Question about NetGear WGT624 Wireless Router
Connecting mas os x
Hi, I have the netgear connected to my home pc. I have other laptops enabled (all xp/vista-based) no probs. I added the new macbook address to my wireless access list, but the mac keeps asking for a password (which we don't have). I even went to the extent of setting up a WPA password, but the Macbook can still not connect. Where am I going wrong? I've not had any problem setting up any windows laptops, just the mac one. Thanks a lot.
    Scholar:
  • 160 Answers
Seek info here or contact support.
http://kbserver.netgear.com/inquira/default.asp
you may need to use a mac address.
Posted on Dec 01, 2008
Cannot connect directly with ethernet cable or using pre installed wifi card wireless or using netgear wirless on my inspirion 9400 with vista home premium
Windows Vista has always had a prob with netgear.
If you get a free upgrade to 7 (on microsofts web site) then the prob will be solved.
Dec 15, 2009 | Dell Inspiron 9400 Notebook
I have a netgear router which i use for laptop and home pc, laptop is working but pc is not how do i reconfigure with code to enable home pc to work?
If u r able to go online wirelessly then the router wireless connection is configured and to connect your pc wirelessly just need to scan and connect to the network. To scan and connect to the network.
For windows vista-start->connect to->select the network name(netgear2)and click connect->it ll ask for password,enter it(telephone no).you ll successfully connected.Now disconnect the cable and try going online wirelessly.
For xp-start->control panel->network connections->right click on wireless network connection->select the network and configure.You ll be able to go online wirelessly if you still have problem let me know ll help u.Thank you
Oct 29, 2009 | NetGear DG834G Router
My wGPS606 wont print on my Windows Vista laptop!
I just found a way to enable the HP P1006 with a different print server (Liveprint on Orange Livebox router). Perhaps this might work with the WGPS606 wireless print server?
I set up the P1006 via the print server as instructed (I'm using Vista 32 Home Premium) but no test page would print.
BUT!! (with thanks to another another forum):
I selected printers, then right-clicked on the wireless printer I'd just installed and selected 'properties'.
Under the 'Ports' tab I deselected 'Enable bidirectional support'.
Problem solved.
Hope this helps.
let me inform you that this printer is not compatible with any wireless print server. The drawback is that it is not possible to network such printers. A printer needs a steady flow of data, which is easily accomplished when it is connected directly to a PC, but cannot be guaranteed when the printer is connected via a LAN. Also, these technologies require intensive handshaking between the driver and the printer.
The host-based software uses the computer's resources to process print commands and rasterizing data, taking advantage of the computer's memory and processing power."
Sorry I can't be more upbeat - but its probably useful to know that someone at HP thinks the job's imposible - unless someone out there has a fix?
May 11, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
Acer notebook with Vista won't connect to home w/l network
Use this tip for a check list : band, encryption, protocol (WPA, WEP?) Do you see your radio signal (SSID)
Do you set an access list on your router? add your Vista PC MAC address to router list or disable access list control.
Be sure to browse internet using a cable connection to router
Try removing access security and check if connection performed
Restore security protection and match router/pc settings,
Feb 16, 2009 | Acer Aspire 4315 Notebook
Problems adding a vista computer to a mn-700 network
you need to install a driver in your vista which will enable you to print your files.i hope this helps
Dec 29, 2008 | Microsoft MN-700 Wireless Router
No internet despite network connection
ok your problem is the home edition for some reason there are features that are missing compared to all xp versions and i'm a little surpise with vista because of none problems but check all your network settings on all computers but start with the home edition the pproblem one make sure the sttings areset and there are a few things that might not be turned on that has to be check under the add and remove program components but sometimes this area might request the os disk to make changes and also check under network settings that the log on in the network properities is client for microsoft networks then goto internet protocol the address should be obtain auto and very important under internet protocol click properties then advance then at the top click the tab at the top that say options then you will see tcp/ip filter click properties and make all checks are enabled and permit all which is the common for this to be turn off and also i like to make windows the wireless default control under the card configure properties.. but again the home edtion has some features that are not available compared to xp pro which is the best xp os of xp versions....
Dec 03, 2008 | NetGear RangeMax WPN824 Wireless Router...
Toshiba laptop running Vista loses connectivity
The problem is not Vista, the problem is the Netgear. I have seen this happen time and time again with both Netgear (primarily) and D-Link (often). That's why I *only* recommend Linksys.
Worst case - go buy one from Walmart (yes, they have 'em). Hook it up and see the difference. If, somehow, the problem persists, take it back, and you've lost nothing. But I'd bet (as they say down here in the South "dollars to doughnuts") that's your problem :)
Hope this helps - remember to rate :)
Oct 02, 2008 | Toshiba Computers & Internet
Can connect with usb stick on one PC and through inbuilt wireless on a laptop to the main router but not a new one
becos of you using three different os one is xp,other one is vista and other on is xpsp3 all the driver is different so how can he connect it.
Sep 06, 2008 | NetGear WG111 802.11g/b Wireless Adapter
Taking Time to Print
that is a network problem between the laptop and the PC. Look for your network settings and adjust them.
Use a tool like pctools to identify your network problems. Vista and Xp sometimes have a problem
Apr 19, 2008 | HP Pavilion dv6000z Notebook
Wireless connection
Hi, I am going crazy! Just moved house and took my Netgear Wireless router with me. However, even though the hard wired base unit works, my wireless laptop can't access the internet - even though a full stregnth signal is there when i browse for wireless connections. Using Vista Home Premium. Help appreciated!
Dec 29, 2007 | NetGear WGR614 Wireless Router
Open Questions:
See all NetGear WGT624 Wireless Router Questions
NetGear WGT624 Wireless Router Logo
80 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
