Question about Acer Aspire™ T180 PC Desktop
Aspire t180 memory problem
I upgraded my memory from 2x512mb to 2x1gb, i could not get vista to run with all 4 boards in their slots. works fine with just 2x1gb in place.
my spec says i got room for 4gb
any help out there ?
  • 2 more comments
  • robbo1955 Oct 17, 2008
    motherboard is fine for 4gb and works fine with 2gb, i would like as much memory as poss (4gb) but pc will not start up ?
  • wal911 Nov 01, 2008
    it A bug in the MB
    You Can put any am2 Dul Core x2 i put a 6000 3.0GB x2 And 3GB But Not 4GB The Moterbord will bich at 4GB of ram
  • Anonymous Nov 02, 2008
    my computer cant work with 4GB i thought it supports 4GB !
Check, if you motherboard support 2GB, or else start windows in safe mode with 2GB.
Posted on Oct 17, 2008
I have an Acer Aspire T180 and would like to upgrade the memory and add a wi-fi card. can you advise what cards I need to purchase?
Memory:
Looks like the Aspire T180 takes DDR2 533/667/800 memory. This is pretty easy to upgrade. Check to see how many memory slots your computer has (Probably 4, might only have 2). You should probably just replace what you have with new memory.
I recommend this memory:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231122
It is 2x 2GB modules. 4GB of RAM is a good amount of RAM to have, you will see a noticeable performance increase.
WiFi:
I would recommend a USB wifi adaptor. It is easy to instal and most ones work well, even the cheap ones. Just stick it in the back of your computer and forget it it's even there.
http://www.newegg.com/Product/Product.aspx?Item=N82E16833130066
I recommend this one, I have been using it for 2 years and have had no problems.
Apr 26, 2011 | Acer Aspire T180 PC Desktop
I have recently upgraded my brothers Acer T180 computer with approved crucial 2 x 1GB ram ddr2 PC2-5300 667 NON ECC UNBUFFERED CL5 which was scanned by the crucial website and purchased from them. When the...
Some motherboards are only upgradable to their allotted amount that board may only handle up to 2 gigs of RAM which is a shame. But this is the way it is. That is why I always check the board memory capacity before I buy computer boards or RAM for them. The beeps indicate error on the slots for the RAM that is why you can start up when you remove ram one at a time and replace. So use the allotted amount of RAM for that board specification or get another mother board that can handle more than 2 gigs of RAM. Sorry for the loss. Thanks for using FixYa! John
Apr 13, 2011 | Acer Aspire™ T180 PC Desktop
Memory Upgrade Problem
Some of the motherboard DIMMS got limitation. U need to check back the manual. Cannot simply insert different type of speed and capacity on each DIMMs.
Feb 13, 2009 | Acer Aspire™ T180 PC Desktop
Memory Upgrade
I believe the max you can go with per slot is 1gb.
This is copied from the Acer site:
Up to 4 GB of DDR2 533/667/800 MHz SDRAM
http://www.memoryx.net/acerxtd1024.html
Jan 31, 2009 | Acer Aspire™ T180 PC Desktop
Acer Aspire Memory problem
The read speed of your new memory is not compatible with your motherboard. It is a higher rate than allowed. The reason why it works when you have one of your old chips installed is because your PC will automatically drop the higher rate chip down to the one that is working. The reason it does not drop both new chips down to a suitable rate is because it has nothing to guide it like your compatible chip does. Always check the MHz on RAM chips and compare that with the acceptable rates listed on your motherboard specs. The good news is you can probably sell those chips and have money left over when you find upgraded compatible memory that is sure to be cheaper since it is slower.
Apr 11, 2017 | Acer Aspire T650 (AST650UC3601) PC Desktop
Dell Dimension E510 memory upgrade
Please check the type of RAM you are using.
You must return it to BestBuy and try using a Dell store.
Call Dell Accessories sale and they will be able to give to better options and it wud work too.
Jun 05, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Memory installation
bev,
all the DIM's must be of same type and same size to work, otherwise it creates problem, like no boot, boot with lowest memory etc.
There is no problem in your PC, its technical issue you can not use two ore more different type RAM at the same time in a motherborad.
Thanks
Iqbal
Apr 08, 2008 | Acer Aspire™ T180 PC Desktop
Doesn't boot with 3Gb of ram....
Your board can only handle 2Gb of total memory.
2 x DDR2 SDRAM DIMMs, Dual Channel DDR2 533/667/800.
Check your manual.
Dec 29, 2007 | Foxconn 6100M2MA-RS2H Motherboard
Memory module
Your motherboard supports 533MHz memory modules, no more. If you put anything higher in, it will work, but only at the speed of 533MHz, so there's not much point in aiming any higher. Just make sure what you're buying is a DDR2 533MHz memory module, and it's best to get them in increments of 2. If you have 4 slots on your motherboard, get another 2x512MB modules of RAM. If you're running Windows Vista, it might be worth considering 2x1GB modules. I think that pretty much covers your question, if you have anything else to ask, feel free to reply.
Sep 07, 2007 | Dell Dimension 5100 (D51L1) PC Desktop
Acer Aspire™ T180 PC Desktop Logo
213 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
