Question about RCA Scenium HDLP61W151 61 in. HD-Ready Television
Buzzing sound when tv is on
The tv makes on buzzing sound when on
Tv buzzing and ripples on theside
Posted on Jan 02, 2009
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
Westinghouse tv power box making buzzing sound
Hi I'm Peter, There is a bad connection and most likely the buzzing sound is a relay going bad internally.
Apr 19, 2014 | Westinghouse Televison & Video
I have a proscan 42LA45H 42 in television that has started making a buzzing noise from the back. What is causing this, and what do I need to do to fix.
Hi
If picture and sound is Ok, and only this buzzing sound is heard from the back of the TV, It should be due to core soose of some ferrite cored transformers inside, especially to the power supply regulator board of the TV. Open the back cover of the TV and swtich it ON. Listeen very carefully which transfromer makes the buzzing noise. Just trouch and press the core of the transformer suspected with some non-cunductive material like glass rod, or a stick of dry wood. You can identify the transformer that makes noise by this way. After identifying the exact transformer; switch OFF the set, unplug it from mains socket, apply some "Super Glue" like fast boanding glue to the joint of core of that transformer. Allow sometime for the glue to set. This will solve the buzzing sound problem of your TV. OK
Jul 13, 2011 | Proscan 42LA45H 42 in. LCD TV
Vizio GV42l buzzing
Vizio makes an ok LCD, but if you notice they no longer make plasma. they stopped last year. Anyways. the buzzing sound is semi serious, it sounds as though you have a capacitor leaking. It is best to get it fixed before it goes out all the way, with it buzzing it will be easier to identify. Best of luck
Sep 12, 2009 | Vizio GV42L 42 in. LCD Television
Buzzing from inside when off.
hi!if your t.v is always on stand by power mode and there is a buzzing sound the problem is in power supply section,you need to check for weak capacitors.
Sep 08, 2009 | Emerson EWF2004 20" TV
Whenever we switch on the Tv is makes buzzing sound....
This is a problem in the filter section in the power or sound source.
Aug 14, 2009 | Televison & Video
37inch Vizio TV making buzzing sound from back
my tv is new too and also makes a buzzing sound and i turned the DCR off and it worked to thanks for the help!!
Jan 03, 2009 | Vizio L37 Television
Quasar 1989 tv makes a buzzing motor sound
Hi and welcome to FixYa,
Initially, if you have confirmed that the source of the buzzing sound is from inside the TV, then that would indicate a component about to fail or would need attention. Let us try process of elimination:
  • tuner - most unlikely, the tuner is responsible for selecting the channel. No component/part of the tuner could make such a mechanical buzzing sound;
  • speaker(s) - most unlikely, the speaker could have a buzz but generally would not affect the video nor cause snow (weak TV signals);
  • transformer - a strong possibility although without knowing the exact model, at most generic ideas; power transformer, flyback transformer, horizontal drive transformer (unlikely);
  • arcing - another strong possibility. This could be caused by damp, dusty surroundings of the components especially at the FBT area. Another area that could have adverse effect when dusty/damp would be the anode cap.
This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 26, 2008 | Televison & Video
Buzzing sound from my tv
tv makes a buzzing sound when i turn on the set, than stops.
Dec 10, 2007 | Harsper HP-4200VPM Television
RCA Scenium HDLP61W151 61 in. HD-Ready Television Logo
206 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
