Question about Randell (84111NPCB)
Pressure settings for brand new randell 10' pizza make table
My manager changed pressure settings instead of temperature control. what is correct pressure settings?
  • Northeast Cooling LLC
    Northeast Cooling LLC May 11, 2010
    Tell me the type of gas and I can give you ball park on set point and differential settings. :)
2 Suggested Answers
bobicehouse
  • 1524 Answers
SOURCE: I have a Randell 5ft
This unit uses Thermostat/Solenoid Valve Combination's to control the temperature
1. Rail 2. Bottom Storage
The way it works is the thermostat senses the need for cooling and energizes the solenoid valve. This allows refrigerant flow which cools the area it is controlling. Once the thermostat is satisfied the contacts open and the solenoid is de-energized closing the valve. If the solenoid is bad, the valve remains closed, no refrigerant flow, warm unit.
Test the solenoid coil (two wires) to see if voltage is present either with a volt meter, or remove the coil off the valve and place a screwdriver (insulated) through the coil hole and you should feel the pull like an electro-magnet (what a coil is).
Posted on Dec 05, 2010
  • 903 Answers
SOURCE: temperature control
http://www.randell.com/assets/docs/randell/Custom_OM_DPM.pdf
go to this web site and check out the manual. It has some general info that can get you started on narrowing down just what is happening.
If it has been filled with freon 2x, there is an issue. Either it has a leak and it has not been found yet, or the amount of freon in the system is incorrect.
Usually, adding a timer is for defrosting purposes. Is there a frosting up issue?
It could be a thermostat issue but it is not set by the PSI, but by actual temperature. If it is a control that you have to set the PSI, an experienced refrigeration tech should know what to set it at.
Let me know if I can be of any further help.
Posted on Dec 20, 2010
Can the pizza delivery person make me pay for a pizza they dropped?
Call the manager tomorrow and see if he;lol make it right.
Jan 04, 2017 | Restaurants
Can I adjust the regulator to lower the flame?
Hello Douglas;
My name is Peter. I am a retired field service appliance technician.
What bothers me is that changing these components increased your flame size?
1.) Make sure you have the correct gas safety valve. These valves are preset to inches of water column.
2.) The ignitor has nothing to do with your flame size. What happens is the oven thermocouple controls your oven temperature. When your oven get about 40 degrees above the set temperature, the ignitor and controlling gas components will shut down. When your oven temperature falls below the set temperature the ignitor and gas components will turn back on. There are ovens called accurate, which are expensive and do not have a 80 degree swing.
3.) Ok. Gas regulator. It is adjustable. Generally you have about a 7" water column pressure going into the regulator and 1" to 4" water column pressure coming out.
At the top of the gas regulator you have a long stem. Inside this stem is a shaft with a spring at the top and a valve at the bottom. In between is a rubber diagram which controls the valve based on the gas inlet and outlet pressure.
4.) Adjust. Turn the gas supply off to the range. Turn on the oven and gas burners to bleed the gas from the system.
There is a slot at the top of the stem. With a flat head screw driver, turn the stem top 1/8 of a turn counter clockwise to reduce the regulator outlet pressure. Turn the gas supply back on to check the flame. You may have to repeat this process to get your desired flame.
BE PATIENT. BE SAFE.
Mar 03, 2016 | Frigidaire Kitchen Ranges
Gas Pizza Oven - Heat issues
Many of the Pizza ovens require ceramic plates that line the bottom surface of each oven. These ceramic plates absorb the heat and retain the temperature. I never used our ovens with a bare lower surface, always applied the plates for even heat and distribution.
Mar 05, 2014 | Ovens
Riddles with answers
you would need to divide 25 by three and add the other dollar to get precisely what each one paid.
that means each one paid 9.33 where the three repeats itself (terminating decimal?) but if you round it you get 9.33. when you multiply that out and compensate for the terminating decimal you get 28 and the 2 that the waiter pocketed.
thats where the other euro went
Oct 28, 2013 | Office Equipment & Supplies
How to change pressure setting on SG Intellisys Controller 39875158 Unable to change offline pressure 103psi and online pressure 93psi on Controller.Please advice the procedure to do so.If there is a...
For and SG controller use the following instructions to access factory setpoints which will allow you to change the pressure setting. Note : look at the metal data tag affixed to the compressor for the correct pressure setting. (eg: 125 psi) do not exceed the data tag pressure or premature damage to the compressor and personal injury may occur.
To access... Power must be applied to the
compressor with READY TO START showing in
the display.... press the center (MAIN MENU)
display button two times and then press the LOAD
button followed by the UNLOAD button, all within
three seconds.
To change settings... The values of the Factory
Setpoints can be changed using the same buttons
and procedures used to change the Operator
Setpoints. Refer to the Operator's Manual for
details.
To exit... Press either the STATUS or MAIN MENU
buttons. If no buttons are pressed within 30
seconds, the display will automatically return to
the Current Status screen showing Package
Discharge Temperature and Airend Discharge
Temperature
Oct 14, 2013 | Air Tools & Compressors
Why would my mother in laws 1996 toyota corolla start fine one day and be reallly hard the next day? my mother inlaw called me to look at her car and i went over to see what the problem was. well when i...
While you are comparing day to day events, you are overlooking the problem is consistent with the Mornings' first start. The engine is hard to start after sitting overnight.
The cold start routine is a setting that is suppose to reboot after the engine cools down. This is controlled by a temperature sensor which can be a water sensor or block heat detector. If you have a water gauge you can have 2 similar components and the component that works the water temperature gauge is on a different circuit than the Engine Management control.
Your defective sensor instead provides the temperature information to the Engine Management computer. It cues a change in fuel mix and timing so that the engine starts better and remains at a higher RPM for short time. If you have ever had a car with a carburetor, it duplicates the "choke" function.
Consult an autoparts store for a correct part and its location. At most, there will be some spillage of Antifreeze but it will be minimized if you do it with a cold engine.
Please rate my info.
Dec 08, 2012 | 1996 Toyota Corolla
I have the aube TH132 underfloor heating system installed. I have programmed the temperature set points to 18c but its over heating to 43c!! I've re programmed it but with no luck!! The icon for when...
This product has 2-year warranty against defects in workmanship.
Aube technologies Inc.
Warranty does not apply to poorly installed ...
Canada 450-358-4600
Manual does not have troubleshoot section.
section 4 includes temperature setpoints by model number.
On-line manual can be word-searched for fine details that might be missed by a visual read.
http://waterheatertimer.org/pdf/TH132-A-F-AF-230-thermostat.pdf
Check that air vents are open to control, so the unit can read correct temperature.
Change temperature Display selector for F or C.
Make sure wires are connected to correct terminals to match your voltage.
15 amp max rating indicates #12 gauge wire for 120Volts. Recommend that thermostat control a contactor instead of direct-wire to heat coils.
Example contactors
http://waterheatertimer.org/H230A.html
Oct 09, 2012 | Hardware & Accessories
My pizza prep-table freezes everything. I think it might be the thermostat. Could I be right
Hi
Sounds like you are correct, unless the door seals are not in good order, air leaking in can fool the thermostat.
If it has a top section that the pans for pizza ingredients sit in check that the airways are clear and that the tins and lids fit properly.
Regards
Gordon
Apr 27, 2011 | True Refrigerated Sandwich Prep Table 72"...
Its freezing my product
It is freezing your food? What brand is this? Have you checked your climate setting?
Feb 16, 2011 | True TPP-93D-2 Pizza Prep. Table, 300...
I have a Randell 5ft Pizza Prep table that's not working correctly and was wondering if someone might be able to help me? The top rail is cooling like it should but the bottom storage area is NOT cooling...
Dec 05, 2010 | Randell Refrigeration 60'' Refrigerated 2...
Randell (84111NPCB) Logo
147 people viewed this question
Top Randell Refrigerators Experts
Dennis Boxerman
Marat Brikov
Are you a Randell Refrigerator Expert? Answer questions, earn points and help others
