Question about GE USB Retractable Number Pad HO98462
How do i access the characters/symbols
Want to access accent marks that i can do w num lock, alt and set of 3 #s on my pc
  • deenah Oct 17, 2008
    i'm not getting anything when i hit alt and any combination. also, why are the combos different in your link? ex: on my desktop, alt 0149 gives me a bullet. on linked list, 149 is accented o.
  • deenah Oct 20, 2008
    the response really didn't give me a solution with the GE retractable number pad. any ideas?
  • 4,472 Answers
Ok what information are you still needing. Once I get a more clear understanding of exactly what you still need or having trouble with I know we should be able to get this issue worked out or some sort of definitive answer.
Thanks,
Lee
Posted on Oct 20, 2008
  • 1,879 Answers
Results depend on the font / character set
Posted on Oct 17, 2008
    Master:
  • 848 Answers
Ctrl + Accent, then letter always works in MS Word.
Entering International Characters
There is a number of ways of entering international characters and symbols.
a.. Use Character Map.
b.. Use Alt + <the character code entered on the numeric keypad>
c.. Use the US International Keyboard
Entering International Characters - Character Map
Start - All Programs - Accessories - System Tools - Character Map and transfer via the clipboard.
Entering International Characters - Alt + Character Code
Holding down alt and pressing the character code on the numeric keypad will enter that character. The keyboard language in use must support entering that character. If your keyboard supports it the code is shown on the right hand side of the status bar in Character Map else this section of the status bar is empty.
However there is two ways of entering codes. The point to remember here that the characters are the same for the first 127 codes. The difference is if the first number typed is a zero of not. If it is then the code will insert the character from the current character set else it will insert a character from the OEM character set.
E.G., Alt + 0 then 6 then 5 then release Alt enters the letter A
Entering International Characters - US International Keyboards
Install the US International keyboard. Start - Control Panel - Regional And Language Options - Languages - Details - Add. While here review the Key Settings to switch keyboards or turn on the Language Bar (Advanced Text Services must not be disabled).
This works in two modes. Right Alt or Shift + Right Alt + another key and also by pressing dead keys (such as accents). On non US Keyboards the Right Alt key is called Alt Gr.
Right Alt is the same key as Ctrl + Left Alt on the US International keyboards, and on almost all keyboards except the standard US keyboards where left and right keys are treated the same . This is a reason why Ctrl + Alt should not be used to set hotkeys. Also F12 should also not be used for hotkeys as it's reserved for attaching a debugger.
The Right Alt Keys
Key Description
Right Alt + 1 i
Right Alt + 2 â²
Right Alt + 3 â³
Right Alt + 4 â¤
Right Alt + 5 €
Right Alt + 6 1/4
Right Alt + 7 1/2
Right Alt + 8 3/4
Right Alt + 9 '
Right Alt + 0 '
Right Alt + - â¥
Right Alt + = ã—
Right Alt + Q ã¤
Right Alt + W ã¥
Right Alt + E ã©
Right Alt + R (r)
Right Alt + T ã¾
Right Alt + Y ã¼
Right Alt + U ãº
Right Alt + I ã*
Right Alt + O ã³
Right Alt + P ã¶
Right Alt + [ <<
Right Alt + ] >>
Right Alt + \ Not Sign
Right Alt + A ã¡
Right Alt + S ãÿ
Right Alt + D ã°
Right Alt + L ã¸
Right Alt + ; Pilcrow Sign
Right Alt + ' â´
Right Alt + Z ã¦
Right Alt + C (c)
Right Alt + N ã±
Right Alt + M âµ
Right Alt + , ã§
Right Alt + / â¿
Shift + Right Alt + 1 â¹
Shift + Right Alt + 4 â£
Shift + Right Alt + = ã·
Shift + Right Alt + Q ã„
Shift + Right Alt + W ã…
Shift + Right Alt + E ã‰
Shift + Right Alt + T ãž
Shift + Right Alt + Y ãœ
Shift + Right Alt + U ãš
Shift + Right Alt + I ã
Shift + Right Alt + O ã“
Shift + Right Alt + P ã–
Shift + Right Alt + \ â¦
Shift + Right Alt + A ã
Shift + Right Alt + S â§
Shift + Right Alt + D ã
Shift + Right Alt + L ã˜
Shift + Right Alt + ; â°
Shift + Right Alt + ' â¨
Shift + Right Alt + Z ã†
Shift + Right Alt + C â¢
Shift + Right Alt + N ã‘
Shift + Right Alt + , ã†
The Dead Keys
The dead keys are the apostrophe ('), quotation mark ("), accent grave (`), tilde (~), and caret(^). If these are pressed the system waits for the next key. If it is in the list below then it enters the symbol character else it enters both keys seperately. These work with uppercase where appropiate.
Key Description
' then C ã†
' then e ã©
' then y ã½
' then u ãº
' then i ã*
' then o ã³
' then a ã¡
" then e ã«
" then u ã¼
" then i ã¯
" then o ã¶
" then a ã¤
` then e ã¨
` then u ã¹
` then i ã¬
` then o ã²
~ then o ãµ
~ then n ã±
^ then e ãª
^ then u ã»
^ then i ã®
^ then o ã´
^ then a ã¢
Like Accessibility there is a trick here with general applicability. Normally Caps Lock is on or off and stays on or off untill the key is pressed again. This can be changed to act like a typewriter at Start - Control Panel - Regional And Language Options - Languages - Details - Key Settings and one can select whether another Caps Lock press will turn off Caps Lock or if pressing the Shift key will turn it off like on a typewriter.
  • GE Master
  • 19,396 Answers
You need to press alt and insert ascii char code for the marks.
  • 1 more comment
  • Ginko
    Ginko Oct 17, 2008
    Here is the full table
    Special ALT Characters
    Just hold alt and type the three characters code corresponding to the character you want.
  • Ginko
    Ginko Oct 17, 2008
    For example, to type " you hold alt, then 34 (or 034), when you leave alt you get the character.
    For other characters refer to table Special ALT Characters
  • Ginko
    Ginko Oct 17, 2008
    Then use this table here.
    " is ALT + 0148
    Alt-0128 €
    Alt-0252 ü
    Alt-0129 
    Alt-0130 ‚
    Alt-0131 ƒ
    Alt-0132 „
    Alt-0253 ý
    Alt-0133 …
    Alt-0134 †
    Alt-0135 †
    Alt-0136 ˆ
    Alt-0254 þ
    Alt-0137 ‰
    Alt-0138 š
    Alt-0139 ‹
    Alt-0140 œ
    Alt-0255 ÿ
    Alt-0141 
    Alt-0142 Ž
    Alt-0143 
    Alt-0144 
    Alt-0248 ø
    Alt-0145 ‘
    Alt-0146 ’
    Alt-0147 "
    Alt-0148 "
    Alt-0249 ù
    Alt-0149 •
    Alt-0150 –
Symbol key how to degee symbal
With num lock on using the right keypad only type alt + 176 I leave a notepad of characters that i can copy and paste from to be faster. To do any alt code google alt codes
Nov 28, 2013 | Computers & Internet
Tip
Short cut keys for Blackberry phone,storm,curve,pearl.bold
Typing shortcuts keys for BlackBerry
These shortcuts keys can be used when typing text in Blackberry:
  • If you want to type the alternate character on a key, hold the Alt key and press the character key.
  • For an accented or special character, hold the letter key and roll the trackball left or right. Click a selected character.
  • To type a symbol, press the Symbol key. To view more symbols, press the Symbol key again. Type the letter that appears below the symbol to insert the corresponding symbol.
  • To insert a period (.), press the Space key twice. The next letter is capitalized.
  • To capitalize a letter, hold the letter key until the capitalized letter appears.
  • To turn NUM lock on, hold the Shift key and press the Alt key.
  • To turn NUM lock off, press the Alt key.
  • To insert an at sign (@) or a period (.) in an email address field, press the Space key.
  • To type a number in a number field, press a number key. You do not need to press the Alt key.
  • In order to type a number in a password field, hold the Alt key and press the number key.
  • To type a letter in a number field, hold the Alt key and use the multi-tap input method to insert the letter.
  • If you are typing input languages, hold the Alt key and press the Enter key. Select a language, then release the Alt key.
Know more about Windows 7
Windows 7 keyboard Shortcuts
on Dec 05, 2009 | Cell Phones
Tip
How to use Blackberry as a modem to acces internet?
Want to make a degree symbol
with num lock on using the right keypad only type alt + 176
Nov 26, 2013 | Dell 0Y3740 Keyboard
Number pad does not work
  1. Find Alt code.
    Numeric Alt codes for symbols are listed in Alt codes list. Check for Alt code of symbol you want to input.
  2. Enable Num Lk.
    You may need to simultaneously press ["FN" and "Scr Lk"] keys. That's the combination for "Num Lock" on some laptops. Look at the picture - the "Num Lk"/"Scr Lk" button is highlighted there.
  3. Hold down "Alt" key.
    Some laptops require you to hold both "Alt" and "FN" keys.
  4. Input Alt code of symbol on Keypad.
    Do this while holding "Alt" button pressed. Type Alt code on your laptop's numeric keypad. It's highlighted on the picture.
  5. Release all the keys.
    After you release all the keys alt symbol should be entered. If all this stuff didn't work - check if you have really enabled the "Num Lock" first. Remember that green indicator should shine near the lock symbol on your laptop's keyboard. If that wasn't the case - try simultaneously holding "FN" and "Alt" keys instead of just "Alt". That just might work.
Feb 15, 2012 | Toshiba Satellite P105-S9722 Notebook
Where is the "tm" symbol
There is no "tm" symbol key on a keyboard, you need to enter an ALT key to type the trademark symbol.
Hold down the "ALT" key while typing 0153 and it will enter this: ™ when you release the ALT key
Mar 04, 2011 | ASUS Eee 4G Notebook
I would like to be able to use accented letters in languages other than English. I want be able to hit num lock + ALT. + digit code to produce letter with accent mark. Where is the num lock key on the...
I don't know what your keyboard looks like, but if your running windows, this guide should help.http://tlt.its.psu.edu/suggestions/international/accents/charmap.html
Feb 26, 2011 | Computers & Internet
I just need to know how to use the diacritic/accent mark key on my Aspire 5610 keyboard.
I'll be glad to help you out with this. Assuming you have XP, you have 2 choices. Either use the Character Map, or an ALT code.
To access the character map, click
Start > All Programs > Accessories > System Tools > Character Map
An ALT code is simply when you hold down the ALT key and press a series of numbers on the keypad to get different symbols. Here's a list of ALT Codes:
http://tlt.its.psu.edu/suggestions/international/accents/codealt.html
Hope this helped :)
Nov 28, 2009 | Acer Aspire 5610-4648 Notebook
Have an e-machine H6535 running Windows XP home edition 2002 service pack 3. Having trouble keyboarding certain keys. All letter characters and numbers appear up ok but the other keys produce variant...
your "NUM LOCK" is on, you need to find the key and press it, its usually near the top right hand side of the keyboard.
the problem should then be solved
regards
Nov 14, 2008 | Computers & Internet
How to write spanish characters?
yes some portables you have to press fn key look for the key that says alt in blue color and use the numbers on keyboard it's in blue too relase and wala spanish caracters
alt 130 é
alt 160 á
alt 161 í
alt 162 ó
alt 163 ú
alt 164 ñ
alt 165 ñ
alt 168 ¿
alt 129 ü
Apr 23, 2008 | Gateway MX7118 Notebook
GE USB Retractable Number Pad HO98462 Logo
1,086 people viewed this question
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
