Hitachi 43UWX10B 43 in. Rear Projection Television
Problem for Hitachi 43UWX10B 43 in. Rear Projection Television
Television problem
By hightech on Jun 04, 2006
Picture on television has yellow outline around the images on screen
Same Problem
Nov 20, 2008
-   all images look yellow, i cant get the color right.-   Guest
Apr 14, 2008
-   Sony KP-65WS500 hs blue shadow from my left side. I did adjust he blue ray gun already and nohing happen. I tapped the blue gun and diappear for a minute and back again please help.-   msweeneys1
Mar 31, 2008
-   Picture bows at top and bottom and colors don't sync (shows three seperate colored images).-   SpyrL
Mar 29, 2008
-   halo with greenish yellow tint to everything .... definition and edge clarity is excellent but tghe blue convergence only has a blue cross no image to converge onto-   markeymark
Dec 03, 2007
-   outlined shadow effect when turned on. After turning off and back on a few times it corrects itself.  This happened once before. The repair man pushed a few buttons on my remote control that brought up a menu screen I hadn't seen before. The whole thing was over in two minutes. He charged me about $170 bucks and I have no idea what he did. Now I'm faced with paying for the same thing again. I will not buy a jvc product again.-   Guest
Best Solution
posted on Jun 22, 2006
Helpful)
hardrocko
Rank: Guru
Rating: 85%, 922 votes
The yellow is being caused by misconvergence of the red and green beams. Go into the menu and do a convergence setup. Should be under video or convergence heading. Your ops manual should tell you exactly how. If after setting the convergence you still have the problem your digital convergence box is bad and you will need a tech to replace it. About $60 to $100.
Was this helpful?
Yes
No
Popular Solutions for Hitachi 43UWX10B 43 in. Rear
Questions and Unsolved Problems for Hitachi 43UWX10B 43 in. Rear
Do you recommend Hitachi 43UWX10B 43 in. Rear Projection Television?
Answer
Answer
power went out when tv turned back on double images 52 inch hitachi
Answer
green, pink color waves at top of screen and wording on screen is double
Answer
rear projection tv made pop noise then picture and sound went out. power light is on.
Answer
I have a Hitachi Ultravision HDTV model number SP-43w. When you turn it on it is red and wavy across... (More)
Answer
no picture just sound and can see the words at times but no picture
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hitachi 43UWX10B 43 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
