right tools you could try the repair yourself. Several videos on youtube show the procedure for taking apart the computer to get the board out.
Hope this has helped you. If so, please take a moment to rate my solution. Thanks for asking here!
Mar 18, 2009 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite A135-S4527 Charger problem
Get another laptop.
The A135 is a lemon.
Problem is either with the dc jack on the board or more than likely the motherboard is damaged.
I've repaired a number of A135's and 95% of the time motherboard had to be replaced.
Sorry for the bad news, but I hope this helps.
Mar 02, 2009 | Toshiba Satellite A135-S4527 Notebook
Toshiba's A135-S4527 Battery isn't working anymore
Have the battery checked or better yet, replaced. Prolonged use might damage the charging circuitry of your machine.
Jan 11, 2009 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite A135-S4666
try to eject whatever is in the DVD (you will see a tiny hole near the eject button, straighten a paper clip and push it in the hole) then try again
regards
Nov 24, 2008 | Toshiba Satellite A135 Notebook
Laptop won't turn on
Unplug the computer from the adapter and then take the battery out. Put the battery back in. Put the adapter back into the computer. Enjoy computer.
Apr 13, 2008 | Toshiba Satellite A135-S2276 Notebook
A135-S2266
Try taken the battery out. Plug a/c directly to it with battery out. See if you get anything. ANY LIghts on? Please respond
Feb 13, 2008 | Toshiba Satellite A135-S2266 Notebook
Toshiba Satellite A135-S2276 Notebook Logo
283 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
